If you're just worried about direct air into the engine bay instead of "ram" air, take off the frame to headlight and do what this guy dude. You can keep the intake on the turbo and the air coming through will be ambient. When you're on the street, put stock headlight back in.
http://www.bimmerforums.com/forum/sh...ght-Intake-e36
It's really not that big of a deal, I'm sure if I find it necessary after assembling the car that I can make it happen. I was just curious if there was one readily available. There have been several high whp cars that have done without it, I'm sure I'll be fine.
My bigger worry is getting parts in, I still have no turbo manifold in my hands yet lol. Also need to go down my checklist again.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Why you retiring this car from street duty?
I have driven my car more miles over a shorter period of time since I turbod it than I ever have in my previous 4 years of ownership. Its so much fun, I drive it every chance I get. Ive put almost 5k miles on it so far. Would seem like such a waste to build such a car and never drive it..
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
I've learned my lesson daily driving my race car. Although it was fun, it was too much wear and tear to race it on weekends and drive it 25 miles each way back and forth to work everyday. Remember, my local racing scene is very active so it'll definitely see street duty, but mostly reserved for the weekends. Trust me, it's going to get driven lol.
Gotcha..
Very jealous of the crowd you got down there.
Nobody ever wants to race around here.
Oh, and hurry up lol
LOL COMEEE ONNNN
The FI section has been boring AF recently. Need a nice build thread to break the monotony...
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Why is that?
Cause people are scrambling to get their cars done, work out the gremlins, and don't want to take the time to snap pics and document. They also don't want to disclose the foolish screw ups and mistakes they have made. Where is in the winter, cars are usually down and there isn't much of a rush.
There is a good amount of new englanders/north easterners here.
1996 332IS
Built 3.2
Oh yeah.. you poor guys can't drive your cars half the year :p
Meanwhile my 21 year old pos gets driven year round without a spec of rust
Parts finally starting to roll in. Got these from Ant's recommendation, really look like solid pieces. It was a nice surprise as I had totally forgot I ordered them LOL.
What's the recommendation on wastgates, turbosmart vs tial? Any one better than the other?
Doing some parts research, has anyone here ever used boost activated exhaust cutouts? As in they activate when the car goes into boost?
It's called open dump wg :p
Yeah my tial 44 has been perfect. Perfect boost control...
I like my precision 46mm gate. Boost control is perfect and it comes with all the springs to go from like 3 psi to 27. I really appreciate that. I think the Tial is a bit more compact and it also comes with all the springs but the range of spring pressure is lower. I don't think you can go wrong with Tial or Precision.
I run a synapse 50mm. I like it a lot i can change boost settings while the car is hot.. It has like 10 settings per spring, plus a preload which ups the boost like 0-10 psi with infinite increments.
The best part is its crack pressure is higher than most wastegates. 18 psi on a regular gate will crack at like 13, this will hold to 16 or something.
If your running ebc its probably not as worth it.. Ill let you know.
Theres also a few home brew diesel options that make VERY nice gates.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Jgs wastgates look cool (the small outfit i was talking about)
http://www.racepartsolutions.com/ind...part-solutions
1989 535i - sold
