Maybe the garrett turbo 35r type turbo that flows nearly 1000hp? Good Spoolage, and rapes up top as well(a turbi you can grow into so to speak)..
The Pursuit of Power leads to sadness
Here is a comparison between the GTX3582R turbine wheel and the the new GTX3584R turbine wheel.......
The new turbine wheel looks much thinner at the leading edge especially at the root. It also looks like the blades don't have as much curve to them. They also say that the turbine wheel is made out of inconel, hasn't it always been made out of inconel?
GTX3582R PRODUCT SPECIFICATIONS: Compressor Wheel Inducer: 62.5mm Compressor Wheel Exducer: 82.5mm Compressor Wheel Trim: 56 Turbine Wheel Inducer: 68.0mm Turbine Wheel Exducer: 62.3mm Turbine Wheel Trim: 84
GTX3584RS PRODUCT SPECIFICATIONS: Compressor Wheel Inducer: 67mm Compressor Wheel Exducer: 88mm Compressor Wheel Trim: 64 Compressor Housing A/R: 0.72 Turbine Wheel Inducer: 68mm Turbine Wheel Exducer: 62mm Turbine Wheel Trim: 84
Finishing up some shopping, have a gauge question.
3 most important gauges to have? I planned to have oil temp, water/coolant temp, and oil pressure in 3 gauge pod, with Eboost2 and Zeitronix in the rallyroad steering column pod. Should I have EGT instead of oil temp or something else?
Also looking for recommendations on a 3 gauge pod.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Here are a few pics of Anthony's setup, I like it.
Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
You will go through days of joy and days of sadness as the pursuit for power leads to madness...
I think you need to buy the single and duel to make a triple. But be advised, if running hefty electronics at the Pilar it gets real tight in there. For instance, back in the day I had a simple boost gauge and a wide band, wasn't too bad. But changed to having an Eboost2, WB , and Water injection gauges on the Pilar. Man its a super tight fit, loads of wires and big pita.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I have been running a double and a single on the pillar for about 10 years. It works, but try to plan out the wiring so it is as simple as possible since space is tight. I have oil pressure, eboost and afr on the pillar, and aquamist, fuel pressure and oil temp in the former storage area below the HVAC control.
I think the best solution would be a single digital gauge with 6 lines of horizontal readout for about 6 different sensors, but I would still want my eboost2 and aquamist so I would still need 3 gauges. I have seen some clean installs of the AFR in the fuel economy gauge, but I like it more in the line of sight. Heads up display would be great. The zeitronix and innovate and other logging systems have some appeal, plus they have the ability to program warnings. I am not sure I will bother setting one up, but I may try the AFR failsafe that AEM makes. The more power you have, the more you are at risk, and failsafes will reduce the risk of harm. I melted an engine about 8 years ago when I ran out of fuel while supercharged and racing a Nissan GTR. I had it by a fender to 145+, when the big oil cloud appeared in the rear view and I lost power. I was concentrating on the road, not the gauges. A warning alarm or failsafe might have helped.
Thats the LeatherZ panel with Autometer rings, just needs some trimming once you get the angles oriented. BTW those are Autometer ES gauges.
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
Well now there's a top mount friendly radiator and reservoir option, just exorbitantly expensive. Hopefully mishimoto will copy it and made a more affordable version LOL.
Ordered a ton of stuff for the car, still looking for a cooling reservoir solution that won't cost 1200 lol.
Use the Euro one. Had one for 10 years.
Stock works fine also -- plenty have used them though I prefer the Euro.
Yeah why do we need to have a $1200 coolant res set up? Vast majority run stock or retrofitted stock set ups...
I thought you were going bottom mount with the steed?
Wait, top mount downpipe doesn't interfere with the euro expansion tank. Thats what I use.
