Hi
Have a new ceramic resistor card to go into the gas tank level sender. Had a go at removing the fuel pump/level sender unit today, Got stumped at unscrewing the big black ring/flange that holds the unit in the tank. Bentley talks about a special tool. What have you creative people used as alternatives?
Cheers
Muzz
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
You can do this method...
https://youtu.be/vhVXXjrqV1Q?t=2m17s
Of note - you pretty much have to seat the rubber gasket on the fuel tank then carefully push in the fuel pump. I had a much easier time using a new gasket than when I reused an original. Also avoid having a full tank of gas otherwise it will slosh out. Ask me how I know.
I tried beating it on the tabs with a drift and was damaging it more than moving it so stopped.
I have a new gasket on hand.
Yes the unit is very low in the tank, Took the car for a drive with the red light on and took it right down to the Empty line while sneaking home on fumes. attempted do do the job. Put the car back together again and gassed it up ready for the weekend. It only took 3/4 of a tank to fill it. Not sue if 1/4 of a tank left in it would be low enough, so in some ways happy to have to go back and have another go. Next time I'll run the car right out of gas going around and around the block, put 4 liters in and know that the fuel level is low enough.
Try this...
http://www.bimmerforums.com/forum/sh...nger-Available
You can also find them on eBay...
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
Thank you for the tip on the tool.
I have just ordered one with free international shipping from Hong Kong
If you get the gauge down to 1/8th full, the fuel level will be low enough to remove the pump assembly. Then you still have enough fuel to make a trip to the filling station without any unnecessary drama.
I've been in there at least a dozen (>12) times, and at first I was overly cautious too__I mean, it's not like I'm smoking while doing the job (I don't smoke!)...
The first time, I made my own tool to remove the collar. I wasn't too worried about removing it, but without a proper tool, how would you torque it back to spec when putting it on?
One of the dealer mechanicians gave me the BMW tool when they received a replacement.
Thanks Randy
I have a tool on order now.
The fuel gauge is the reason I'm taking the pump unit out. The gauge jumps around from empty to 1/2 full whenever it's below 1/2 full. Have a new resistor card to fit into the gauge sender unit.
My local gas station is about a 1 km away, so running the car out of fuel and putting 4 liters will not cause too much drama.
I knew someone had the proper tool. Should have guess it was Randy.. as that would have been a safe guess lol
The fluctuating/intermittent fuel gauge was a big issue when the cars were new, and I almost never hear about it nowadays. The recommended cure, working in all but the most extreme cases, was to run a couple bottles of Chevron's Techron through the system (in a couple back to back fillups) and periodically thereafter. Though intended for cleaning fuel injectors, it did help thwart warranty replacement of the whole fuel pump assembly when just the level sensor was malfunctioning.
In the last year I've run 4 bottles of injector cleaner through the car in an attempt to clean the sender unit. That and using the trip meter as a sudo fuel gauge and running the sender unit through as much of its range a possible. This has provided some improvement. Still having problems, so time for a new resistance card. Got the resistance card off E-Bay, out of the Netherlands for US$25. If it all works out, its a lot cheaper than a whole new pump unit.
Aww darn! Well then, I hope the card swap goes painlessly for you
You know, I had this happen right after the last fill-up. It was kinda fun to watch the needle swing back and forth, but a little worrisome too.
It had been raining like heck for the previous week, and the fill-up in question was in a hard rain. Things dried out a couple days later and it seems fine since. But I'll watch for this happening again.
I've always seen fuel gauges as somewhat of a luxury as all my German (aircooled) stuff (2 and 4 wheel) these days don't have them, but do have reserve taps.
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would motor about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
Been working on the 2.0L Z3 over the last few months and have not got around to fitting the card yet in the 3.0L Z3.
Forgot to update... my card was broken, the new card fixed the problem. Also found a tool for R&Ring the ring pretty cheap.
https://www.ebay.com/itm/New-Univers...oAAOSww6Veu0ee
New Universal Fuel Tank Lid Sender Unit Removal Assembly Tool Fuel Pump For Benz
I had a wonky gauge in my M. Ran a bottle of Techron and it's back to normal...saved me a card and a tool, for now. Perhaps a cleaning is worth a shot first, for anyone that's not certain if anything is broken.
Nathan in Denver
