Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 75 of 291
Thread: Habbit continued / Turbo build V2
  1. #51
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    So taking the manifold back off ? I've been really back and forth with the direct port. The problem is puddling. Aquamist uses a 165psi pump, so your spraying 100+ psi in a tight runner , and only 20-25psi pushing against it. The 100+ psi will be more forcefully and hit the back side of the runner and just puddle down in a stream. So, I've been weighing the options of this. Also Matt had a cracked cylinder and Eric had a blown up stuff too.
    My crack cylinder had nothing to do with direct port injection.
    Im 90% sure I know what happened and had nothing to do with meth...
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  2. #52
    Apr 2006
    Manchvegas
    Boosted M3’s
    Wow Interesting, I'm going to have to research that puddling issue. Plan is the current manifold will be pulled as the direct port will be going on another manifold I have. I've been trying to figure out just where I wanted to tap the manifold these last few days.
    She will be alive once again.
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
  3. #53
    Apr 2006
    Manchvegas
    Boosted M3’s
    Quote Originally Posted by flyfishvt View Post
    Is that running?
    Not yet, waiting on a few more parts.
    Stock motor
    build thread:
  4. #54
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Matutino View Post
    I'm sure it didn't. But,, something unknown happened. Something , unexplained. I'm probably going to do the direct port myself.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #55
    May 2003
    Irvine
    It wasn't unknown, I know what it was
    Greg, here ya you budy
  6. #56
    Apr 2006
    Manchvegas
    Boosted M3’s
    It wasn't unknown, I know what it was Greg, here ya you budy
    That's awesome, thank you !
    Stock motor
    build thread:
  7. #57
    Apr 2006
    Manchvegas
    Boosted M3’s
    Took a pic of these today as they will be on the market very soon.
    Stock motor
    build thread:
  8. #58
    South Carolina
    2004 330 vert 2004 X5
    Quote Originally Posted by Mod Addict View Post
    Sorry...I'm tapped out.
  9. #59
    South Carolina
    Very pretty. Isn't it possible to inject a lot closer to the end of the runner so there isn't any puddling ? It's only going to inject while intake valves are open so there will be lots of force pushing/pulling that mist into the cylinder.
  10. #60
    May 2003
    Irvine
    The further away from the head the better, that's what Aquamist told me.
  11. #61
    NY
    skateboard
    Those momo's look fancy
    ― George Orwell
  12. #62
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    They would look good in your car.
  13. #63
    Apr 2006
    Manchvegas
    Boosted M3’s
    Correct.
    Stock motor
    build thread:
  14. #64
    NY
    skateboard
    Correct.
    Depends on if a human of my size will fit in the properly.
    ― George Orwell
  15. #65
    Apr 2006
    Manchvegas
    Boosted M3’s
    Snow kit is done.
    Next will be zeitronix install.
    It's been fun.
    Stock motor
    build thread:
  16. #66
    South Carolina
    You're now a meth man?
  17. #67
    Manchester, N.H.
    96 332IS 6466 turbo
    He has had meth before we had turbos. I used to play with nitrous, not no more.
    1996 332IS
    Built 3.2
  18. #68
    Apr 2006
    Manchvegas
    Boosted M3’s
    Yea this snow kit is fairly simple in comparison to an Aquamist kit but it should do the job and help make more power on pump gas. Keep it simple is the new philosophy.
    Stock motor
    build thread:
  19. #69
    Manchester, N.H.
    96 332IS 6466 turbo
    I wish I could say the same, I'll be adding 6 new lines, and a bunch of other shit. Hope its worth it.
    1996 332IS
    Built 3.2
  20. #70
    NY
    skateboard
    How did you fit all of that crap behind the headlight?
    ― George Orwell
  21. #71
    Apr 2006
    Manchvegas
    Boosted M3’s
    Quote Originally Posted by GG///M3 View Post
    The pump is mounted to the inter cooler bracket so it flows from the tank down to the pump then up to the intake. The 3 qt tank fits nice because my inter cooler piping goes down by the power steering pump not over by the horns. Plenty of room. I will get a picture with the bumper off.
    Stock motor
    build thread:
  22. #72
    Apr 2006
    Manchvegas
    Boosted M3’s
    She is alive !!!'
    Stock motor
    build thread:
  23. #73
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
  24. #74
    Apr 2006
    Manchvegas
    Boosted M3’s
    Cage is in as well as a new zeitronix data log setup. Car is running flawless.. ;-)
    Stock motor
    build thread:
  25. #75
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    Nice!
    THE TIME DRAWS NEAR!
  1. M3LOLJK v2.0 turbo build 328i
    By omarmarji in forum Forced Induction
    Last Post: 01-27-2015, 05:02 PM
  2. off-season turbo build v2.0 -> input needed
    By r0taryh3ad in forum Forced Induction
    Last Post: 01-17-2015, 02:36 AM
  3. 325iS Turbo Build, v2!
    By SiGmA in forum Forced Induction
    Last Post: 04-22-2010, 03:52 PM
  4. Continued the turbo build this weekend
    By 95RedBMWe36M50 in forum Forced Induction
    Last Post: 04-14-2008, 07:00 AM
  5. my DIY turbo build up has begun...stay tune!!!
    By e36widelip in forum Forced Induction
    Last Post: 10-13-2006, 03:12 AM
