Ive tried installing and using the PA soft on win 10 going by the win 7 x64 instructions that were put up a while ago that i found, but to now avail.
Has anyone done this on a windows 10 machine before? Im stuck on getting the drivers for the cable/dongle to install so everything works.
Please help :/
2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
2003 M3 - 210K - BMW Euro Cross Drilled Rotors
I have PA Soft 1.4 running on Windows 8.1 x64, so it will work with Win10. Yes the install was a little troublesome, but it will work.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
What's the trick? I've tried everything i can think of....no matter what i try i can't get it to load the driver for the dongle.
You have to disable driver signing, which on Win8 and 10 is slightly more complicated.
http://www.howtogeek.com/167723/how-...igned-drivers/
I had to do this on my Surface Pro tablet, but I had huge additional headaches because in that procedure it didn't load USB or touchscreen so I couldn't push 'F7' key. There is a difficult workaround that as well, to trick the tablet to load USB for keyboard.
-Abel
Hrmmmm....doing this on a full fledge laptop. I'll try deactivating that and see if i get any results. I changed the usb root hub driver just fine....i just can't get it to use the same driver for the dongle.
-Abel
I'll try to give this a shot. Thanks!
I'll be....it worked. Thank you good sir! I can now get some crap done
any procedure will be appreciated,thx
Uh... how did you resolve the keyboard issue? Installed the drivers and got a BSOD and my surface book rebooted and had no keyboard or mouse control. I do have touch screen. How would I go about regaining g functionality of my kB and mouse?
i ended up just updating the drivers automatically and it worked. I got the program working. Not sure how it all works out haha
