98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
276/760 ... :d
How thick was the shim for the vanos on that schrick, or it's not needed?
Lmao
He is slowly building a Brayton cycle engine.
Sent from my GTX3582R
sorry boys, been sniffing too much brake cleaner over the past few nights lol
Thanks for the invite.
Those cams look yummy..are you planning to time em off the blocks?
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Holy crap, tight fit lol. Is that the same AR manifold you had? I guess bigger turbo means even less clearance if so lol.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
I have to get a move on lol, can I use your ring gapper?
Yes, same AR manifold and the same housing. I have to fit a blanket between the housing and the valve cover. I had one on there before but its a super tight fit.
sure can, let me know
Alot of long nights after my kids go to bed lol
Too add insult he didn't even need to swap motors, his old one was fine! Lol
Most of us blow our shit up and take forever to fix it. He's just like" well I want more compression and power, let me build another motor and swap it in with a bigger turbo in a week."
Ballin
Lol he really wanted an excuse to put in the built trans.
I didn't get a chance to polish my new 6-speed, the last one was polished and clear coated
When I mocked up that manifold in my car I planned on running a T4 flange as a spacer and drill and tap it for EGT and pressure
Sent from my SM-T707V using Tapatalk
yes, the spacer is good to move the housing away from the valve cover but then it hits the front of the strut tower...
Started sorting some wiring out, over the years after adding more electronics (ie BC, WBO2, E85 Analyzer, Gauges) the wiring was getting alittle sloppy (yes I said sloppy lol) so I rewired everything to a central fuse block. Seperate main power supply with replays etc. Much better now. Next is going to get a good ground.
Progress!
It's all about how badly you want to get the heat away from the valve cover. IMO I wanted it further away. Thus I was willing to provide some clearance on the strut tower with some massaging with a BFH and cover it with reflect a gold to gain the space from the valve cover.
Sent from my SM-G935V using Tapatalk
