Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: TPMS malfunction; RDC module failure
  1. #26
    Seneca, SC
    2019 X5 40i, 2012 X5 35i
    Perhaps this BMW TPM RDC solution applies to your situation: https://www.youtube.com/watch?v=8Vu7GTFcZjU
  2. #27
    Canastota, NY
    2010 Z4 6M, 2013 320xi
    Does anyone know where I can get this part? Is it interchangeable with 36106853736?
    I have a 2013 320xi. Thanks.
  3. #28
    Canastota, NY
    Update. I found the part 36106853736 used on eBay (about $80). I just installed it and it worked. It was very simple. As soon as I plugged it in the system was ready to go. It just needed to be reset and I drove around for a minute and everything went green and I was good to go. No calibration or dealer input needed. Thank you to the forum for having the information available to make this repair.
  4. #29
    Nov 2017
    FRANCE
    BMW F30 318d
    I never find it and BMW said me it was under rear passenger seat....
    Envoyé de mon ONEPLUS A6003 en utilisant Tapatalk
  5. #30
    Jul 2004
    Houston, TX
    36 Cylinders
    Just answering for those who don't know, after March 2014, the tire pressure monitoring system antenna/module is integrated in the DSC MK100 module. So you will not find it by the fuel tank.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  6. #31
    Dec 2011
    Maynard, MA
    2004 BMW 325xi
    Cool Thanks for the pictures
    Quote Originally Posted by aspartakus View Post
    Wonderful ! You're amazing and very kind to give me this pictures ! Thank you !
    I see now. It's enough hidden. I will raise the right rear these days to grab rdc control unit.
    We keep in touch.
    Benoit.
    Envoyé de mon SM-G930F en utilisant Tapatalk
    The pictures helping locate the RDC receiver were very helpful. Thank you! The fact the dealer tried to say all this programming was necessary is such B.S. They pull that on most components. Never heard a clear explanation what "reprogramming" means (and I'm a programmer) -- my sense is its not much more than clearing the fault code thru OBD. I'll find out - I'm replacing the part as soon as Amazon delivers an OEM replacement, incidentally, for well under $300.
  7. #32
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by rockfish52 View Post
    No, most components DO require reprogramming (flashing of firmware for that specific car, and coding). RDC module does not need reprogramming of any sort though. It is one of the only modules on F30 chassis that doesn't require it.
    -Abel
  8. #33
    Dec 2011
    Maynard, MA
    2004 BMW 325xi
    Smile RDC replacement for F30 - 2013 335i xdrive
    My 2013 F30 335i xdrive was diagnosed with a faulty RDC module @ 90000 miles. Car started issuing a TPM malfunction as seen in other posts. My tire guy checked the valve stem on each tier and determined each was sending signal; RDC just not reporting anything to main computer. Went through the forums so I could locate it but it seems BMW frequently moves the RDC. For this model its located between the rear wheels about 12" left of center. It's very accessible from underneath. After finding it, it took minutes to remove, a trip to the dealer with $300 for a new one, and a few minutes to install. Started car and it immediately worked. Despite what dealer tech said, I found no "programming" was needed (lots of mixed experience on this, too). TPMS is reporting now. Took old unit apart and found standard corrosion. Estimate from my reliable (?) non-dealer BMW repair shop was just over $500. I'm glad I did this myself.
    36FE2ABC-BC88-4C4F-8C1F-21896131BB6B.jpgAE6A7C51-E1F5-4F3F-8B84-1745CDA1CF54.jpg29C0AE10-EEA7-47B6-832F-ECE4EC0EFDA3.jpg160CF9FB-1787-4D6D-AEEC-02CA77235E64.jpg
  9. #34
    Mar 2020
    New Hampshire
    2013 328; 1984 318i
    I too had the same malfunction. Switched from my winter to summer wheel set thinking it might be a bad TPMS sensor. When that didn’t work I pulled the RDC and opened it and found corrosion and tried to clean it, but No-Go. Twice I ordered a compatible used RDC online from salvage yards that advertised the item with the same part# and software version, but both times the yard found out they no longer had the RDC. Finally ordered a new RDC with the newer superseding part number (36106855180) and newer software. Plug and play install. No programing needed. Thanks to the previous poster for his info.
