So I finally got around to it. I started just before Christmas. Had my money all lined up to do a complete fuel system rebuild. I pulled off the injectors (bought new this past summer), WUR (new rebuilt from a year ago),and the fuel distributor and sent them off to CIS flowtech for rebuild.I went ahead and dropped both fuel tanks and sent those off to the radiator shop for cleaning, relining and painting. I hit Bavarian auto sport and bough the in tank lift pump, new fuel filter. That lift pump must be made with solid gold bushings to cost $400! So my tanks are back looking all spiffy and this past weekend I put them all back up under the car. All new vapor line rubber, hose between tank halves and the filler tube and tank, and new clamps, orings, etc. Now I'm just waiting to hear back from Flowtech CIS. Impatiently I might add. After the rebuild of the WUR and distributor this fuel system is new or rebuilt from ship to stern including both fuel pumps, accumulator, check valve, etc. I am hoping this will restore some power, improve my fuel economy, and fix the idle issues I have been having. This car sat up in a barn from 1996 to 2014. When I talked to the tank guys they said they cleaned about an eighth of an inch of shellac and crud of the bottoms of the tank. I am guessing this means the fuel distributor was in a bad way as well. Has anybody else here dealt with Flowtech CIS? Does anybody know what their turnaround times are? I can;t get them to call me back to save my life and every time I call them they tell me they will call me back in a few minutes but then don't. My wife is about to drive me crazy wanting to know when I will get it back on the road so she can get her car back. ( ) Any expereinces with CIS flowtech out there?
probably should just buy your wife a new car.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Is that the one in Alabama?
If so, a quick search reveals folks raving about how good they are/were
$400.00 lift pump?
Tbd
Did you get quotes from FlowTech on the cost of rebuilding your WUR and FD? Please give us a review once your parts get back. John
Yeah the in tank pump. I call it a lift pump because it functions a lot like a lift pump on a diesel engine. Basicly just pulls fuel while the fuel pump actually builds the pressure for the injection system. On a diesel the lift pump just gets it form the tank to the injection pump. Yeah I already got the wife a car! I'm driving it now which is why shes a bit cranky! My normal car I would drive otherwise is a 2004 Toyota Matrix however the 5 speed manual tranny just blew the differential bearings and I need to replace that now. (Not enough hours or money in a day lol) I'll let you guys know how it turns out. I hear the guy has all the Bosch equipment, can get parts for the distributors that are unobtainable otherwise, and that Bosch actually sends their Automotive tradition stuff to him for rebuild. When I called and got voicemail the lady in the message sounded german. It was a bit strange. lol
Hey you know those in-tank pumps are available on Amazon for like $118
1982 320i E21 Coupe, Manual, Cashmere Metallic, 162K+ miles (Daily Driver)
1997 318i E36 Sedan, Manual, Black, 388K+ miles (RIP)
from just a couple weeks ago: http://www.amazon.com/gp/product/B00...iglink20399-20
The picture is incorrect, this is what it looks like
Works just as well with Lifetime warranty, $115 plus, I installed the above Airtex in tank fuel pump, when I installed a new Main Fuel Pump 1 1/2 yrs ago, also dropped in new Fuel accumulator as old one was gone with the wind, everything works well.
CISFlowtech is run by Larry, he has a very good reputation, I have talked to him.
I got my Warm Up regulator rebuilt by Bob(owner) at Fuel injection Corporation, 18 Mo warranty all new parts. Bob rebuilds Bosch ECUs for 80-83 BMW e21, his employee diagnosis mine and reset fixed it, His wife K(C)athy answers the phone,Tracy, Ca, Bob has a very good reputation as well. I also tested the CIS system and checked the specifications of the WUR and Fuel Pump Pressure,ect,all good in specifications.
So Bob rebuilds fuel pumps,Fuel Distributors, ECU's and WUR for our cars,,Happy New Years to you and yours...
https://www.fuelinjectioncorp.com/
Phone: 925-371-6551
Yes 77-79 E21 owners FIC can rebuild your WUR,FD,and Fuel Pump too with new parts and bench test them thru a machine for fuel flow and make adjustments to get into specifications .
Larry at CISFlowtech rebuilds FD's and WURs
http://www.cisflowtech.com/
(251) 929.3771
Randy
well I had an issue with the fist pump I bought and looked like ^. Then they sent a replacement that looked like the sale photo. Same part number so idk why I got one of each design.
Airtex makes 2 models of the same in tank fuel pump, would be my 2 cents. One that looks like the original VDO(siemens) and one Airtex made on its own.
lol
Randy
Hey it work and that is all I ask of it
Well the one I had WAS still working. But the screen part was attached to case a part that fell off the bottom. Then the pump wheel fell out. I had pondered gluing it back together but I could not find the little plastic pump impeller. I had already glued it back together once. I did talk to Larry this AM. The distributor had been rebuilt. he said it had been gunked up in varnish pretty bad and a note had been attached to tell me to check my tanks for varnish! (The radiator shop cleaned out a TON of it!) He said he will b calibrating it this week and also rebuilding my WUR and calibrating it. Looks like I should get it back next week if all goes well. I wish I had seen the $115 in tank pump! Although I am hoping this one made by VDO will last almost 30 years like the original. I also got a NOS Bosch ignition module, Thermo time switch, and a brand new fuel pump relay that showed up today. I'm hoping she will run like a million bucks after this!
