Page 5 of 5 FirstFirst 12345
Results 101 to 121 of 121
Thread: 1992 E36 Coupe Electric Rear Vents -Retrofit
  1. #101
    germany
    6/96 318is
    Quote Originally Posted by bmw4life92 View Post
    Okai, still needs modding?...
    Yes, they do. I will consult my notes as to the resistor values, or if necessary, read them off a modified module.
  2. #102
    Aug 2016
    Denmark
    BMW e36 Coupe 1992
    Can i ask how this went in your bmw e36 1992? im thinking ZKM or ZKE module wise.
    Im the Proud owner of a 1992 5/5 E36 coupe, do i need to get another ZK module or will mine thats preinstalled be fine?
    I have read this thread a couple of times but im not quite sure i follow 100 %
    And about the harness my set of rear vent the wires were cut off so i need to create the harness anyone who can help of have made one who is selling it?
  3. #103
    Nov 2015
    Norway
    1992 BMW 325i Coupe
    You dont need to add a ZKE4 module, Just get a blue K113 Hinged Window Relay and some rear vent switches, then follow the pin-out info posted on Page 3 by Genius, skip the black/red wire going to ZKE and you have a power vent wiring harness for your pre-1994 E36.
    I got power from the open pin on my comfort relay.
    There is a feature on 1994+ cars with ZKE4, holding lock button on fob or holding Key in full lock position in the door will close all open windows and sunroof. But this whole feature is not in the older ZVM module we have.
    I have all the BMW pins & connectors to make a new wiring harness just for fun, but I have not gotten around to wiring it up during this summer. It is fairly easy once you can read the pin-outs.
  4. #104
    Jul 2018
    BC
    1998 M
    Anyone have power vent system components for sale?
    i am trying to make this system more accessible to everyone. i found the motors from the original manufacturer widely available still, very cheap. Pm for more details. i need the power vent window wiring and the comfort relay wiring to make schematics.
  5. #105
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by Fix.a.ZX View Post
    You can check the BMW E36 ETM for the exact wiring schematics.
    IG:
  6. #106
    Jul 2018
    BC
    1998 M
    Does that tell you length and gage? Not last time I checked.
  7. #107
    The Netherlands
    No not the length ha. Gauge, yes.
    IG:
  8. #108
    Jul 2018
    BC
    1998 M
    Besides I need the harnesses for my use anyways.
  9. #109
    Sep 2017
    Hungary
    1997 BMW E36 320i
    hi there!
    i'll like to upgrade my car with the rear windows to lift it electric, first of all, i've an E36 SEDAN from '97 so it's got an ZKE IV module. So.... now, my job is only get around follow the assemby of harnesses like the previous comments, or i have to modify somethings on my car?
    can i follow these methods or i'm absolutly wrong?
  10. #110
    germany
    6/96 318is
    I might start a new thread. This one is about swinging rear windows, which is quite different than lifting them. For example, to get a sedan to safely comfort close its rear windows, you might want to wire and code the ZKE as if it is raising and lower the windows in a cabrio.
  11. #111
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Okay, anyway, can you show me a schematic pic about this harness? With pinouts. Just to know where could I start it to wire up my harness. Thanks a lot!
  12. #112
    germany
    6/96 318is
    You might search for something like "bmw etm gb".
    Section 5133.0 of the BMW wiring diagrams covers the different power windows in the sedan, coupe and cabrio.
  13. #113
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Thanks, I see it, and the numbers of the lines next to connection corner are the pin numbers?
  14. #114
    germany
    6/96 318is
    Quote Originally Posted by Fireball1991 View Post
    That is right. You should see the same numbers on the plastic connector shells the contacts slide into. If you have a pair of older eyes, you may need a light and a little magnification to make them out. Sections 7000.0–8500.0 contain diagrams to help find the connectors and confirm the physical pin numbering. I cross check pin numbers in various ways to avoid surprises.
  15. #115
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Thanks a lot I found it but it's still foggy... so I can't figure out which cables where to come and where to goes... so I actually looking for a scheme like this pic, or a pin outs table like the another one pic. PLS somebody help me!Screenshot_20181123-055742.jpgE36_18_Button_OBC_HUN.png
  16. #116
    May 2005
    Melb,Australia
    3.0 Euro M3, 328is track
    old thread i know. I have a 1994 m3 euro, i have everything except the "Hinged Window Relay" this part is NLA, is there another i can use? do i even need it?
  17. #117
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Its depending on what kind of car do you have because mine is sedan, so my car electronics little bit different from the other ones (coupe, compact etc.) so finally i wired it up, and i succes to bring it to life for me, but i had to replace my zke module, ind install the RMIV modul too. so here's my help:
    https://drive.google.com/file/d/0B7-...VFeTFCb3M/view
    Power windows circuit for rear section is ELE-235, but it's come from ELE-234 on page 717 and 718.
    so i made my own cable harness, and i put it into my car and BUMMMM its working now
    so i'm happy now, i hope you will too
    But here's the other one advanced question.
    How can i wire up the Check Control Modul?
    anybody has any help for it? circuit, pin outs table etc.?
    Thanks a lot guys!
  18. #118
    The Netherlands
    Thanks a lot guys!
    If your E36 as a ZKE, it can only be the ZKE 4. So you never need to replace it. Just recode.
    IG:
  19. #119
    Sep 2017
    Hungary
    1997 BMW E36 320i
    I had to replace it because my old one has 4 connector and the New one has 5. My old was ZKE 4 LOW, and the New one is ZKE 4 HIGH. i didnt code anything. I just installed them and here we go... Its workin.
  20. #120
    Mar 2008
    Metavers
    99 M3
    what size wire should I be using for the harness?
    The Atomic City
    X5 328i 325iT Z3
    Another old thread... I wonder about power vents on a ti....
  1. E36 FS: BMW E36 M3 Coupe Electric Rear Window Switches (Power Vents)
    By M3C in forum Interior Lighting & Body Parts
    Last Post: 09-16-2018, 04:11 PM
  2. 1992 E36 Coupe Electric Rear Vents -Retrofit
    By bmw4life92 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-16-2015, 06:56 PM
  3. E36 FS: BMW E36 M3 Coupe Electric Rear Window Switches (Power Vents)
    Last Post: 10-25-2012, 07:35 PM
  4. FS: Rear Power Vents E36 M3 Coupe (electric rear windows)
    Last Post: 01-24-2011, 12:13 PM
  5. retrofit coupe electric rear windows
    By zed///M in forum 1991 - 1999 (E36)
    Last Post: 10-29-2005, 07:10 AM
