Results 1 to 24 of 24
Thread: Battery drain 1999 740i
    May 2014
    UK
    BMW e38 735i 1997
    I got 1999 740i with current drain which is killing my battery. Previous owner has installed a switch on the ground cable because he had the same issue, he could never fix it, and that allowed him to switch off the car after each journey. After 16min the current leakage drops to approximately 0.34A and it stay like that for hours. Ammeter was connected between ground cable and ground on the battery for a test.
    At once I have removed all Fuses in the glove box, all fuses in the box underneath the steering wheel, all fuses + 2 relays which were in the trunk where the battery is. The battery drainage did not change significantly only by 0.01A.
    Then, underneath the bonnet I have unplugged ABS/DSC module, then DME + 2 other ECUs which are located "under window" on the passenger side, in the same place underneath the ECUs I have found some relays which I have also disconnected. Then I have disconnected the phone, and then I gave up.
    Can someone tell me what else is left for me to check that is not protected with a fuse and could cause the problem?
    Rain sensor? Is alarm unit fused in the trunk? Gearbox?
    Feb 2008
    Fort Worth, TX
    2013 750li Xdrive Msport
    This is a great question...Both 740's I've had did this. I learned that it was whenever I tried to lock it with the key fob. So I stopped using it and put the key in the door everytime. I haven't had the issue since. I think it has something to do with the EWS
    May 2014
    UK
    BMW e38 735i 1997
    Do you remember how many amps did your cars drained? was it similar to my value of 0.34A? Did you do anything to try to fix it?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    If it's .34A and not .34mA, you have quite a drain.
    Edit: I would check the second info first.
    I would suggest pulling the RH seat, drivers seat for you, passenger in US. You will find this:
    F107, X13030
    inside RH frame side member
    F107 Fuse F107
    X13030 Cable shoe Output, fuse F107
    That is fed from the Fuse 100
    F100, X819
    in rear RH side of luggage compartment
    F100 Fuse F100
    X819 Cable shoe B+ supply fuse carrier, luggage compartment
    These are fuses 100 to 106. If it drops by removing Fuse 100, I would then move on to the fuse block under the seat. Each of these lead to a large group of blade fuses.
    May 2014
    UK
    BMW e38 735i 1997
    I didnt know that there are more fuses in the car, I only knew about the fuses with "pretty colours", how many is there?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Those should be the only ones you had not checked. The ones under the seat are often a victim to water from sunroof drains leaking.
    It should look like this:
    May 2014
    UK
    BMW e38 735i 1997
    If those fail, are there any replacement fuses available? Is it under the carpet?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Don't forget the alternator - that is often the source of large drains - you would need to remove the B+ cable - but this must be done with the battery disconnected, just too dangerous to do it live. Also - something I came across recently was a method that BMW use to trace current drain WTHOUT removing the fuses:
    http://www.meeknet.co.uk//E64/Fuse%2...20Readings.pdf
    My BMW Repair YouTube Channel
    Kansas City, MO
    2x01 750, 01 740
    That is very neat, thanks!
    Replacement fuses should be basically free since there are tons on any parts car. But usually the wiring/connectors not the fuses that go bad.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
    May 2014
    UK
    BMW e38 735i 1997
    I found the problem. It seems like F103 is draining power. 4th from the left side...
    What is it?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    The ones in the truck of below the seat?
    May 2014
    UK
    BMW e38 735i 1997
    Luggage compartment
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Fuse 103 shows it's only used in diesel engines. If that's what you have, it shows it feeding the DDE relay, maybe even two depending on which set up you have.
    K2003, X2085
    rear RH side of engine compartment in electronics box
    K2003 DDE relay
    X2085 Component connector (9-pin, Black), DDE relay
    May 2014
    UK
    BMW e38 735i 1997
    I dont have diesel... the title and then first post is saying that.
    It's a picture from e39, but it's the same in my e38... On this picture is listed as F102 and it is wired in my car, showed on the picture.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    All I can find is going back to the '98 model and it's for the trailer module for RHD cars. It's used for the same thing on the '99 E39's. Could be the WDS is wrong. Wouldn't be the first time.
    A6, X609
    in RH side of luggage compartment
    A6 Trailer module (AHM)
    X609 Component connector (15-pin, Black), Trailer module (AHM)
    May 2014
    UK
    BMW e38 735i 1997
    Any other ideas? So what is the fuse number that I have highlighted on the picture above... Is it 102 or 103?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    The fuse you have the highlighted line going to is 103. All I found is in Post #15 above.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I think the counting of the fuses is extremely confusing - possibly the PO take a picture of his car! I think the fuse is 102 - which connects to a number of smaller fuses in the rear fuse box next to the battery. And of those, I reckon the one that connects to the alarm siren is the most likely - the fuses are:
    Fuse 55 = General Module
    Fuse 56 = Alarm Siren
    Fuse 57 = Fuel Pump Relay
    Fuse 58 = Rear lock, Tilt Sensor, Rear Mirror, Interior Protection Control
    Fuse 59 = Rear Defogger Relay
    Try measuring the current across those
    May 2014
    UK
    BMW e38 735i 1997
    After removing them nothing happened, the current stays the same 0.33A.
    When I disconnected the F103, F102... I dont know it's name... the car starts normal, and I could actually not find anything wrong with the car inside or outside... everything seems to be working fine.
    Although I want to find the problem and fix it.
    Timm... Could it be a fuse F103 not 102?
    When I followed the cable from the fuse... it goes towards a rear seat, where it disappears from my vision.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Take a picture - it will life a lot easier!
    May 2014
    UK
    BMW e38 735i 1997
    I need to take the front seat out. The cable from the fuse goes somewhere to the front of the car together with two very thick cables. They run next to the door but on the floor, underneath carpet.
    Dec 2015
    Eagle Pass, Texas
    1999 BMW 740IL
    Quote Originally Posted by xlr8tin View Post
    I tried the same thing and it helped me out. What would be the problem?
    May 2014
    UK
    BMW e38 735i 1997
    BTW... since noone knew what is the point of that cable, and because the cable disappears in the thick cable loom under the driver seat... I have simply removed the fuse. Everything works as usual. I still wonder what the cable is for.
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Wild ride here. Curious what this is after reading. I've seen Nav Units be the culprit as well.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
  1. 2001 740I BMW Battery drain caused by MK3 Navigation Unit.
    By mmihailov in forum 1995 - 2001 (E38)
    Last Post: 09-04-2019, 10:08 PM
  2. BMW 523iA 1999 - Battery drain
    By Levin1966 in forum E39 Touring / Wagon
    Last Post: 02-26-2013, 04:48 AM
  3. 1999 740il Battery Drain Need Some Help
    By E38740iMD in forum 1995 - 2001 (E38)
    Last Post: 11-06-2012, 12:34 AM
  4. 1999 740i wheel fitment
    By kamash in forum 1995 - 2001 (E38)
    Last Post: 09-02-2003, 05:55 PM
  5. Battery drained! Could DDE be doing it?
    By HWangM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2003, 01:58 PM
