Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Just keeping tabs on myself here. Kinda wishing I wasn't so picky and allowed myself to cut a few corners here and there that would expedite this process, but I guess it's better to just do it once.
Big items left to buy:
-Rallyroad column pod
-Eboost2
-Zeitronix
-Turbo
-driveshaft
Trying to decide whether to test the limits of the Spec Stage3+ just to get the car up and running or just bite the bullet on a twin disc.
That stage 3 won't last long at the power levels you want.
Skip the eboost And the driveshaft for a while.. .... and buy a proper clutch. You dont need either of those for a while.
1989 535i - sold
1999 M3 Tiag/Dove - sold
What turbo?
Anyone have any luck getting a rallyroad 52mm pod? Been trying to order one since before Christmas and it's been sold out.
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
Still haven't gotten any word back on him and it says sold out on the site, smh.
Also in search of a 6 bolt driveshaft to match to my 210mm diff if anyone has any leads on one.
Another question, is the euro 6 speed more durable than a ZF 5 speed? I have a line on one, if it's as good as a getrag 420 from an e46 M3 I'd pull the trigger on it.
You just need the bigger spline size for the disc, the rest is the same.
