Results 1 to 9 of 9
Thread: m20b23 tuning potential
    Feb 2013
    Warsaw, Poland
    E34 540i/6 E30 323i 2d.
    M20B23 (LE-Jetronic) has 150HP stock at crank. I would like to make it 170-180HP. Is it possible with hotter cams, headers, Mahle Pistons, Maybe conversion to Motronic?
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    If you change the cams, headers, and pistons, you probably want a tunable engine management, like VEMS or Megasquirt.
    And, of course, anything is possible with enough money. You can get 300whp out of an m20 if you want to. It just requires enough money. It definitely won't be a 2.3 liter anymore, maybe 2.9 or 3.1 liters.
    Feb 2013
    Warsaw, Poland
    Good point Kershaw. My question wasn't specific enough, let me modify it:
    I would like to get around 180-190HP from M20B23. What modifications should I do? (Now, knowing mods' list I will be able to calculate the cost).
    One note: I don't want to bore that engine.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    Dual valve springs, cam, +2 (885) valves, a mild port job, 19lb injectors and a motronic/chip upgrade.
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    you could swap to a 2.7 eta block to effectively bore/stroke it too.
    monterey, ca.
    e21, e30 m3. e46 330ci
    Quote Originally Posted by Bazyl View Post
    ....One note: I don't want to bore that engine.
    why not? the Ljet M20B23 with 150hp had 9.8:1 compression. since the bores are probably tired and you're swapping pistons then it's only logical to bore it and bump the comp ratio to 10.5:1, displacement is one of the quickest way to gain torque.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Feb 2013
    Warsaw, Poland
    I would rather swap bottom end with ETA's bottom end.
    So, the setup would be:
    -ETA bottom
    -731 Head
    -Mahle pistons
    -Schrick cam
    -Headers
    -Some porting
    -m20b25 Intake manifold
    What could be expected power range?
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    Oct 2020
    USA
    82’ 323i
    -ETA bottom
    -731 Head
    -Mahle pistons
    -Schrick cam
    -Headers
    -Some porting
    Hey @bazyl did you ever get this done?
  1. Tuning Potentials 3.0L vs. 3.2L engine
    By Exacc in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 06-09-2007, 02:55 PM
  2. Advice for a potential E36 buyer?
    By Logik in forum 1991 - 1999 (E36)
    Last Post: 04-20-2004, 06:45 PM
  3. ES Tuning exhaust?
    By axion911 in forum 1991 - 1999 (E36)
    Last Post: 03-13-2001, 07:20 PM
  4. Replies: 5
    Last Post: 03-01-2001, 10:41 PM
