Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 98
Thread: The Weedspeed M1 Pro Car Replica [+Bonus E36 M3]
  1. #51
    Apr 2014
    Stockholm, Stockholm
    Weedspeed Mark II
    Not really any progress yet I'm afraid. We've spent the last couple of weekends working on the house project rather than the car.
  2. #52
    May 2014
    Sweden
    330 compact AWD turbo
    As my brother mentioned, not much progress yet.
    One thing that has changed is the m3, it's been sold and replaced with another m3e36 that has an M50b25 engine with turbo. It's silver and delivers 600hp/800nm and has a best et of 10.04/224kmh.
    Got tired of the brilliant but slow red N/A e36, 321hp just isn't enough when you are used to 600+ hp
    Regarding the M1, our body is in the making and is scheduled to arrive in Sweden sometime in February/March
  3. #53
    Mar 2014
    Concord, CA
    1996 328i vert
    I'm confused, someone swapped the m50b30 m3 engine single Vanos for an m50b25 non Vanos? How is this an m3? Nice power though.
  4. #54
    Quote Originally Posted by Pyropete82 View Post
    No M3's had an M50 (M50B30 also does not exist), sounds like previous owner swapped out the S50 in exchange for a turbo M50
    Pictures arent loading for me though
  5. #55
    Mar 2014
    Concord, CA
    1996 328i vert
    Quote Originally Posted by BimmerBreaker View Post
    Thank you for the "s"correction my bad
  6. #56
    May 2014
    Sweden
    Its an Euro M3 with S50b32 from the beginning, bought without engine and now features a m50b25
    The body and chassis of the euro M3s differs quite a bit from the regular e36s.
    Edit: imgur har apparently blocked bimmerforums, fixing it as we speak!
  7. #57
    Apr 2014
    Weedspeed Mark II
    Pics of the new E36.
  8. #58
    H-Town/Los Angeles USA
    bmw e36 328i 4dr saloon
    Looks badass!!
    1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
    http://mbuild.blogspot.com/
  9. #59
    May 2014
    Sweden
    Thanks, its fast as hell, 100-200 in 5,2.
    The Porsche Brakes with pfc01 makes all the difference!
  10. #60
    Iceland
    BMW 850
    More info on those brakes?
    What caliper and discs are those?
  11. #61
    Nov 2016
    uk
    m1
    Wow. Impressive to say the least.
  12. #62
    Jul 2012
    Germany
    1997 323I
    Quote Originally Posted by erikjakan View Post
    Videos would be nice.
  13. #63
    May 2014
    Sweden
    Its winter here guys, no video until spring im afraid
    The brakes are Porsche Boxster S, Caliper No: 996351425 & 996351426.
    Adpater: http://www.millway.se/adapter-brake-...mw-e36-z3.html
    Discs are m3e46 325mm euroversion, CSL also works but requires 18".
    Either shave off 12mm from caliper for 325mm disc, or 2mm for 345csl disc.
    Brakepads are PFC01
    MVH Erik Wedlund
  14. #64
    Apr 2014
    Weedspeed Mark II
    A quick little update.
    We decided to ditch the Corvette stock front subframe and went back to building our own mounting points instead.
    It turns out that the Corvette front frame is heavier, but the main reason we decided to ditch is was that it is simply too bulky in a place where we are allready struggling for space, making it hard to reach all the nuts and bolts for adjustments that we may want to put a tool to later on when the car is complete.
    So, we went ahead and got a couple of plates bent and got started on the construction of our own front beams with mounting points.
    Then we cut a beam and dot-welded em together.
    We're gonna need 2 of these though, one with the mounting points for the steering rack and one without em.
    Here is the other beam, which has been completely welded aswell as enfroced with some bits and pieces of sheet metal.
    Also got started on the same piece on the rear mounting points.
