1989 535i - sold
1999 M3 Tiag/Dove - sold
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
unfortunately i dont have it, the operator at the dyno day was a huge dick.
I have posted the 500/500 graphs in my thread.
With the new motor i will be making the long trip to the good dynojet/operator i used the first time.
Edit-- Just thinking about it i actually think i may have a picture on the good camera. I was tuning not wielding the camera so im not certain.
1989 535i - sold
1996 332IS
Built 3.2
From my original dyno day 473wtq @ 4006 rpm, 93 pump only on medium timing, no EBC..
Note i added 3-5* in the 4k range after that day, we were hunting high rpm issues which turned out to be poor ring seal and didnt spend any time with adjusting midrange timing.
1989 535i - sold
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
I too have decided to join the dark side once again! Found out we can get an OBD2 turbo s52 to pass smog here relatively easier now. The Z3 Coupe will be getting some boost!
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
1989 535i - sold
Will do a proper build thread too. No rush on this, need to get my 6 speed, and all the z3 mcoupe suspension, brakes and subframes swapped from my Ti to the coupe, and put the zf 5 speed, and new bushings in the coupe stuff for the Ti. Then I need to sell the Ti to fund the coupe build, lol.
On the alternate list for the Steedspeed TS mani, and luckily I still have my old 3.3L motor, that already had forged CP pistons, ARP2000 stud and the ported non-Vanos head. Going to throw some K1 rods in it, put my fresh Dr. Vanos on it, and get a cut ring to drop compression from 11:1 down to 9.5:1. I want to run a 6466, and will get the 115 e85 injectors and necessary fuel system upgrade to run big boost. I want 450whp on pure 91 and the ability to turn it up to 750whp on e85 .
Its a 6673 in common turbo parlance, so it is on the large size among popular turbos for the 3.0L S50 and 3.2L S52. 73 is a big turbine to motivate. A GT4094 is a 6868, for example. Big usually means laggy, though fancy tech like ball bearing and titanium -- of which the S366 has neither -- can help. I'd call the S366 a high flowing bang for the buck turbo, but won't call it responsive until I see a dyno of one on an S50 or S52 showing good response.
1989 535i - sold
The problem with those graphs is everyone started at a different rpm which skews results..
The lower you start the higher your torque curve will be, because the turbo has more time absorbing energy.
1989 535i - sold
Thought Avee was S362 FMW.
1996 332IS
Built 3.2
1989 535i - sold
1996 332IS
Built 3.2
1989 535i - sold
1996 332IS
Built 3.2
