Results 1 to 4 of 4
Thread: Removing Motor Mounts on 895 840
    Apr 2015
    Houston
    95 840Ci
    I have the skill to do this job, but apparently not the knowledge. I attached my 17 in 3/8 drive to a universal joint and 20 inches of extension. The top nut is in a tight spot and is tilted back towards the engine making it impossible for my setup to seat properly . How do I get this top nut off. Both sides had already separated leaving just the upper "cap" and nut
    Jun 2010
    Hyperworld
    '97 840CI
    IIRC...
    My standard procedure is to unbolt the mounts from the frame, then lift the engine with mounts still attached to the bracket. Even if the engine is not leaving, it should provide critical access to the top hardware.
    Going the other way is slightly trickier because the mounts are installed to the engine bracket first, but need to be precisely oriented/aligned/clocked to the holes in the frame. As the engine is lowered into place, I'm under there checking the alignment and persuading mount studs to go into frame holes.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Wobbly extensions from the top are helpful
    Regards,
    Brian
    Cave Creek, AZ
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    Can the left engine mount on an early model 850i be removed without having to disconnect any of the lines that appear to be in the way? I took a quick look while under the car and it did not look easy to do but mounts on my car may be dry-rotted and cracked.
  1. Replies: 14
    Last Post: 08-02-2010, 03:44 PM
  2. Replies: 7
    Last Post: 01-06-2010, 01:18 PM
  3. e46 m3 motor mounts on e36?
    By BMWFanatic in forum 1992 - 1999 M3 (E36)
    Last Post: 07-07-2008, 01:17 PM
  4. Cool Alpina 3.5L motor mounts on ebay
    By SneezyMcFartLeg in forum 1983 - 1991 (E30)
    Last Post: 09-02-2007, 11:21 PM
  5. M3 motor mounts on a 325i?
    By GriFF3n in forum 1991 - 1999 (E36)
    Last Post: 06-14-2006, 03:11 AM
