As the title says. Clutch, and pressure plate out of my 97 328. Worked great before I took it out. Almost brand new. $100 + shipping. I have a 328 flywheel as well for $150 obo if anybody is interested.
edit: $200 for everything. ALL OFFERS ENTERTAINED
Shipping from zip code 84020
Box dimensions: (L x W x H) 13" x 12.5" x 4.5" (39lbs)
I may, but trying to weigh out just doing stock or going with an M3 clutch.
What's the reason for replacing?
also, was it slipped much?
Trevor Ely
'13 JSW TDI
'05 Elise
'96 328is
'91 318is
'90 325is
'89 325is
'88 535is
'95 M-Sport 540i (1 of 200)
'85 190E 2.3-16 ECE
'70 Honda N600
'00 A4 1.8TQMS
how many miles?
"The main thing about money, Bud, is that it makes you do things you don't want to do."
"The great difference between us, Angelos, is this: you believe you have found salvation, and believing this, you are saved; I believe that salvation does not exist, and believing this I am saved."
Bump for a great seller
Milltek pipes. Ground control coilovers. Conforti Tuned. V1 & iPod hardwired
Would that fit a 92 325i?
Tom
I don't see why it wouldn't, as long as you use the 328 flywheel with it. The 325 flywheel doesn't have the same amount of useable surface area. I looked it up in the ETK; the assembly is the same overall diameter but the 328 uses more actual inside area on the flywheel. Basically you may see some performance gain because the actual clutch disc is bigger.Originally Posted by bmwperson
I may be interested. I need to find a good local shop to install it. Any reason it wouldn't fit a 98 328ic?
Would lit fit a 318is? Ill give you 125
Hey JB, I just bought a 98 328i to replace the Mini. Car has 80,000 miles, so the clutch could go at any point. A cheap replacement would be great! Let me know when you are at Eurosport next week (or today) and I will probably come buy it. Flywheel too.
Keith White
#91 Street Modified Utah SCCA
