Results 1 to 21 of 21
Thread: How much does it cost you to maintain your E36 M3?
    Feb 2016
    Sydney, Australia
    White 98 E36 M3
    Im looking into buying a E36 M3 and just wondering what price points i should be looking at. If something major breaks and stuff and just pretty much the adverage price people pay for stuff. Thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Question: Are you a DIYer and make everything DIY, or do you have to pay a shop to do all the work? That makes a big difference. In addition the spare parts prices in Australia are much higher than for example in the U.S.
    I am doing all repair and maintenance work DIY, so only the parts cost I have to count.
    I have my M3 now 6 years, bought it with abt. 30 k miles. Parts I repaired/replaced:
    both front shocks as they were leaking
    broken glovebox button replaced
    glovebox cover re-glued
    engine oil and filter
    trans fluid and filter
    repaired my alternator with parts from another used alternator
    4 new tires
    microfilter
    1 foglight replaced due to broken glass
    replaced leaking power steering hoses DIY
    some vacuum hoses replaced in engine bay
    hanging headliner DIY will be done next month
    brake pads replaced, rotors I bought for stock till they need to be replaced
    giubo and center bearing replaced
    exhaust rubber hangers replaced
    sound absorbing mat removed partially above the giubo, as it was touching the driveshaft
    airfilter replaced
    outer door handle gaskets replaced
    Thermostat and thermostat housing replaced incl. coolant
    fuel filter replaced, also the leaking fuel line around fuel filter
    passenger seat occupancy sensor mat repaired
    That is basically all I remember except some smaller cosmetic stuff
    Free of charge done by BMW:
    AIR BAGS:SIDE/WINDOW recall/defect on 1998 BMW M3 Build Years/Makes/Models: 1997 - 1999 BMW M3 - reprogramming control module.
    Voluntary Emissions Recall Campaign No. 99E-A01 - UPDATED Crankshaft Position/RPM Sensor should be BMW part# 12 14 1 709 616, made by OEM Siemens. BMW e36 e39 z3 Adapter Wire for Updated Position Sensor should be 12514592703. BMW Sensors Problems and Faults Voluntary Emissions Recall Campaign No. 99E-A01
    Model: E36 – BMW 323i and BMW 328i with M52 engine produced June 1995 - December 1998 E36-BMW M3 with S52 engine produced January 1996 – December 1998. Complaint: Vehicles that have a faulty crankshaft position sensor have had a Voluntary Emission-Recall Campaign. This is to check the illumination of the check engine lamp as well as fault code 83 – Crankshaft position sensor, and fault code 244 – Crankshaft segment timing. Remedy: The crankshaft position sensor should be replaced with the same sensor used on a M52TU engine. An adaptor harness must also be installed so that it has a 12V operating voltage instead of the 5 volts currently supplied by the DME.
    So in my case that was not much and only material cost, but I did not drive it a lot, abt. 25 k miles in these years.And I do not drive it hard, no drifting or racing, no use in winter, as I have some other cars, just a fun car.
    Dec 2014
    Stuttgart, Germany
    One Too Many
    I am a DIY Guy, mostly the only things that go wrong with these motors as any BMW motors is... Usually Nothing. Just some Sensors, as Crank/CAM/O2, Maybe the double Vanos needing new seals, Some parts need cleaning as ICV, MAF, You are better overhauling your cooling system (radiators, water pump) thats the number one killer for these engines dying or getting a bad HG/overheat etc. You may require some interior work as saggy headliner/door cards, etc, all which can be done, some may be subjected to suspension work or may just be fine, watch out for rust under neath, maybe some soldering in the trunk, where there is always some broken wires, the trunk harness.
    the myth about the ubber expense of owning a bmw is just that, a myth created into reality by some shops and how much some people will try to charge you for parts.
    If you can buy it, for a good price, and can do most stuff DIY (have a sect of screw drivers, sockets, hammer and what not) then you can do it. No big expenses.
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
    Feb 2016
    Sydney, Australia
    White 98 E36 M3
    For the most part i will be DIY'ing most of the stuff... if it gets hard i might need some help from others (dad etc) but i don't think i will be going to a mechanic for a simple job i can do myself. I also want to learn more about the car and cars in general.
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Look, if you can change your own oil, change your own wheels, understand how a car works, take you time every now and then, top up your radiator, comfortable taking off panels and insides after looking at guides on how to do things, can follow simple instructions then you can own a BMW. Its a Drivers Car... the E36 in particular has a very easy and nice as in enjoyable learning curve to it. Make sure its a EVO as in S50B32 motor. Just rebuild the vanos with seals worth ~40. Then redo some of your cooling system, your crank and cam sensors may also be nice to replace, do a bit of maintenance in the engine bay and change out al fluids (trans,motor and radiator) check for broken hoses here and there in the intake and you are done. Trust me there is nothing to it. The biggest issue you may come across would be insurance if you are at a young age like under 20.
    your username suggests you already are familiar or have in mind the 328i, if so, then the m3 is not that far off. there is nothing special about owning a particular sub model, most of the work is the same, some parts may be a bit more expensive, but how often do you need that.
