Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Lets talk axle tech. Pics, info, expereinces, etc
  1. #26
    Vancouver, B.C., Canada
    '97 M3
    no way will you get it in.
    That's what she said
    Sent from my GTX3582R
  2. #27
    Nov 2011
    Hamburg, Germany
    e30 m30 hx50
    Hi,
    Sorry that I write into this old thread, but I didn't want to start a new one. I want to convert to 3,2l m3 axles and have the opportunity to get the needed m3 3,2l trailing arms, but unfortunately there are no axles in it. The part number of the trailing arms are 2227991. But i can't find this part number on realoem or other etks. So the only way to figure out whether these trailing arms are the correct ones, is to measure the inner diameter of the hub spline. The seller measured approximately 31 to 32mm (his caliper is broken he Sais). Could someone provide me the outer diameter from the m3 axle splines? I've been searching a long time but i can't find that info. Or maybe someone can at least tell me the spline diameter from non m e36 axles?
    Thanks alot
    Regards
    Özy
  1. Anyone have good pics of Recaros, etc in e36?
    By Erik@EDGE in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-07-2002, 09:40 PM
  2. SSR comps, pros/cons/pics/info etc....all needed
    By Krivit in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-19-2001, 05:16 PM
  3. Lets talk automatic... help me out.
    By Black Majik in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-13-2001, 12:14 PM