  10. #35
    Jun 2020
    Chicago
    2013 BMW 335i
    Thumbs up Worked for me
    Thank you everyone for the input and pictures. The post above definitely helped me. I too have a 2013 335i (not xdrive), which had been giving me a TPM malfunction every time I started the car for the last couple months. Had the tire guy check the valve stems and confirmed they were all sending signals. I found my RDC module in the same spot (between the rear wheels, towards the front of the left wheel), and was accessible without raising anything. Was able to do the swap with the car on the ground in a matter of minutes. Pulled out the 36106853736, and ordered the 36106855180, swapped it out and voila, worked perfectly!
  11. #36
    Jun 2020
    California
    2015 x5
    you pay 1hr for diag and you pay for the install of the part. RDC does not require programming. Some modules do and programming is charged at 1hr labor.
  12. #37
    Jun 2020
    Pembroke, MA, USA
    2015 428i xdrive
    Quote Originally Posted by united777 View Post
    My first post ever. I just want to post some info here so it might be helpful for someone having the same problem as me. I have 2013 328xi. Yesterday I got a message on idrive: Tire pressure monitoring system malfunction. I stopped at the local dealership to get it checked because my local shop couldn't figure out what was wrong. Over 2 hours later service advisor informed me that RDC module is broken and it would cost $1018 to get it fixed. I refused paying that much and paid "only"$168 for the diagnostic. In the meantime I asked parts department about part price and part itself was $286+tax=$307 (part number 36106855180). I went back to the service advisor to find out why total bill is over $1k if part is only $307. He told me that it needs a lot of programming and I just can't fix it myself. I took a risk and bought the part. Module is located under the car and is attached to the fuel tank. Easily accessible and it takes 2 minutes to swap the parts. I want to report that programming is a lie and extra $500 is a joke. Everything works in order. Be aware of the unhonest dealers.
    Well Done!
  13. #38
    Sep 2012
    El Paso Del Norte, TX, US
    ‘15 F31d Msport
    thanks. A few months ago when it got warm mine started getting flaky and dropping out for 20-30 minutes. When it does it it comes back eventually and then will be fine for weeks, then it will randomly do it a couple times more That day and be fine for another couple months.
    If I were to give my Touring a first name, I'd probably name it "Alan".
    Mostly because I like puns.
    Mutual Admiration Society #5
  14. #39
    Jul 2020
    United States
    BMW
    I had a warning on my iDrive, Tyre Pressure Monitor (RDC) failure. I was not sure if it was a sensor in a wheel or the actual unit itself. I checked tire pressure in all four tires and their sensors manually and replaced them one by one, but it didn’t work. I then tried resetting the tire pressure monitoring system (RDC) and it worked. I didn’t have to replace any sensor. If you face the same issue, don’t buy the RDC module before resetting it. I suggest reading this blog they provide complete information about fixing tire pressure monitoring system (RDC). Here is the link https://xenons4u.co.uk/blog/bmw-tire...ure-explained/
  15. #40
    Jan 2020
    Phoenix
    2007 e60 n52
    under the spare tire in 07 e60
    Hi ! Cool for you
    For my part, I didn't resolve my issue.
    First, because I didn't find the rdc module under the gas tank. I think the locations change between BMW models.
    Second, the RDC failure happens only after few miles, only with long journey.
    For example, did you find correctly the module under the gas tank ?!
  1. TPM Malfunction/TPM/RDC control Unit replacement
    By Jroe02 in forum 2004-2010 (E60,E61)
    Last Post: 11-22-2016, 08:27 AM
  2. TPM Malfunction-RDC/TPM control unit replacement
    By Jroe02 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-02-2014, 06:01 PM
  3. TPM Malfunction-RDC/TPM control unit replacement
    By Jroe02 in forum Forum Software Questions & Suggestions
    Last Post: 09-30-2014, 12:05 PM
  4. transmission control module failure
    By flight12 in forum Hawaii & Other Islands
    Last Post: 04-20-2006, 02:15 AM
  5. AC digital control module failure
    By subzero32 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-14-2005, 09:25 PM
