Results 1 to 10 of 10
Thread: Clicking noise when turning steering wheel [video]
    Dec 2015
    New Haven, CT
    2000 540i/6
    I've recently started noticing a clicking sound when I turn the steering wheel from lock to lock. This tends to happen more when the car is cold and gets better when the car warms up. Here's a video showing the sound:
    http://youtu.be/QlgBP9BgPcg
    I checked the power steering fluid reservoir and it seems fine...any idea what it could be and how serious an issue it is? Handling while driving seems unaffected.
    Dec 2014
    Los Gatos, California.
    2002 BMW 540i
    Mine makes a similar noise and I have narrowed it down to being the brakes moving around slightly. You can easily test this by turning with the brake pedal depressed, then again without using any brakes at all to see if the noise goes away.
    Its quite annoying and I have tried a lot of brake pad grease but it persists...I hope its as simple for you. Good luck!
    Dec 2015
    New Haven, CT
    2000 540i/6
    Quote Originally Posted by shwy View Post
    I tried this and it's definitely not it. It also happens while the car is moving and I'm taking a turn. After driving around some more over the last week I've noticed that the noise only happens when it's cold out (outside temp below ~35 F). When it's warmer the wheel turns with no noise whatsoever, regardless of how long the car's been running. Any other ideas?
    Dec 2017
    Brooklyn
    2003 530i
    Hey guys, I have similar problem to the above, here is the video:
    https://youtu.be/lYjDYc2YA74
    I can hear this only at warm, dry weather after car was running for about 1 hour minimum. Might assume this problem has something to do with lubricant? Power steering is full, sway bar links and sway bar bushings were replaced recently as well as front brakes... If someone has idea please share. Thank you in advance!
    San Jose, CA
    1997 BMW 540i 6 speed
    Possible failure of the clock spring. It connects the steering wheel buttons to the car.
    Feb 2018
    Wroclaw, Poland
    1999 BMW E39 535i
    Quote Originally Posted by ohlongjohnson View Post
    I had the same issue, my power steering fluid was brown, almost black (maybe still from the factory :-)) I've flushed the system with new power steering fluid (ATFIII in that case) and so far so good. Try it it's a cheap fix, might help and won't do harm.
    Dec 2017
    Brooklyn
    2003 530i
    Quote Originally Posted by edjack View Post
    Yeah, i thought so, but after investigation, figured out that this is not from clock spring, this comes from suspension.
    Quote Originally Posted by adamkas View Post
    I did it about 8 month ago, while replacing reservoir with hoses.
    Guys, do you have any other thoughts?
    Jan 2017
    CT
    2011 750Lix M sport
    I had a similar issue. Took it to my indy and he discovered it was due to the spring not being properly seated on the strut base. Perhaps the spring mount bushing has been dislodged from the strut itself. Have someone turn your wheel while you are outside of the vehicle with your ear by the front wheel. (Obviously not while the car is moving). Worth a shot...hope that helps.
    Dec 2017
    Brooklyn
    2003 530i
    if someone needs, problem solved, in my case it was drivers side tie rod...
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Yeah, that sounds very much like a bad ball joint somewhere. Take it to an alignment shop, and when they put it on the alignment rack and move the steering wheel, another tech under the car should easily be able to feel or even see where that clunk is coming from.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  1. Replies: 2
    Last Post: 09-23-2014, 10:12 AM
  2. Creaking noise when turning steering wheel.
    By likedatyalll in forum 1995 - 2001 (E38)
    Last Post: 06-20-2014, 01:02 PM
  3. Scratching noise when turning steering wheel
    By Chapel in forum 1991 - 1999 (E36)
    Last Post: 11-05-2012, 08:00 PM
  4. Weird noise when turning steering wheel
    By jlamb51 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-29-2012, 03:30 PM
  5. Strange noise when turning steering wheel - Video
    By FredRC in forum 1996 - 2003 (E39)
    Last Post: 10-24-2011, 10:01 PM
