-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Subscribed!
1995 BMW M3 5 Speed Coupe, 3.0 S50B30, Cosmos Black/Hellgrau Vader, Shrick Camshafts, New Vanos
Dinan Cold Air Intake, Ireland Engineering Front and Rear Strut Bar, Turner Motorsport Chip, EWS Delete
BBS RC 303 Genuine, 24 lb Injectors, Tuned for 93 Octane, StopTech Rotors, Bilstein Shocks, H&R Race Springs
Continental DWS 06, Eibach Front and Rear Sway Bars, Turner Motorsport Rear Camber Arms, TM RTABs.
Will offer free labor for free labor. Oh wait...
2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
-Paul
So, I received my flywheel today, only there was one major problem... it's the wrong one. In my research, I had originally though I would need the 330Ci 6-speed flywheel since it was mated to a M54, but after discussing it with TerraPhantm, he said that unlike the S62/M62 that use the flywheel for crankshaft timing, the S54/M54 both have a crank sensor over the actual crank on the engine, so the flywheel teeth are really just for the starter. Anyways, the point is, I needed the M3 flywheel to mate with the M3 clutch kit for the M3 transmission. The problem is, while looking for the flywheel on Rock Auto's website (on 3 different computers BTW since I was either at work, in my home office or in the living room), I must have had the wrong one in my shopping cart when I placed the order and ended up with the 330Ci flywheel. I put in a return request this evening and was able to get it dropped off at FedEx before their last Ground pickup for the night/weekend and placed an order for the correct M3 flywheel. Unfortunately, it says it won't be shipped until Monday. Not that big of a deal since I won't be doing the swap until the first weekend in February anyways, but I like to have all the parts in hand before I do final measuring and mocking up at Brian's next weekend. We'll be doing an oil pan gasket replacement, some power steering hoses and reservoir replacement, S54 oil pan mockup to see where it would need to be cut, and some measuring to make sure all the 6-speed stuff will fit and work together. We'll also be swapping the output flange on the M3 transmission with the one from my cracked 540i transmission and making sure that works properly. After we have all the measurements done and feel confident that it'll work (at least as much as we can be), we'll pull the bellhousing off to send as a core to Kaiv on m3forum.net who is providing the pre-modified 6MT bellhousing for me. If he is able to get it shipped out to me and delivered before next weekend, I'll go ahead and mount it on the transmission while I'm there as well. I should also have all the parts I've ordered from Morristown and Clemster by then as well, so we can get started installing the pedal cluster and a few other things that will make the swap go smoother on swap weekend. The only things I'll really be able to get done early are the pedals, hydraulic lines, CSB and Guibo on the driveshaft. The rest will have to wait until swap weekend.
-Paul
suscribe
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
So maybe I'll get to wrench on your car at Redshifts garage next weekend.
-Paul
I'm picking up my 5 swap kit soon as well. Not the same car but worth the follow. I'll probably end up with the e60 545 linkage
Modification Thread"The E46 is expensive like a high maintenance girlfriend. She may be hot, but how many more damn times does she need to shop at Tiffany's"Instagram: @CarbonZHP
-Paul
Subscribed. I have the intention of putting the ESS twin screw in my car later this year or early next. We have the exact same cars so this will be very helpful if I decide to replace the transmission first or wait until after the TS is installed.
-Paul
Need a DME or EGS update?
https://forum.e46fanatics.com/showthread.php?t=1081716
Coding 530i after AT->MT Swap
https://www.bimmerforums.com/forum/s...ter-AT-MT-Swap
-Paul
-Paul
Ed Zachary! Several people have gone down the road of taking a 420g from a V8 E39 only to run into those issues and give up. Case in point:
http://www.e46fanatics.com/forum/sho....php?t=1046393
It's so much easier to just patiently do the homework up front and put together the right drivetrain parts combination, like is being done on this thread.
Believe me, I considered that option from the e46fanatics thread. I have a 540i 420g that has a crack in the tail housing that I was going to try to get a tailshaft housing and 6MT bellhousing for and use for this project originally, but I saw only failure in other people's experiments, so I figured I would need to just bite the bullet and do a M3 6MT and then I figured I could swap my output flange from the cracked 540i transmission to allow me to use an all 540i or M5 drivetrain behind the transmission.
-Paul
I know we already had Christmas, but here it is again!
-Paul
All these parts came from Morristown BMW. Thanks so much Colin for giving me such a great deal! I hope he's able to make it down for the swap weekend.
-Paul
-Paul
-Paul
Got to Brian's pretty early in the afternoon today and got an early start on the oil pan gasket replacement. We got the oil pan out in about 3 hours or so including prep time for getting the engine supported by the frame. Most of the oil pan bolts are easy to get to, but there are several that require moving the auto transmission cooler lines, which of course would have been easier to do when doing the manual swap, but it wasn't too bad. After getting the pan off, we cleaned the mating surface as best we could and then moved to degreasing the pan. That was a bit of a miserable experience as I am a little sick, it was raining outside and it was really dark, but I got it pretty clean and it's now drying for the night and we'll get it reinstalled in the morning.
That's the majority of the work we had hoped to get done this weekend, so far so good.
-Paul
