Ok but my cable has a button for OBD and one for ADS...do I keep it on OBD? Im still getting the Net error-0009 timeout. Even with the older version of ediabas now. My obd.ini wasn't in the bin folder of ediabas so I moved it there. Also, in its settings under hardware it was set to USB....I changed it to OBD. Im close...but still not there yet.
Make sure that you have correctly modified the path settings in Environmental variables of Device Manager or Windows won't know where to look to find EDIABAS. If you are using INPA v4.4.7/EDIABAS v6.4.3, you don't need OBD.ini, it was introduced for versions of EDIABAS commencing with v6.4.7.
Inpa now shows both Black dots and Im able to read modules from the car....but dis times out with the error net-0009 and won't pass the api test. Does it have to pass this test inside of Ediabas via the configurematic menu? Im no longer getting any colored bars on the upper right hand corner of DIS. They were there before I got INPA working. Im using an ADS interface with the OBD button selected.
Everyone seems to have a fixation with the coloured bars on DIS but they are only applicable where DIS is installed in a workshop network - for our application, they should be off. If DIS doesn't pass the APItest, it means that there is a problem with the virtual network configuration or with the EDIABAS.ini file in INPA. See the DIS troubleshooting guide in post #800 on page 32 of the DIS Success thread here https://www.bimmerforums.com/forum/s...6#post27153566 I will email you with a correctly modded EDIABAS.ini file for EDIABAS v6.4.3 and an OBD interface. Also, make sure that your antivirus software is off whilst running DIS as it can disrupt communication on the VM network.
Look inside your c:/EDIABAS/Bin folder and View EDIABAS.ini. If your computer doesn’t display file name extensions (e.g. .ini, .exe, etc.) but shows the file name extension on EDIABAS.ini, you need to rename the file simply as EDIABAS.
So I got INPA working again...although it barely does much for my e60 w regards to modules etc. lots of error messages and "IFH module not found" etc. Now DIS is giving me a diagnoses bus error "Communication between operating unit and diagnostic head is impaired. Error number 200.159. I hope my interface hasn't bought the farm. Before I was getting error "no diag head connected or found etc".
I notice theres no entry for diaghead in the ediabas.ini file inside of dis but there is in my ediabas.ini file in the bin folder. What gives?
