M20B23 (LE-Jetronic) has 150HP stock at crank. I would like to make it 170-180HP. Is it possible with hotter cams, headers, Mahle Pistons, Maybe conversion to Motronic?
Thanks!
If you change the cams, headers, and pistons, you probably want a tunable engine management, like VEMS or Megasquirt.
And, of course, anything is possible with enough money. You can get 300whp out of an m20 if you want to. It just requires enough money. It definitely won't be a 2.3 liter anymore, maybe 2.9 or 3.1 liters.
Good point Kershaw. My question wasn't specific enough, let me modify it:
I would like to get around 180-190HP from M20B23. What modifications should I do? (Now, knowing mods' list I will be able to calculate the cost).
One note: I don't want to bore that engine.
Dual valve springs, cam, +2 (885) valves, a mild port job, 19lb injectors and a motronic/chip upgrade.
87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
New "made in Europe" seat shocks. PM for details
http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
you could swap to a 2.7 eta block to effectively bore/stroke it too.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
I would rather swap bottom end with ETA's bottom end.
So, the setup would be:
-ETA bottom
-731 Head
-Mahle pistons
-Schrick cam
-Headers
-Some porting
-m20b25 Intake manifold
What could be expected power range?
This might help
http://racehead.com.au/m20-low-compr...troker-engine/
