Page 25 of 34 FirstFirst ... 1516171819202122232425262728293031323334 LastLast
Results 601 to 625 of 832
Thread: An N/A guy looking to the darkside. Help me build boost!
  1. #601
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There needs to be a standard for measuring boost response that is easy for everyone to apply. Like a steady 2000 rpm cruise in each gear. Then floor it and record the rpm at which you get 20 psi. Or a dynojet with boost log. Otherwise its a bunch of butt dynos or one persons logging tool vs another or what someone thinks they saw.
  2. #602
    Toronto, Canada
    E36 Turbo
    Agreed, just have to remember gearing makes a difference as well.
  3. #603
    Jun 2005
    New England
    OK. Disclose gearing as well. Weight also makes a difference, so that should be disclosed also. And the turbine housing AR should be listed along with the turbo size. And the manifold brand and whether it is open or twinscroll. And whether the fuel is pump or E85. And the displacement of the motor and compression. And the cams.
    A 2000 rpm roll at least has everyone doing the same test. Right now, one guy might have a brand X datalog, one guy reports what he sees on the gauges, and one guy has a dynojet boost log and probably for the same turbo on the same car they would all differ.
  4. #604
    Toronto, Canada
    E36 Turbo
    Well the more we know about said setup, the better we can make sense of the findings...
  5. #605
    NY/FL
    '08 G35S, '98 M3/4/5
    Quote Originally Posted by e30kid89 View Post
    Sounds like what I was saying earlier!
    Bf.c FI needs to stop fearing the large turbos.
    I don't fear large turbos. I fear large price tag and long wait times to complete the car lol.
    Never did any research on GTW turbos Butters, and links to info?
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  6. #606
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Da Infammus 1 View Post
    There isn't a whole lot out there. They are new as of last year. Garrett wanted to put out a series of turbos to compete with the Precision lineup.
    Basically real close in wheel sizes. The BB turbos are water cooled.
    Couple here running them. They are very happy.
    They basically have the 58/62/64/67mm turbos available. Price is awesome and should be "Garrett reliable".
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  7. #607
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    I know Chelsea Denofa switched from a gtx3582r to a gtw3884 and made more power on less boost, and similar spool.
  8. #608
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by e30polak View Post
    I'd love to see info on that.
    1996 332IS
    Built 3.2
  9. #609
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by E36 HateR View Post
    In what gear?
    I was getting 25psi in 2nd at 4500, and 25psi in 3rd about 300rpm sooner.
    Large 4 inch core and 3 inch piping from the compressor cover.
    Lazy journal bearing holset on a stock compression 2.8, so a slightly lower comp 3.3 should come on sooner.
    I do most of my stuff in 3rd gear and log everything to the little AEM.
    I think its a bit apples to oranges. 1100hp turbo with a 68*92.5 compressor | 78.75*70 turbine. I don't remember, are you hx40 with a 64mm? That make you like 64-65 and maybe an 750hp turbo?
    Yeah I mean I thought the old 64mm was gonna be a "big turbo" when I bought it but I think I wouldn't go any smaller on a 3L++. I think the 6870 is honestly the right choice for a 3.3l and for a 2.8-2.999 I would probably go 6466.
    Quote Originally Posted by NOTORIOUS VR View Post
    Dyno? Logs?
    I can upload logs, I have ordered new tires and am getting adjustable lower control arms and an alignment. I also need more fuel TBH.. but ill eventually hit a dyno.
    I will try and find time to post logs later with a 1 bar spring, gate only, from 2000rpm, with 3.15 rear in 3rd.. logged at 20hz.. Oh my poor third gear.
    Edit: But I mean im vanos off, on soft timing with base tune AFR so there is a good bit to be gained.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  10. #610
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by vollosso View Post
    Other than your VANOS being off (why?), that would be good test.. spring only, no controller.
    I'd like to see how it is vs my 4094R on a softer spring (13 psi) combo on my 2.9
  11. #611
    Jun 2005
    New England
    Do 4th since that is what is usually done on the dyno, creates good load, reduces wheelspin, and is less breakage prone.
  12. #612
    Mar 2012
    Renton, Wa
    98 m3
    Jeeze, ill see if I can find enough highway for that :p
    Vanos was acting funny and giving me codes, I pulled the top end apart twice thinking it was cam timing. Eventually just disabled it in the code so I didn't have a CEL. Wasn't an issue with the old instaspool-turbo. I have a spare vanos unit now and just need to rebuild it and install it, just been too busy..
    hah I think its actually a 13.5# so it would be a great datapoint. I can export to CSV and you can overlay them if you'd like. Do a pull and also note your current ATMO conditions and lets compare.
