So there's no damage to the spline hub of the clutch disc?
It was actually rubbing the pressure plate frame and that isn't used for anything else, so we should be good. All else looks perfect.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Great news. Should be okay to reuse the SMG piece. Do guide tubes go bad otherwise?
Wonderful news!
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
I was just going to ask about the fingers/levers on the pressure plate but if it wasn't rubbing on that then I guess you didn't encounter any serious damage.
Anyways, glad you guys found the problem.
Damn! Wish I could be there right now ....
-Paul
Sucks to see the part that screwed you, but at least you found the issue with no permanent damage.
Looking forward to the burnouts this week!
A one wheel burnout though ....
Great speed getting that tranny off! Congrats on finding the issue. One legged burnout vid please!
1995 BMW M3 5 Speed Coupe, 3.0 S50B30, Cosmos Black/Hellgrau Vader, Shrick Camshafts, New Vanos
Dinan Cold Air Intake, Ireland Engineering Front and Rear Strut Bar, Turner Motorsport Chip, EWS Delete
BBS RC 303 Genuine, 24 lb Injectors, Tuned for 93 Octane, StopTech Rotors, Bilstein Shocks, H&R Race Springs
Continental DWS 06, Eibach Front and Rear Sway Bars, Turner Motorsport Rear Camber Arms, TM RTABs.
So, the starter got the best of us for a bit and in the process made me hit my lip with a large pry bar, but we eventually prevailed and got it installed after cutting the dowel off entirely. We did a test start and the car ran beautifully and shifted great. The clutch engagement was normal. The engine sounds pretty amazing with no exhaust. Now, while I'm at urgent care possibly getting some stitches on my lip, Brian and Asim are getting the driveshaft, exhaust and cabin air boxes reinstalled so when I get back it should be ready to go.
-Paul
sorry to hear about the lip. rub some dirt and/or beer on it and get back to work!
-Paul
Nioce
E90 335i
On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
E39 540i (SOLD)
6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC Racingcoilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
E90 335i
E39 540i (SOLD)
Wow, now you're blessing it with blood! Hope you heal up fast!
2003 DINAN 5 | M54B30 | Titanium Gray Metallic | Stage 3 Engine Software | High Flow Throttle Body | Cold Air Intake | Free Flow Exhaust | Performance Automatic Transmission Software | Front Strut Brace | OE 18x9 BBS RS745 Style 42 on 265/35-18 MY BUILD THREAD: [Click]
Zipped it up and drove it just now. Feels great! Needs a blower though.
2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
-Paul
E90 335i
E39 540i (SOLD)
-Paul
Huh odd. Well as long as it works I guess it doesn't matter. Maybe the M3 starter has a larger hole for the dowel or something
Good thing you didn't lose any teeth in the process... your lip will heal after a week or two, but that transmission should give you months of fun driving Congrats on getting everything sorted out, what a rollercoaster of a ride it was.
1995 525i 5-speed - Thread
-Paul
