Page 3 of 34 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 832
Thread: An N/A guy looking to the darkside. Help me build boost!
  1. #51
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Da Infammus 1 View Post
    I would actually love to be able to do some dig racing with the car once the trans and rear is set up for it, chikinhed indicated a bigger turbo would be more suited to that. Would you concur? (Without thinking that it would help your sale lol)
    If all the car is for is racing, sure higher HP the majority of the time. But for a street car do you want to always be 5k+ in the rpm range ? There is something to be said for taking a little bit of loss of peak power and shifting the graph to the left. Makes for much more fun on the street honestly.
    You really need to pick a #, and buy a turbo accordingly.
    If your looking for 650 and under I would say get a 35r based turbo. If your looking for 700+ go gt40/6466 based.
    There is no need to lose that lower end and buy a 4094 if your looking for 600.
    Having the power on tap at all tines for 600 wheel is nice with a 35r ish turbo. But with a 4094 and running around with 600 your downshifting all the time.
    I really think for a street car , having a fat power band is more fun.
    Having driven everything in between, I can tell you this, if this TS steed doesn't wake up this 6466 a bit more, I'll take the hit and not have 700wheel on pump and fatten up the power band and get a wide 650 with a gtx35 or a 6266.
    But to answer your question, from a dig, its going to be hard for the big turbo car to catch the smaller turbo car light to light.
    Pick a fuel, pick a whp# this should pick the turbo.
    Ie , 93 octane and 600 HP is a 35r with 22-23 psi. That's doable. If that # was 700, then the 35r ain't going to cut it with out e85 or 109.
    My opinion is that everyone should experience a hard hitting 35r style turbo as a street car. While your sorting it out , if you decide you want more than 600 then upgrade. 600 should amuse you for a little bit . coning from 275 or whatever you were at. Try that first. You have a lot to sort out on your first turbo setup.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #52
    NY
    skateboard
    I don't really have intentions of using the 286's unless a tuner or someone else knowledgeable tells me otherwise.
    Any other help on the parts list or any info I asked for in my 1st post?
    Ask Jordan what he thinks
    ― George Orwell
  3. #53
    NY/FL
    '08 G35S, '98 M3/4/5
    Thank you for that info Butters, super helpful! I agree, getting into my first turbo setup 600 would be fine for the time being. Maybe even 500 just t get used to it. What's the torque numbers usually look like with 600whp, around 500wtq? Also in a 35r-ish turbo, would an HTA upgraded 35r serve for more sustainable higher RPM power than say a standard gtx35r?
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  4. #54
    NY/FL
    Quote Originally Posted by GG///M3 View Post
    I'd also like to know what ALL tuners, including both Jordan and Nick, would think on that camshaft matter. I'm pretty confident they'd tell me to stick with 264's or 276's
  5. #55
    Dec 2015
    Fairbanks Alaska
    looking for E36 328i
    HTA3586 is a monster. Very popular.
    4 different turbo cars/1 BB chevy/1 all motor+nitrous...7 different turbos, 4 different intercoolers, 6 different EMS systems etc etc. Looking to play E36 on boost.
  6. #56
    NY/FL
    Quote Originally Posted by mean4g View Post
    What makes it so different from a gtx35r straight from Garrett though?
  7. #57
    Manchester, N.H.
    96 332IS 6466 turbo
    3582 vs 3586
    1996 332IS
    Built 3.2
  8. #58
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    It goes like this
    Gt35r, hta3582/86, gtx3582, the hta is a forced performance upgrade.
  9. #59
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    I had the HTA upgrade...it was good but I expected better results. The only reason I did it was because I nicked one of the blades on the compressor wheel when I was installing the cover on a brand new GT3582R.
    Id like to see:
    Steedspeed V2
    6466
    E85
    RK tuned
    You'll be in the 800+whp range for sure.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  10. #60
    NY/FL
    Quote Originally Posted by E36 HateR View Post
    It goes like this
    How is the HTA3586 behind the gtx3582? Wouldn't the 86 be a bigger turbo, although the gtx denotes journal bearings?