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Prices in Australia are obviously nearly double the U.S., as with practically everything else (whether fuel, groceries, house prices etc) and are based on wages we earn vs yours and the exchange...
    In any case, LABOUR costs are what cost a bomb, not so much the parts.
    When the dollar was more favourable, you could get stuff from the U.S. even cheaper and that made it worthwhile. Not so much anymore, although some Aussie retailers for Euro parts are *still* gouging, owing to our higher cost base.
    If you can DIY some of the work, you are already ahead most of the way in working on the BMW. Big things to factor in ASAP are the Cooling System and exchanging fluid in transmission and differential once every 50,000km. After that its pretty routine, I think, not too much to worry about. Look after any care, and it will look after you. BMW's are the same, but just don't appreciate neglect.
    Suspension work may be next on the agenda, depending on the vehicle's history.
    That said, in the eastern states you have the annual road-worthy tests, so the fact the car has it should be a starting point (or a cause for concern...).
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Great Points, By B320i, Basically Your Cooling System & Fluid (I Use the Type A Coolant Mixed with a little distilled Water, Works Great), Engine Oil & filter, Transmission Oil and filter, Differential Oil and few Electrical Gremlins here and there, over all if its well taken care of, you will be fine. Tell us when you got the car.
    Quote Originally Posted by B320i View Post
    If you think Australia is bad, I will swap places (including cars) with you in a heartbeat right about now, if I could.
    Prices and Labor here are still ridiculous, the 20 year old M3 here costs 3x times the US price, and there is a bmw old boys network full of the usual kiwi suspects, mr. tall poppy, mr high and mighty, mr. I am in denial, and mr. ripoff, imagine paying $500 for used M3 bumpers? Yep, they charge it because they CAN. And if you got anything going, they want it for free. Never had that problem with anyone else, phew, cant await for my exit.
    washington dc
    Avus Cosmos Calypso!
    $500 is not completely unreasonable if it's an OE bumper in good shape and repainted to your particular color with high quality base coats and clear coats. Basically, the amount you should budget depends on how much of the work you can do yourself.
    Jun 2014
    Santa Clara, CA
    F30 '14 328i Msport
    All of the points above are great.
    Rule of thumb for cost on these: More than most, less than some
    Sep 2008
    Portland
    2 bmw's
    1-2k a year lol
    The server is too busy at the moment. Please try again later.
    Feb 2015
    United States
    '95 M3 Coupe
    Unless already done, plan on doing a lot of bushings. Ask me how I found out.
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Purchased 2 years ago not running. Restored it to like new mechanically for about $3000. Only thing that's wrong right now is the catalytic converter which I have other plans that will leave that as no longer a worry. As of now though I don't expect it will need anything for a while. Preventative maintenance goes such a long way.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Jun 2014
    Santa Clara, CA
    F30 '14 328i Msport
    42
    Jun 2010
    ithaca, ny
    2001 325vert
    If you only fix what needs to be, it wont be much annually.
    The problem is these damn forums, they suck you into the cars. Next thing you know youre spending fortune on new rims, fancy engine mounts, led taillights. Thats when shit gets expensive.
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Quote Originally Posted by tynwarrior View Post
    Got that right. Thankfully old fogies (at heart, like me) dislike visual appeal and go for functionality first... That said, the OE Pioneer speakers in the rear have developed "fart" syndrome...
    Sonoma Whine Country
    E12, E12, E36, E39
    To date, with just under 100K in my ownership and about 215K total, my costs are about 4.3 cents per mile for maintenance and repairs. That will take a jump soon as I've got a new radiator ready to go in and it's almost due for O2 sensors too, but the tires are new, which is one of the big costs. $.043 or under a nickle a mile. That's cheap. Granted I do everything myself and look for good value pricing, but it's still cheap.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Dec 2018
    Ireland
    M3
    Where would I get a full timing chain kit for a s50b32
    Austin, TX
    E36M3, E60545i, F10550i
    Quote Originally Posted by O neill m3 View Post
    https://www.ecstuning.com/BMW-E36-M3...ing_Chain_Kit/
    Nov 2008
    Indiana
    S50B32 not S50B30, he has dual vanos, that kit is for a single vanos.
    Austin, TX
    Quote Originally Posted by somebody5788 View Post
    Ah! Thank you. My apologies to all.
    Dec 2018
    The Couch
    2017 Mustang GT
    Haha, isn't that the truth... enter the black hole at your own risk
  1. How much did it cost you to swap for an M3 bumper?
    By PrecisionX in forum 1999 - 2006 (E46)
    Last Post: 08-13-2012, 09:22 PM
  2. How much did it cost you to ship your Vaders?
    By Garrett M in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2009, 04:06 PM
  3. How much did it cost you to have your COs installed?
    Last Post: 01-27-2007, 01:28 AM
