ebay?
― George Orwell
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
Good old NicG in da houze.
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Stock motor
build thread:
Ah yea you already have the secret sauce setup, nice.. The individual injectors I believe is a much more accurate setup. Another thing I started on my other car but never used it was use another Mac valve to drop boost if flow drops. I plan on running meth and MS 109 to break some personal records this year. The motor should be up to the task this time.
You square away your motor purchase ?
Stock motor
build thread:
Stock motor
build thread:
Keep the pics coming. I lost my reading glasses.
Stock motor
build thread:
Looks good Greg. The normal seats are my favorite part.
1994 325is "Christine"
"Frozen" S52 OBD1 230k, ARP Head Studs, JE Cutring/Copper, SPA T4, Garrett GT35R, Tial V44 WG, Ebay BOV, 4" Exhaust, Aeromotive FPR, Walbro 255, AA 60LB Tune, FX Racing Stage 3 Clutch, Z3M Shifter, E90 M3 Engine & Trans Mounts, H&R Sport/Bilstein, Powerflex FCABs, Powerflex Sway Bar Bushings, UUC SS Clutch/Brake hoses, Stoptech 309 Pads, 40% Diff, M3 LTW Wheels.
Stock motor
build thread:
I wonder why you didn't weld the Maf flange to the piping vs having that extra piece, that way you can eliminate those two connectors right before the elbow
Stock motor
build thread:
After this you won't ever have to work on the car again.
Stock motor
build thread:
Stock motor
build thread:
Stock motor
build thread:
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I want to get a parts car like Gregs black car.
Stock motor
build thread:
Stock motor
build thread:
Is that running?
So taking the manifold back off ? I've been really back and forth with the direct port. The problem is puddling. Aquamist uses a 165psi pump, so your spraying 100+ psi in a tight runner , and only 20-25psi pushing against it. The 100+ psi will be more forcefully and hit the back side of the runner and just puddle down in a stream. So, I've been weighing the options of this. Also Matt had a cracked cylinder and Eric had a blown up stuff too.
1996 332IS
Built 3.2
