Bavarian Soundwerks
Results 1 to 6 of 6
Thread: BMW mk4 problem
    Dec 2015
    Latvia, Saldus
    E46 Coupe
    BMW mk4 problem
    Hi
    I upgrade my E46 with mk4 nav! I get my nav from car with mono setup, i make these steps
    Brief Instructions:
    1. Downgrade the nav to v24 OS, so we can force an upgrade later on.
    2. Make a special v28 OS disc where the ONLY change is the mono navboot file is replaced with the colour navboot file
    3. Load new v28 special disc
    Full Instructions
    1. DOWNGRADE TO V24
    Make yourself a good, unaltered, v24 OS disc.
    Force the Mk4 Mono nav to upgrade to v24...
    Insert nav in car, turn key on, let nav boot up (you cannot see anything, just wait 2 min)
    Insert v24 OS disc. Nav will load v24 software. Wait for disc to be ejected. Remove disc.
    Nav is now at v24. Turn key off, go and make a new disc...
    2. MAKE V28-SPECIAL DISC
    Get a genuine, unaltered, v28 OS image.
    Open with MagicISO or your favourite image editor
    Replace this file:
    V_2 RR 0101 BMWM01S app_sw navboot
    with this one:
    V_2 RR 0101 BMWC01S app_sw navboot
    ...so that both the BMWM01S (monochrome) and BMWC01S (colour) directories have the same (colour) navboot file (11,807,976 bytes)
    What we have done is put the colour navboot file in the monochrome directory, the mono nav will boot using the colour navboot, and switch to colour mode.
    Burn a new v28-special OS CD. Label it as 'v28 special'
    Verify that the two navboot files are identical (in the BMWC01S and BMWM01S directories)
    3. LOAD NEW V28-SPECIAL
    Go to car, turn ign on, wait for mono nav (pre-loaded with v24) to boot (2 min to be sure). Remember, you won't see anything on the monitor yet.
    Insert v28-special OS CD
    Nav will load new v28 software, when done, will eject CD.
    Remove CD and press the bordmonitor button
    Nav will re-boot. When it starts, the colour screen will come.
    Problem is when my nav reboot screen start flickering
    I try to reload firmware but nav do nothing!
    And I can't connect to nav with INPA But before its connected, and everything works!
    Can somebody help?
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    You have a very old 4:3 monitor, I'm under the impression the Mk4 DVD based computer, which is a much later module, can directly drive a later 16:9 widescreen monitor. I'd suggest you change to one of those 16:9 units and try again.
    Cheers, Dennis!
    Jan 2016
    Paris , France
    E39 M5 . E90 318D
    Yes I agree with DennisCooper
    You may need to play with INPA and change the settings back to Mono in the Nav menu .
    Dec 2015
    Latvia, Saldus
    E46 Coupe
    Quote Originally Posted by Onemanshow View Post
    The problem is that I can't connect anymore INPA with navigation module !
    Mar 2018
    Slovakia
    E39
    [QUOTE = snaipis; 29002129] Ahoj
    upgrade my E46 s mk4 nav! Dostanem svoju loď z auta s mono nastavením, urobím tieto kroky
    Stručné inštrukcie:
    1. Znížte úroveň navigačného systému na operačný systém v24, aby sme mohli neskôr vynútiť aktualizáciu.
    2. Vytvorte špeciálny disk v28 OS, kde je len zmena, keď je mono navboot súbor nahradený farebným navboot súborom
    3. Vložte nový špeciálny disk v28
    Úplné pokyny
    1. DOWNGRADE TO V24
    Urobte si dobrý nezmenený disk v24 OS.
    Vynúte Mk4 Mono nav na upgrade na v24 ...
    Vložte nav do auta, zapnite kľúč, nechajte bootovať (nič nevidíte, len počkajte 2 minúty)
    Vložte disk v24 OS. Nav sa načíta softvér v24. Počkajte na vysunutie disku. Odstráňte disk.
    Nav je teraz na adrese v24. Vypnite kľúč, prejdite a vytvorte nový disk ...
    Získajte originálny nezmenený obraz v28 OS.
    Otvorte program MagicISO alebo váš obľúbený editor obrázkov
    Nahraďte tento súbor:
    s týmto:
    ... takže adresáre BMWM01S (monochromatické) a BMWC01S (farebné) majú rovnaké ) navboot súbor (11 807 976 bajtov)
    Čo sme urobili, je umiestniť farebný navboot súbor do monochromatického adresára, mono nav sa spustí pomocou farebnej navboot a prepne sa do farebného režimu.
    Napaľte nové špeciálne CD s operačným systémom v28. Označte ho ako "špeciálny v28 "
    Overte, či sú dva navboot súbory identické (v adresároch BMWC01S a BMWM01S)
    3. ZAŤAŽTE NOVÉ V28-SPECIAL
    Choďte na auto, zapnite ignoráciu, čakajte na mono nav (prednastavené s v24) na zavádzanie (2 minúty, aby ste si boli istí). Nezabudnite, že na monitore ešte nie je nič.
    Vložte v28-špeciálny OS CD
    Nav načíta nový softvér v28, keď skončíte, vysuniete CD.
    Odstráňte disk CD a stlačte tlačidlo bordmonitor
    Nav sa spustí opätovné spustenie. Keď sa spustí, príde farebná obrazovka.
    Problém je vtedy, keď sa moje reboot obrazovky začne
    blikať [video = youtube_share; HXZVd10LlaQ] https://youtu.be/HXZVd10LlaQ [/ video]
    Snažím sa znova načítať firmvér, ale nav nič neurobí!
    A nemôžem sa pripojiť na navigáciu s INPA Ale predtým, ako je pripojený a všetko funguje!
    Môže niekto pomôcť? [/ Quote]
    Hi, I have the same problem . Did you find a solution? Thanks
    Mar 2018
    Slovakia
    E39
    I have the same problem. Did you find a solution?
  1. 2000 bmw 323i problem please help
    By serdriver97 in forum 1999 - 2006 (E46)
    Last Post: 07-08-2005, 06:29 PM
  2. 1992 BMW 318iC Problem - Please Help!
    By thejeff22 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2005, 03:16 PM
  3. 1991 bmw 318is problems (E30)
    By kowalski in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-29-2005, 07:06 AM
  4. BMW Alarm Problem
    By untouch@ble in forum 1991 - 1999 (E36)
    Last Post: 01-03-2005, 01:29 PM
  5. BMW 325i problem
    By HS3 in forum 1999 - 2006 (E46)
    Last Post: 09-29-2004, 08:34 PM
