Results 1 to 12 of 12
Thread: 1988 e34 530d m57 swap
    Jan 2014
    Slovakia
    88 BMW e34
    Hello everybody, finally moved my project - swaping an m57 3.0 diesel engine into my former 524td e34 to be published a little. It was my first swap ever done, so many things have to be changed and upgraded during the time, but I have learned a lot on this project and completely fell in love with this car, so far I am driving it for 4 years daily and we have completed over 30 000km.
    It all started by the death of my former m21 2.4 litre diesel engine with automatic transmission. After few month of trying to bring it back a gave up, and after one ride in e39 530d it was clear, what has to be done. Got an m57 3.0d 135kw/400Nm engine with 5q manual transmission from e46 and the works have began.
    During the works I was strugling with many problems, both mechanical and electrical. So far I got to the finish line and happily riding the car, while doing some small upgrades all the time, we all know, what I am talking about.
    Some info of the current state of the car:
    Silver e34 with 135kw 3.0 litre m57 diesel engine, 5q manual, 2.65 LSD, M5 3,6 brakes, M tech, whole body electronic from 525i, so I have HIGH cluster and CC and so on...
    Here are som pics of my progress and works on my car, hope you would like it at least a little bit, though it is not a petrolhead but with an GT2260V from e60 we can easily get 150kw and 500Nm
    http://sklenus.rajce.idnes.cz/e34_Resto
    planning lots of thing to do, but still in school so I have limited time and resources
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    Wow, amazing project! I wish we got more of the diesel engine options in the States
    Great White North
    various
    Very nice.
    Ya the only diesels we get are movie actors......
    Aug 2013
    Central Florida
    1989 BMW 535i
    I had a chance to pick up a 524td a few years ago for like $700 . At the time i was an avid dieselhead (still am ,actually). But all they imported here unfortunately were automatics.
    92' 535i stick/'89 535i / '85 380SL / '80 300SD / / '77 240D / '91 Jetta IDI / '82 Caddy IDI / '81 Cabriolet IDI / '66 TR4a IRS / '70 Spitfire MkIII / '67 F-100
    Washington, D.C.
    1995 BMW 525i/5spd, 1999 Mercedes-Benz CL500
    Quote Originally Posted by sklenus View Post
    Well. This engine looks pretty awesome in that car. Granted it's not a 4.4 liter/6spd swap, but still very cool. Impressive amount of work, too. How is the body holding up after almost 28 years of driving on Easter European roads?
    Bellevue, WA
    1995 540i/6,740i
    Wouldn't mind having a 2.65:1 lsd for the 540. Love long gears
    Jan 2014
    Slovakia
    88 BMW e34
    few months ago I made my dream come true and bought an e34 540iA saloon, it is hell a differrent driving experience, while the max torque of 400Nm is available at totaly different revs, but the 530d driven each weekend for 400km with a load of 4 people traveling to school with backage for 6l/100km of diesel is quite good, yet it is not a sports car, I set the suspesnsion for comfortable ride, while driving with people, there is no need to invest a lots of money, but now I can see, that the suspension is getting behing the power of the car, will need some upgrade, still want to keep it in more comfortable way, rather than Bilstein B8 on 540, so in future months will change the suspension for sachs or something like that, to stay firm on the road, but also comfortable riding on bumps
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    Never-never land
    E34T
    Hell yeah!
    I'm very interested in any details of the swap, especially what electronics you're using to run the engine and work with the chassis. Or did you convert it to a mechanical injection pump?
    My personal fantasy is an OM606 in my E34, but this is a close second. How much custom work was required to phyisically fit the engine and transmission?
    Quote Originally Posted by Martinator View Post
    I have this and I like it.
    Mar 2013
    Ireland
    89/95 BMW E34 520i
    Hi i am about to to the same swap did you have to change engine mounts or did engine fit without any mods.
    Jan 2014
    Slovakia
    88 BMW e34
    to Silverdream:
    there were only few mods to be done - as I used an e46 330d 5speed trany, I put it on the e46 trany mount, it fits the e46 chasis with no mods required, right engine mount is OEM e34 m21 or m51 diesel mount, petrol won't fit while different engine angle in the bay, so far I made only left custom mount
    In nearest future I am willing to put an 6speed trany from e46 and will use an e38 730d left engine mount, it will need a little customization to rubber engine mount, it has to be higher, so will put some subframe between rubber and front axle bar
    Mar 2013
    Ireland
    89/95 BMW E34 520i
    Thanks for that so its a no go for me as my engine mounts wont match up would it be a big job to cut engine mounts from doner car to fit in my car as i have agreed to buy a clean 2002 e39 530D . How did you manage with the diff did your diff work with the engine change & joining the interior loom up to the new ecu wiring loom. I was going to switch everything over to my e34 once i had it back to a rolling shell.
    Jan 2014
    Slovakia
    88 BMW e34
    to Sliverdream:
    you probably won't be able to cut and weld e39er as they are aluminium and welding is much likely impossible, the easiest way is to get e34 diesel mounts, if you won't have luck getting one, I can arrange some package from Europe, still driver side will be custom work for some welder
    -electric swap is not the way, trust me, I have put a complete wiring from e46 to an e34, most things customized to work properly like all the lights with LCM from e46 and so on, but afterwards I swaped e34 HIGH wiring to get check control cluster, rpm signal from m57 engine is working, so far I have not manage to fuel consumption gauge and oil level sensor switch to work, all other systems are working properly
    - driveshaft is custom made to fit e46 tranny and tds 2,65 diff
  1. E34 WTB E34 5 speed swap parts - ZF310, driveshaft, clutch, flywheel, pedals)
    By M3221 Birel in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 07-22-2015, 08:03 AM
  2. e34 m57 swap - rpm gauge
    By sklenus in forum 1988 - 1996 (E34)
    Last Post: 07-10-2015, 11:31 PM
  3. E34 FS Complete E34 m50 5spd swap, zf310 and 3.23lsd
    By BMW750il&AudiA6 in forum E34 Classifieds (closing soon)
    Last Post: 07-05-2011, 05:59 PM
  4. E34 Complete E34 535i Manual Swap Kit - minus throwout bearing
    By TGreene in forum E34 Classifieds (closing soon)
    Last Post: 03-30-2010, 06:07 PM
  5. E34 WTB: e34 manual trans swap parts
    By sfgearhead in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 12-16-2009, 05:19 PM