    1989 535i - sold
  13. #613
    Toronto, Canada
    E36 Turbo
    My car is down right now.. but I have a log starting from 3rd to 4th somewhere from a few months back (so warmer weather) for now. I'll get a current one once the car is back together though because I can't wait to drive it again lol.
  14. #614
    Mar 2012
    Renton, Wa
    98 m3
    so ill just do a 3rd from 2k-4th redline
    and a 4th from 2k on my way home today.
    hah i have no idea what happened with this log but imagine my shock when i look down and see like 20 psi haha.
    2200 rpm start, flat surface, 83* F, no vanos.
    I need to check the couplers and wastegate I guess, havent turned a wrench in a few weeks.
    1989 535i - sold
  15. #615
    Vancouver, B.C., Canada
    '97 M3
    I was having intermittent Vanos issues a while back and it ended up being a small piece of poo in the small orifice at the bottom of the banjo bolt threads on the vanos.
  16. #616
    Manchester, N.H.
    96 332IS 6466 turbo
    10# at 4k ?
    1996 332IS
    Built 3.2
  17. #617
    '97 M3
    10# at 4k ?
    I wouldn't be bragging about that.
  18. #618
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by chikinhed View Post
    Same.
  19. #619
    Mar 2012
    Renton, Wa
    98 m3
    Wow uploads a log for transparency.. You guys are really something..
    Its a 13.5# spring, it should make 9-10# and then be mostly open. it will be 100% open by 13.5#. Its clearly creeping after that for some reason, for the first time I have seen just today.
    Everyone wonders why there's nothing posted, no transparency, and nothing happening on BFC... this is why.. you guys immediately hate before thinking.. I dont get it.
    1989 535i - sold
  20. #620
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    You said full boost by 4200, i thought you meant 20psi by then. With the higher spring pressure it will spool better.
  21. #621
    Manchester, N.H.
    96 332IS 6466 turbo
    Gate looks like it cracked at 4k then hit target at 5k.
    In 3rd gear with a 6870 that might be right on par.
    I talked with Reid today from Sound Performance about the 6870 vs 6466. He has probably more experience than anyone with those turbos. Unfortunately for me without being able to run high pressures, or e85 he said it would be a loss. These turbos are meant for big powers and big boosts.
    1996 332IS
    Built 3.2
  22. #622
    '97 M3
    Wow uploads a log for transparency.. You guys are really something.. Everyone wonders why there's nothing posted, no transparency, and nothing happening on BFC... this is why.. you guys immediately hate before thinking.. I dont get it.
    Honesty, I didn't even see the graph or know who Butters was referring to, I was just responding to what Butters had said. It was a total peanut gallery remark, wasn't trying to hate.
    That thing must have felt like a rocket ship by 20 psi.
  23. #623
    Sep 2008
    Toronto, ON
    6465 328ti
    Gate looks like it cracked at 4k then hit target at 5k. In 3rd gear with a 6870 that might be right on par. I talked with Reid today from Sound Performance about the 6870 vs 6466. He has probably more experience than anyone with those turbos. Unfortunately for me without being able to run high pressures, or e85 he said it would be a loss. These turbos are meant for big powers and big boosts.
    Yeah, I didn't get to run mine on pump gas but it wouldn't great. Why not consider the 6766? Pump gas friendly and still good for high 8-low 900whp if you decide to max it out one day.
  24. #624
    Huntsville, AL
    95 M3
    Did he provide you with any data to justify this statement? (Specifically on a bmw engine)
    WOT
  25. #625
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by hsvturbo View Post
    Think its pretty well known that these gen2 wheels like high pressures.
    They did some back to back testing back in the day using a 6266 gen2 vs a 6266 gen1 and until you got up in the 25# land the gen1 was beating the gen2. But, after that game over.
    They are a supra shop tho. I want to say they built an e46 m3 years ago with over 1k whp, but I don't really follow other stuff.
    1996 332IS
    Built 3.2
  1. New to the Forum - Help Me Save My Bimmer!!!
    By PoisonBimmer in forum Georgia sponsored by Harrison Motorsports
    Last Post: 06-18-2010, 09:58 PM
  2. new to the site. new to the bmw..help me out
    By deadman911 in forum 1999 - 2006 (E46)
    Last Post: 02-19-2010, 04:25 PM
  3. Looking into the 335i HELP ME
    By Smk U ltr in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-13-2008, 10:18 AM
  4. New guy back to the forums, help?
    By bmwfreak96 in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 08:45 AM
