Page 1 of 12 1234567891011 ... LastLast
Results 1 to 25 of 291
Thread: Habbit continued / Turbo build V2
    Apr 2006
    Manchvegas
    Boosted M3’s
    Well here we go again.
    Build consist of;
    Block 3.2 Ltr
    Cut ring gasket
    Stock 3.2 cams
    Cp coated Pistons
    Arrow rods
    Factory bearings
    Boost logic manifold T4
    Gt40/94r 85 T4
    AA large blow off valve
    V44 wastegate
    Plx devices
    Turbosmart eboost 2
    Obd2 Technique Tuning ecu
    80 Lb injectors
    Walbro 400 fuel pump
    Aeromotive fuel pressure regulator
    Kenne bell boost a pump
    Large case 210 diff 3:15 ratio
    Driveshaft shop driveshaft and cv axles
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, we need to hit the track much more this year. No excuses. 10s for everyone.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Apr 2014
    Manchester, NH
    1994 325is, 1993 K2500
    Not enough RTV on VC gasket.
    1994 325is "Christine"
    "Frozen" S52 OBD1 230k, ARP Head Studs, JE Cutring/Copper, SPA T4, Garrett GT35R, Tial V44 WG, Ebay BOV, 4" Exhaust, Aeromotive FPR, Walbro 255, AA 60LB Tune, FX Racing Stage 3 Clutch, Z3M Shifter, E90 M3 Engine & Trans Mounts, H&R Sport/Bilstein, Powerflex FCABs, Powerflex Sway Bar Bushings, UUC SS Clutch/Brake hoses, Stoptech 309 Pads, 40% Diff, M3 LTW Wheels.
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    So did you put this one together?
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
    Apr 2006
    Manchvegas
    Boosted M3’s
    Quote Originally Posted by Matutino View Post
    R&L engines in Dover built the lower end and I installed the bolt on parts. Motor is in the car after a hard night of work. More pictures after I get some rest lol.
    Stock motor
    build thread:
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
    Manchester, N.H.
    96 332IS 6466 turbo
    You are going to be bored all winter. Slow down and enjoy the build.
    1996 332IS
    Built 3.2
    Apr 2006
    Manchvegas
    Boosted M3’s
    Yea working on the ride has been nice and steady. Had some time to change a few things and organize the engine compartment even more than the last setup.
    Stock motor
    build thread:
    May 2003
    Irvine
    I'm getting a new engine as well and I'm debating if I should get the long block done or just the short block and I would do the rest myself.
    I would at least save in shipping.
    Apr 2006
    Manchvegas
    Boosted M3’s
    I'm getting a new engine as well and I'm debating if I should get the long block done or just the short block and I would do the rest myself. I would at least save in shipping.
    Sorry to hear about your motor.
    I'd get the short block and build the rest yourself.
    Stock motor
    build thread:
    NY
    skateboard
    Wow nice progress, and fast. If you need a hand let me know
    ― George Orwell
    May 2003
    Irvine
    Quote Originally Posted by Mod Addict View Post
    Yeah, it was unexpected to say the least.
    I'm following that route, short block and I will assemble the rest, hopefully will be up and running by the end of February
    Manchester, N.H.
    96 332IS 6466 turbo
    Will we see 130+ from you ?
    What I've seen is every 5mph seems to be a mile stone. I remember I was running 125-128 and wanted 130 so bad. Then I skipped over the 130 and went 134.96 then 135 then 137. Now I seem to want that 140 slip.
    1996 332IS
    Built 3.2
    May 2003
    Irvine
    I would hope so, making lots of changes to my current set up. I was at 125 before so 130 should be possible
    Anyone has an m50 block laying around?
    South Carolina
    2004 330 vert 2004 X5
    http://nh.craigslist.org/pts/5385799954.html
    Does this help?
    Sent from my iPad
    May 2003
    Irvine
    I would rather be from a forum member, Craigslist if not able to inspect it I rather stay away
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Should be no need to ship a lump of iron across the country. I threw away an m50 a few years ago.
    Manchester, N.H.
    96 332IS 6466 turbo
    Getting punched out anyway ? Not sure why you want obd1 block tho. Obd2 is same. But hole in the back
    1996 332IS
    Built 3.2
    May 2003
    Irvine
    OBDI or OBDII is the same, do you have one laying around?
    Manchester, N.H.
    96 332IS 6466 turbo
    Will the machinist sleeve it ? I can find one but shipping would be like $400, maybe more.
    We really don't need extra motors. We all have nick tuning and nothing every blows up. ; )
    1996 332IS
    Built 3.2
    Apr 2006
    Manchvegas
    Boosted M3’s
    I'd think you would be able to find one locally that is fairly inexpensive, no?
    Stock motor
    build thread:
    May 2003
    Irvine
    I have been looking for the last few days with no luck, I'm sure something will pop up
  1. M3LOLJK v2.0 turbo build 328i
    By omarmarji in forum Forced Induction
    Last Post: 01-27-2015, 05:02 PM
  2. off-season turbo build v2.0 -> input needed
    By r0taryh3ad in forum Forced Induction
    Last Post: 01-17-2015, 02:36 AM
  3. 325iS Turbo Build, v2!
    By SiGmA in forum Forced Induction
    Last Post: 04-22-2010, 03:52 PM
  4. Continued the turbo build this weekend
    By 95RedBMWe36M50 in forum Forced Induction
    Last Post: 04-14-2008, 07:00 AM
  5. my DIY turbo build up has begun...stay tune!!!
    By e36widelip in forum Forced Induction
    Last Post: 10-13-2006, 03:12 AM
