Have a problem with front speakers not working and no sound at all from CD player. CD player works & changes tracks, but no sound at all. Front speakers only work with radio and nav voice. Lots of wires are cut & disconnected like previous owner had a aftermarket amp they removed and didn't bother fixing back there mess. A color coded diagram would be helpful if there's a link somewhere. I found a old one on here but starts to open then goes blank.
Thanks for any help.
This is the one I use. I use Firefox with the JAVA plugin.
http://www.bmw-planet.com/diagrams/release/en/index.htm
You also need to put an exception in the JAVA console:
There is a member who has his own WDS that is much easier to access. I will leave it up to him if he wants to share it.
So many variable depending on which system you have but there should be something that runs from the CD player directly to the amp.
I have this saved if you happen to have a 15 pin connector on the amp. I don't remember which it came from.
Thanks. I'll try to open on a laptop instead of iPhone. I think I have part of the wires figured out. ( three of the yellow pairs). There's still one yellow pair with a red stripe and a pair of blue wires I haven't figured out yet.
Here's a pic if you can tell anything about it. The CD player is removed right now. It also seems I have front lower door speakers working but not the top ones. Although if you adjust fader all the way to front there's no sound? Like the lower fronts are playing off the rears??