  11. #61
    NY/FL
    Quote Originally Posted by NY98M3 View Post
    Id like to see:
    Steedspeed V2
    6466
    E85
    RK tuned
    The only problem I have with that setup is that the car isn't able to hold that kind of power yet, I'd just be blowing up my drivetrain constantly at that power level and then have a slightly laggy system when turned down to an acceptable power level. Thus why I was thinking start at 550-600's, learn the car and get acclimated to turbo life while compiling parts to go big later on.
    But umm.. that 6466 you got is a t4 twin scroll housing? That would be tempting
  12. #62
    Manchester, N.H.
    96 332IS 6466 turbo
    I think the HTA3582 is like the gtx3582. So more like
    35r < hta3582 = gtx3582 < hta3586
    1996 332IS
    Built 3.2
  13. #63
    NY/FL
    Ahh, that makes sense. Wouldnt the 3586 and PT 6466 be in the same performance range though?
    Also what diff ratio are you guys using? Mine is currently 3.46 from having an N/A setup, wondering what I should change it to.
  14. #64
    Manchester, N.H.
    96 332IS 6466 turbo
    Hta35 will spool much quicker than the 6466. Both will make 700 , the 6466 will do it with less boost. If goal is 650 or under HTA is your turbo, if you want 700+ go 6466
    1996 332IS
    Built 3.2
  15. #65
    NY
    skateboard
    I liked it better then driving a 4094 car .
    ― George Orwell
  16. #66
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    3.2 gtx35 m3 vs 2.5 hx40 325, 40 roll both cars make a hair over 600whp but one "makes no torques"
    Skip to 4:14
    Had him 3-4 cars and i was driving horribly, banged the limiter before every shift just to flex.
    From 0-100 the smaller turbo is the better choice but if you are going to race to 140-150mph id take the larger turbo every day.
  17. #67
    Vancouver, B.C., Canada
    '97 M3
    We're the cars dynoed on the same dyno, the same weight, same gearing, both getting traction and both driven to max potential? One of those factor had to have played a role there.
    Sent from my GTX3582R
  18. #68
    Dec 2015
    Fairbanks Alaska
    Skip to 4:14
    nice. A lot of variables of course....but I always loved smashing people with their $2K+ turbos as well. Their jaws hit the floor when they see you are running a diesel truck turbo that cost you 400 dollars. lol.
  19. #69
    NY/FL
    Might as well go 6466 or similar sized turbo and go from there since my new engine will be high whp capable. My area is all highway, there isn't really much stop and go driving. Plus this is no longer my DD, if I take the car out it'll be to do some sort of racing.
    As for diff ratios, the popular two that I see for boosted cars are 3.15 and 2.93, am occasionally the 3.23. Any input on any of those to replace my current 3.46?
  20. #70
    NY
    skateboard
    Is the 3.46 a built diff? If so I have a built 3.15 in my car with about 1,500miles on it
    ― George Orwell
  21. #71
    '97 M3
    I wish we had a local here with a large frame turbo so I could see if I could tolerate the lag.
  22. #72
    NY/FL
    Yea, built 3.46 with 40 % lockup. It's a noisy diff but has done it's job very well. Just want something I can depend on that'll be conducive to the new turbo setup.
  23. #73
    NY
    skateboard
    Quote Originally Posted by chikinhed View Post
    It isn't that bad, but it wasn't what I liked honestly.
    Same here 40% lock
    ― George Orwell
  24. #74
    NY/FL
    For anyone like me who was trying to gain more knowledge of turbos, this article helped me understand the basics
    http://www.superstreetonline.com/how...urbo-tech-101/
  25. #75
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    If you are set on 6466 then go for it. The list of stuff you have to replace above 550 is pretty big but given time and money you will get it for sure. The problem will be keeping the HP down before the car is ready and I've seen you at the track!
    Riverview has a thorntons with e85. I think i found about 20 stations in 40 miles with e85. You realize Nick is in Florida right?
  1. New to the Forum - Help Me Save My Bimmer!!!
    By PoisonBimmer in forum Georgia sponsored by Harrison Motorsports
    Last Post: 06-18-2010, 09:58 PM
  2. new to the site. new to the bmw..help me out
    By deadman911 in forum 1999 - 2006 (E46)
    Last Post: 02-19-2010, 04:25 PM
  3. Looking into the 335i HELP ME
    By Smk U ltr in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-13-2008, 10:18 AM
  4. New guy back to the forums, help?
    By bmwfreak96 in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 08:45 AM
