Looking for several Dinan parts.
-Main Charger Bracket with or without legs. Must be Vortech based.
-Crank pulley, no hardware required.
-Bottom leg spacers. They look like large round washers.
-Cruise Control Brackets
-Fender air filter mounting plate
-Dual Port Dipstick Tube
Any other Dinan parts you have laying around message me about. I'll make offers.
949-500-8493
RMS used the same bracket at one point so it may be worth it to give them a call. They should have the fan spacers too.
If you can get me dimensions of the spacer bushing things I could make them for you. I remember them from my old dinan kit.
The long bolts aren't hard to get. You just need to measure the length difference between the stock mounting point and the new mounting point then add that to the stock bolt length. Then find it on McMaster.
I don't want RMS parts. I'm looking for Dinan specifically.
I will have the bushings made up if I need to locally. It's just a WTB post to see if anyone has something now.
I'm not looking for any long bolts. I have all of them in quantity. Not sure where this comment is from. Everything I'm looking for is fairly specific. If it is on McMaster or readily available, I have it already.
Thank you though.
Good luck..
Bump.