    And that's all for now
  15. #65
    Apr 2014
    Weedspeed Mark II
    New update
    So, obviously the Porsche gearbox won't fit on the S85B50 so we're going to have to make an adapter plate, among some other stuff, but let's start with the adapter plate.
    Quite a big and beefy piece of metal.
    We're also going to have to make sure that the gearbox becomes centered, or there'll be trouble. As you may remember, a couple of updates previously we slaugthered a stock gearbox so that we could get ahold of a piece of the sweep that'll now come in handy for constructing the adapter plate.
    We took that part that we cut off from the old gearbox, bolted it onto the engine and then we bolted this centering piece onto the crank.
    Then we cut a hole for the starter and attached the other part of the adapter plate onto the centering piece.
    Seems to fit quite nicely
    Off to the workbench and start marking it out for some cutting. Also had it machined a little.
    Then we reattach everything and get some welding done :9
    Once everything is welded we cut away the cross section and added some studs.
    Bonus pic of the new garage helper
    That's all for now, at least we are making progress
  16. #66
    Rigel 7
    M3, 850i, E30T, E55T
    Phenomenal stuff.
  17. #67
    Del a Where?
    LSx M3 & 2017 Touareg
    So much awesomeness
  18. #68
    TX
    97 M3/4/5, MCS
    maybe a silly question but are you blueprinting all of this? In case you wanted to reproduce another?
  19. #69
    East Europe - RO
    Boston Grün E36 M-Te
    Quote Originally Posted by MarketMaster View Post
    +1 on this.
    Whenever it is that I will have that kind of money, I would buy this!
    And I'm not into replicas or so stuff. But this is so much more!
    E36/4 Boston Grün "Class II"
    E36/4 Cosmos Schwarz "Class II"
    18" BBS RC / 18" BBS LM
  20. #70
    Dec 2016
    uk
    m1
    I was going to say you should do a straight pipe S85 v10 with ITBs and was not disappointed when I saw the intended engine.
  21. #71
    May 2014
    Sweden
    Glad you guys like it, we have blueprints on everything, also going to start making these chassis for people who want their own M1s.
    Bodys will be avaible also
  22. #72
    UT
    98 M3/4/5
    eh..... ive seen better....
    jk
    98 Estoril ///M3 4/6
    S54 swap CSL
  23. #73
    Rigel 7
    I'll just start saving up now.
  24. #74
    Silicon Valley, CA
    2003 540i - M-Sport
    Wow what a build, can't wait to see more....very impressive!
    2003 540i M-Sport - Sterling Grey/Black Leather
    GPS | PP | Rear Shades | Intravee II | Valentine 1 | 35w ProLumen HID Fog Lights w/3000k bulbs | 35% Formula One Pinnacle Series Ceramic Tint | Eisenmann Race Exhaust 2 x 83mm | Eibach Rear Sway Bar | Weichers Front Strut Tower Brace | Racing Dynamics CAI | Stealthone | Sound by Focal/JL Audio/Arc Audio
    DPE Wheels for Sale....
    http://forums.bimmerforums.com/forum...5#post26952145
  25. #75
    Apr 2014
    Weedspeed Mark II
    Gearbox successfully mounted onto the engine
    And yes, the gearbox is supposed to be upside down, else we'd have a drivetrain designed for performance reversing.
    Now we need to figure out an appropriate clutch combination.
  1. E36 Car Cover -- Noah -- E36 M3 Coupe NIB
    By Johno in forum Exterior Lighting & Body Parts
    Last Post: 11-25-2010, 10:31 PM
  2. E36 WTB - Eibach Pro Kit Rear Springs E36 M3
    By E30Rookie in forum BMW Parts Wanted
    Last Post: 04-14-2010, 04:28 PM
  3. M1 Pro CAR on Ebay!
    By bigdog68 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-24-2008, 04:08 PM
  4. M1 "Pro Car"
    By BoyNamedSue in forum BMW Rides & Events
    Last Post: 10-23-2008, 03:32 AM
