It would suck if the engine didn't start because you lost the coil grounds. Not saying it would be a problem, but I would remove the paint were the coils sit on the VC.
Nice build, looking forward to another 95 m3 on boost.
WOT
I saw you said you removed the timing chain cover before taking the short block to the machine shop. That cover needs to be attached to the short block if they deck the surface. The headgasket also seals that area.
Another 21 year old buys perfect 1995 M3 to thrash it. No wonder why E36 M3 is going up in price. 3 inch inlet intercooler? Wow, lag will be eternal
Lookin good so far! I wouldn't worry about lag BTW. I'm running the same manifold/turbo combo with 3" IC and charge pipe and it spools just fine! Comes on at about 3500 rpm. I'm interested in seeing how your manifold handles creep though. I have a really unbalanced setup lol I'm using an adapter to run a 38mm 2 bolt WG with a 5lb spring. Big turbo + little wastegate = mega creep. My build is super janky to say the least, but it's got character! Put your manifold on a belt sander BTW. My flanges weren't perfectly flat out of the box.
Feel free to judge me off my age all ya want, but i baby my cars for what they are. I'm not the typical young guy wanting crazy power to go do burnouts and bounce the limiter everywhere. I like to do builds as its my passion and I overbuild to handle way more than I throw at them. If you don't respect my build based off my age I feel sorry for you. I based the 3 inch inlet off of the fact that I'm running a trm blow through maf that requires a 3 inch charge pipe and it's easier to have 3 inch on both hot and cold side as its a universal intercooler kit. I've seen plenty of people with similar specs for turbo and intercooler setup and they seem to spool just fine.
Yeah I've been reading about the creep issues with this manifold. I have a 44mm so that might help a little, but I'll also use a 45 degree external pipe vs the 90 degree, heard that helps as well. Anyways I'll play it by ear and see how bad it creeps and go from there! Thanks for reassuring me with the lag, I didn't think it would be bad as I've seen lots of people run pretty similar setup. Plus my last car spooled at about 4K so this should be even better!
Okay I'll definitely check out the flanges before install
You zero balance the flywheel then you balance with the pressure plate (adjustments to the PP) that way it doesn't matter if you change your clutch. Sent from my GTX3582R
Picked up the short block today and I gotta say it looks awesome, sure got me excited to keep moving forward! Just have to go rent the pilot bearing removal tool tomorrow morning and pick up a front main seal from BMW then I'll be able to make some more progress. Until then here's a pic of the block!
Awesome build!
May I ask which machine shop did you use for all your machining?
Fast lookin' but slow movin'
237 rwhp N/A power
Thank you! I got it done at pacific auto machine down in Renton. I chose them based off of there was a couple people on the here that said they "bring all their motors here because they know it'll be done right", and after talking to the owner with knowing he'd been doing it for decades I felt pretty comfortable that knowing it would be done right.
How much did it cost you to do the bottom end, if you don't mind me asking? I'm pricing out what I need to save up for rods, pistons, bearings and machine work. I'll do the assembly myself.
Nice build so far. Always nice to see quality work and attention to detail. You can make your own pilot bearing removal tool with a piece of bar stock and a 3/8" bolt and nut. Any bolt will do as long as the hex head is just a tiny bit smaller than the center hole of the pilot bearing. Drill a hole in the bar stock. Put the bolt through it and attach the nut. Slide the hex head through the hole of the pilot bearing and slide it to one side so the lip of the head grabs the pilot bearing. Tighten the nut and pull out the bearing.
I didn't have any bar stock
A bit of inspiration for you after I saw that valve cover
You could just use a grease gun to fill the void behind the pilot bearing, then tap the clutch alignment tool in to drive out the bearing.
S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
97 BMW M3 | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
I used bread to get mine out. Easy, simple and zero mess.
WOT
I like the bread trick.
I've seen the grease trick. What's the bread trick?
