These fitting seem to be the perfect size, onward with the installation. Just hope the small NPT size stays in the manifold under boost lol. Thanks Vollosso!
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
If you blow an epoxied npt fitting out of the manifold you'll probably be the first...
On the plenum where the fins are inline with #5 runner there are two bosses that are undrilled. Those can easily be drilled and tapped for 1/8 NPT and are IMHO the best location for installing a nipple to pipe thread fitting as you have extra 'meat' for the threads in that location.
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
That'll be exactly what I'm doing like Anthony showed me
Deeeeemmm you just gonna take that?!?!
Both of them are 1/8npt with a 1/4" barb. I probably shouldve gone with the 1/8 barb to match my boost gauge and bov fittings but I was able to slide over the lines onto them anyways for a tighter seal. I bought the clear vacuum tubing from the hardware store that seems to be pretty strong and won't collapse. I think it was like 10 cents a foot lol. If you have your BOV / boost gauge already just bring it with you to Lowes / Home Depot and match it up to the fittings on them
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
1989 535i - sold
1999 M3 Tiag/Dove - sold
Lol true, but my planning stage was close to 5 years. In that time I bought 2 different setups and parted them out because it wasn't the right timing. Finally made the push to get it done and it's worth all of the struggles
Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
You will go through days of joy and days of sadness as the pursuit for power leads to madness...
Santa was good to me. Time to get back on my bull***t.
Damn, I remember reading kill threads about your car years ago, dreamed about your build... then got a solid turbo setup for over year because screw n/a. Then crashed it and now im starting build #2...? Lol props man gl with your progress!!
N/A was a lot of fun, I don't regret it at all. It was just unfortunate that the car broke right when I bought a house, a truck, and had a kid or else it would already be done. No worries, it'll be done soon now that I have my turbo.
What size turbo did you get?
WOT
Looks like a 6466
