Results 1 to 17 of 17
Thread: 2007 530i, CRANK NO START
    Jan 2016
    Florida
    2007 530i
    I have a 2007 530i, My problem first started with my CAS module. My car was not recognizing the keys. Dealer changed CAS it recognizes the key now but car will not start. Cranks Strong but no start. Stealer wanted $1000,s to diagnose so I took it to my own shop and started with the basics. Fuel, air, spark. I have all three. I scanned the car with BMW WHAT APP and have no faults. I started to throw parts at it, first the battery tried to start it and just cranks. next new plugs, still no luck, cranks but no start. Coil packs are good, checked fuel pressure and pump its good, installed crank shaft position sensor still no luck. Installed eccentric shaft sensor (did not have oil in it) still no luck. Sent it to my indie who uses bmw diagnosis computer and he found no faults and is also stumped on what it could be. He said everything is communicating, all relays and fuses are good, he tried starting fluid but it just back fired. He said it smells like it is flooding so he let it dry but still no luck. The timing is good. maybe BMW updated the software and messed up something? I'm at a lost. So still with no luck or any idea what it could be I am coming on here to see if anyone has any idea what else it could be.
    Dec 2015
    Boston, MA
    2007 BMW 530xiT
    sounds like maybe the immobilizer has been activated somehow?
    how could you leave the dealership with the car if it didn't start???
    Jan 2016
    Florida
    2007 530i
    Thanks for the reply, I have had the car towed from dealer to my indy then towed back to my garage. From my understanding the car should not crank if the immobilizer has been activated?
    Apr 2012
    I am confused as I am sure you are.. you have Spark, Fuel and Air.. but it won't start?? Whats the compression on the car??
    Jan 2016
    Florida
    2007 530i
    Yes all 3, just cranks strong but no start. Possible clogged catalytic converter? or maybe bmw did not update the software for every module? Any advice is appreciated as I am lost.
    Nov 2012
    Cambridge MA
    2004 BMW 330xi
    Sounds like immobilizer activated
    Jan 2016
    Florida
    2007 530i
    It will crank if immobilizer is activated..?
    Canada
    750 F01, 850i, LR3 HSE
    Seeing that you have all required pre requisites, Spark, Fuel, Injector pulse. You should look at cam crank timing.
    Jan 2016
    Florida
    2007 530i
    Timing has been checked and it is good, today I pulled both oxygen sensors and the car finally gave me something, they were flooded with fuel, tried to start it and I finally got some combustion still no start tho. Clogged catalytic converter?
    Jan 2016
    Florida
    2007 530i
    The car finally threw some codes, any input is greatly appreciated as I am still lost
    BMW WHAT APP CODES
    (2D5C) DME digital motor electronics, internal error: Speed control
    (2A41) Valvetronic, electronic overload protection
    (2D09) Throttle
    (2A43) Valvetronic, thermal overload protection: warning threshold
    (2D1D) Accelerator pedal moduel, pedal sensor 1 voltage
    (2D1F) Accelerator pedal moduel, Signal 1
    (2A47) Heating-link Signal-path / Valvetronic eccentric shaft senso: Plausibility/ Lambada probe heating after catalyst activation
    (2A38) Valvetronic, drive: slow or open circuit
    (2CFB) Throttle valve adaptation value
    Generic code reader codes
    p1017
    p1618
    p1624
    p2120
    Canada
    Is there power to the valvetronic actuator/motor? This is powered by a 40amp fuse in E box, this fuse receives power from the power distribution box or mpm via a maxi fuse.
    Mark.
    Jan 2016
    Florida
    2007 530i
    I will check tomorrow if it has power still, if it doesn't have power could that cause the car to just crank and not start? any idea why it would throw these codes all of a sudden after 2 months of it not starting and having any codes?
    Jan 2016
    Oman
    BMW
    Have you started your BMW ???
    Jan 2016
    Olathe, Kansas
    2006 BMW 530i
    Quote Originally Posted by alsediri85 View Post
    I'd like to know too. It sounds like the same problem I'm having with my '06 530i.
    Jan 2016
    Florida
    2007 530i
    I have not started it yet, I just had time today to mess with it, I was getting these codes with Generic code reader
    p1417
    p2401
    p2419
    p1694
    I pulled the throttle actuator plug and noticed it was filled with water, blew it out with my compressor and cleared codes and they have not came back. But I still have no start just cranks. any suggestions help.
    May 2018
    bridgeport, ct
    2006 bmw 530xi
    Quote Originally Posted by samsbimmer11 View Post
    i have not started it yet, i just had time today to mess with it, i was getting these codes with generic code reader
    p1417
    p2401
    p2419
    p1694
    i pulled the throttle actuator plug and noticed it was filled with water, blew it out with my compressor and cleared codes and they have not came back. But i still have no start just cranks. Any suggestions help.
    any luck ??? I have the same issue! Bmw 530xi 2006
    2a3f
    2cf9
    2d09
    a0b2
    5f77
    May 2018
    bridgeport, ct
    2006 bmw 530xi
    Any luck starting your bmw??? Have the same issue!!!
  1. Battery problems 2007 530I
    By Ansx97 in forum 2004-2010 (E60,E61)
    Last Post: 09-18-2013, 10:26 PM
  2. 2007 530i engine overheat, recurring problem HELP
    By EZshifter in forum 2004-2010 (E60,E61)
    Last Post: 04-10-2012, 07:28 PM
  3. F/S 2007 530i Sport/Premium, LAKE FOREST, CA
    By new2beemer in forum 5 series & 6 series
    Last Post: 09-20-2010, 08:11 PM
  4. F/S 2007 530i Sport/Premium, LAKE FOREST, CA
    By new2beemer in forum California sponsored by Avus Autosport
    Last Post: 09-20-2010, 11:51 AM
  5. Series 6 Ignition control module problem maybe ?
    By kiwi635 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-06-2002, 07:07 PM
