Went to a no prep, did ok.
Forst round- against a twin turbo ls rat rod. Put a couple cars on him
2nd round- up against a 400ci 88mm 1970 nova. Car was sick. I treed the shit out of him, very badly. I cut a .04, car came out like 10ft and smoked the tire. Then for some reason, I couldn't get the shifter into 2nd. He put like 3 cars on me while I banged limiter. Couldn't catch him.
then I put it into TNT and couldn't get the car to leave at all. Frustrated. Fastest pass was another 6.4 at 114
And the nova won the whole thing
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Dude, that is some really good results for just getting going with this version of the build -- Congrats!
Brought the car to Mexico last night for some rolls.
smacked up a built evo 8 on a 6466 on 38psi.
tried running a buddy with a built wrx on a 6870 on 40psi, but it smoked the tire badly on a 60 roll.
best part- 3 people in the car. Sedan life
I think the results are going to start coming in real nicely now. Are you feeling any less like selling the beast at this point (yet)?
blows tires off at 60 with 3 people in the car.
did this strike anyone else as being the coolest thing they'd read in a long while?
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
Lol it nailed the tires so hard, I thought it broke. Traction control with a 20% slip threshold is too much for the radials. Needs to be like 12%
Not at all. Once it goes 9.5, it's gone.
Spent all day yesterday test fitting different wheels. I need a 15x8 with a et40 or greater to fit a 275/50/15
Also, put some 700pound springs in the rear and rolled the quarters more per suggestions from people smarter then me
And the TCI sticker is to cover the cracked windsheild where my buddy snapped off the mirror.
What dampers are you using with the 700 lb rear springs? Did you notice an improvement?
Havent had hardly any runtime other then some street pulls and it seemed ok. Right now its on Koni yellows adjusted fully firm, but ive been talking to Viking about making a set of double adjustables for the spring rates im running. 250$/each, 4 day turn around.
I figured ill try it as is. I know what the car 60fted before the springs and tires. If i can get back to that or better, im moving in the right direction. Then ill get the shocks.
So brought the car to the track on the new 275 radials and stuff springs. Also raised the launch boost and rpm and used timing retard based off time to reduce the power on the launch and quickly bring it back in.off the trailer it went my PB of a 6.2 at 114.then I just added 2 degrees and raised the launch rpm to 3800 and did thisI lifted after the 1/8th. Rolled a 10.3 lol
That 60ft is crazy
Foot brake still
It's what I have been saying for years. Glad you fingered it out on your own. Also, in case you didn't know, you have an 8 sec car on your hands (potentially).
I agree. I think once I really start turning it up, she's gonna fly
So here I am again, wanting to go faster, looking for someone to go racing with me today. New goal- 5.6 in the 1/8
i think I can leave with a little more power, and I got a lot more power to put in after the 60ft.
Wish I ran it out back on the 6.0 pass
And shout out to someguy2800. We had a conversation not to long ago about suspension setup and I took some of his advise and shaved a tenth off my 60ft.
I bet you surprise the hell outta folks running those times in that e36 man. Crazy business!!
sorry wrong thread
You should put the matching wheels on the front for the ultimate sleeper look.
I would, but my slicks are mounted on the other set, lol.
No more rubbing. Had to raise the car a bit and roll the quarters but nothing crazy. Have to run a 10mm spacer and shave the caliper down but thats specific to the wheel, and to be honest, a 15x8 with a 6inch back space would probably work even better.
But the stiff springs helped me 2 fold for my car with the auto. With a manual, it will be more difficult to get to work. You will really be relying on the shock imo.
Shoot me a PM if you want, no worries.
