Results 1 to 4 of 4
Thread: Comprehensive manual swap guide out there somewhere...?
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    There's dozens of mentions of manual swaps scattered all over the search function and google search, but i can't find any comprehensive step-by-step of the process.
    what i'm concerned about is if i need a specific driveshaft and diff replacement, and the exact wiring and exact coding needed
    Also, would there be significant differences between, say, a 98 2.8i and an 02 3.0i? Or would it just be a different shape bellhousing and not much else?
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The 2.8 and 3.0 transmissions are the same. The rest of it depends on which car you are dealing with.
    /.randy
    Jul 2004
    Houston, TX
    36 Cylinders
    Ok, lets back up to the basics.
    What exact model is the car you want to convert, and what is the intended donor?
    The basic instructions for it all will come from the E36 manual swaps.
    A user here converted his Z3 3.0i coupe to manual using a complete kit I sold him. I was intending to use it for a project, but I gave up temporarily.
    My kit was from a 1997 328i with ZF manual transmission. I had the flywheel and complete clutch kit from it. All you really need is the front half-shaft of the driveshaft from the donor car. Ideally you should balance it with the rear half-shaft. Pedals and hydraulics were from E36.
    You need Z3 specific shifter linkage parts for the shifter. I intended to use a Z3M shift lever with it all.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2013
    Worcester, MA
    Ok that confirms my suspicion of most of the parts just being e36 parts, that makes things quite east and inexpensive.
    my target vehicle is (probably) a year 2002 3.0i coupe, it's a pristine example for not much money and not many miles and good service history nearby but it's autotragic.
    although since it's the m54b30, wouldn't it use e46 bits for the swap...?
    GN92489
  1. Auto to manual swap guide
    By xatlas0 in forum 1988 - 1996 (E34)
    Last Post: 02-04-2017, 08:15 AM
  2. "There are no running V8 swapped BMWs out there"
    By schwerdt1 in forum Engine Conversions
    Last Post: 08-27-2015, 12:13 PM
  3. any headgasket DIY guides out there?
    By jmott in forum 1992 - 1999 M3 (E36)
    Last Post: 05-03-2005, 12:25 PM
  4. Any comprehensive 635 repair manuals out there??
    By shotstew in forum 1976 - 1989 (E24)
    Last Post: 01-28-2005, 11:29 AM
  5. Any BMW 330ti (318ti s50 swap) owners out there?
    By Shoe Coupe in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2004, 03:44 PM
