Page 19 of 40 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 451 to 475 of 976
Thread: Dburt's Rusty Nitrous LS M3 Build, now twin turbo
  1. #451
    Aug 2012
    CT
    Twin turbo LS E36 M3
    So I got to see Stevie fast break the record for fastest past on a drag radial. 3.73 at 201 (can't rememebr the exact speed)
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  2. #452
    DeWitt, Michigan
    '97 540i/6, '97 328i
  3. #453
    Vancouver, B.C., Canada
    '97 M3
    That's like a fricken sling shot.
  4. #454
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by dburt86 View Post
    Yep he went 3.737 @ 199!
    That's one badass machine!
  5. #455
    '97 M3
    0.9 sec 60 ft time.
  6. #456
    Apr 2006
    Minnesota eh?
    86 325es
    I don't know how they don't tear all the cords in the sidewalls of those drag radials going that fast. I tore up two sets in one summer with my low powered little car
  7. #457
    Jun 2015
    NH
    1998 BMW 323is
    So I just found this thread after having been DREAMING about a 6.0 LS(q) with twin turbos up front in my 323 for years at this point. holy hell its beautiful. cant wait to follow this more as it goes.
  8. #458
    Aug 2012
    CT
    Thanks man. I'll have some updates soon.
    Converter shipped friday, turbos showed up Friday. The only big ticket thing I need is an ecu and harness.
    this week I should have some solid progress.
    ps- Stevie fast hits the wall after the 1/8, and duct tapes the front end back together.
    then the corvette that lost in the finals chucks a rod through the block, and they weld the block up and epoxy the head and makes it to the semi finals where he wins, but drops a valve. Patches it back together for the finals and loses.
  9. #459
    Jun 2012
    South fla
    97 332i, 90 535i
    That was crazy I watched it all on live feed!
  10. #460
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Wow! Great build.
    Just came across this thread for the first time.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  11. #461
    Aug 2012
    CT
    Turbos came in
  12. #462
    Manchester, N.H.
    96 332IS 6466 turbo
    Turbos came in
    They look awesome !
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  13. #463
    Aug 2012
    CT
    Something is going with using an iPhone and Photobucket. It has worked for years and now pics won't appear
    %5BURL=http://s314.photobucket.com/user/dburt86/media/BMW%20stuff/AEEF0FFD-C5E7-4ABA-BD1E-F0796F75EDBF_zps1gtevvgb.jpg.html%5D%5BIMG%5Dhttp://i314.photobucket.com/albums/ll431/dburt86/BMW%20stuff/AEEF0FFD-C5E7-4ABA-BD1E-F0796F75EDBF_zps1gtevvgb.jpg%5B/IMG%5D%5B/URL%5D
  14. #464
    Apr 2006
    Minnesota eh?
    86 325es
    I have the same problem. Pain in the ass
  15. #465
    Aug 2012
    CT
    It makes me want to snap my phone in half
    every time
    Side not for the nerds-
    i was over at the Dwayne mills golden gorilla pit this weekend talking to the proline guys and they recently switched to a hemi motor (nothing mopar about it) and made some new headers.
    twin 106mm turbos (iirc)
    2 5/8 primaries on the headers
    car has almost 1:1 back pressure at 75psi of boost.
    wtf.
    he also uses an inductive pickup on a plug wire for the cam signal.
    car goes 210ish in the eighth
  16. #466
    Jun 2012
    South fla
    97 332i, 90 535i
    wtf.
    Faaaack! That's a nasty setup!
  17. #467
    Boston, MA
    E36 M3 Turbo
    This lights out sounds sick!
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  18. #468
    Aug 2012
    CT
    I'd upload some photos if my phone wasn't such a pile
    but basically it's 2500-4000whp cars that should be on huge slicks, slap on 275 or 315 drag radials and go almost as fast as they would with a steam roller sized tire.
  19. #469
    Aug 2012
    CT
  20. #470
    DeWitt, Michigan
    Got a pair of high output air movers there? They don't appear to be orange, so maybe not haha...
    What are the specs on them?
  21. #471
    Aug 2012
    CT
    66MM comp, 74mm turbine, open .88 housing t4 flange
  22. #472
    Jul 2004
    Austin, TX
    AA turbo 332i
    No idea how I missed this thread!! Awesome work, keep it up
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  23. #473
    Aug 2012
    CT
    Quote Originally Posted by jjjjjjj View Post
    Thanks man!
    Got the shifter installed last night. Everything stock seems to fit. Ill snap some pics when im back at the shop.
    Converter should be here any day so then i can get the trans in and get the swap in where it needs to be. After that, i can put the turbos on and figure out an exhuast (i dont think my current exhaust will clear the deep pan for the trans)
  24. #474
    Aug 2012
    CT
    im just about done with photobucket
    Converter is in
  25. #475
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Converter is in
    Go old school and do Flickr.
    my Flickr account is old as the hills and still works perfectly.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  1. Full Build Thread - Twin Turbo e30 m3
    By SierraNevada40 in forum Forced Induction
    Last Post: 01-23-2017, 05:44 AM
  2. E36 M3 1JZ-GTE Twin Turbo Build! Purists Beware
    By Reilly1JZ in forum Engine Conversions
    Last Post: 07-05-2015, 12:12 PM
  3. Local E46 SMG M3 Build - Maximum PSI Turbo Kit
    By maximumpsi in forum Forced Induction
    Last Post: 02-19-2013, 07:14 PM
  4. E36 M3 vs E46 M3 vs Supra Twin Turbo
    By HyperHoHo in forum Kill Stories
    Last Post: 06-12-2004, 10:20 PM
  5. E46 M3 vs. RX7 Twin Turbo
    By JMWeb in forum Kill Stories
    Last Post: 04-18-2003, 03:44 PM
