Page 21 of 26 FirstFirst ... 11121314151617181920212223242526 LastLast
Results 501 to 525 of 641
Thread: What did you do to/for your e46 today??
  1. #501
    Dec 2015
    Vermont
    2 330xi's, 1 330i ZHP
    IMPORTANT UPDATE: Washed the car, unlatched the hood to clean the engine bay, and noticed that the hood latch was camming against an inner edge when lifted--flexing the right side of the affected grille out 1/8" or so. That, of course, is totally unacceptable, so I dremmeled said edge down and almost totally eliminated the issue. The fault for the interference may rest with my car, because the locking mechanism on my car looks pretty worn (perhaps requiring a larger range of motion than is standard). At any rate, I wanted to let people know... On an aside, I--of course--somehow knicked the surface finish of the grill during my labors. Then, I made it worse trying to use my Dremel tool polishing attachments to repair. I quit while I wasn't too far behind and dug out various grades of emery paper which fixed it up just dandy. The grille is solid, black plastic--no paint or other coatings--and is easy to repair. I like that.
  2. #502
    South Carolina
    2004 330 vert 2004 X5
    Replaced the fuel pump 2 days ago. Yesterday did an oil change in the morning. Replaced radiator, expansion tank, tstat, water pump, upper/lower rad hoses and a few misc parts and a bunch of orings in the afternoon. Not exactly a piece of cake but it's done. Next job is new plugs and I'll be ready for my 900 mile trip to my new home.
  3. #503
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    Replaced belts on the M3. For those unaware you can do this without removing the fan. Still have to remove the airbox and side shroud but you can move the belt around the fan in about a minute which I find much easier than removing the fan and shroud. Also while I was in there I checked all of the pulleys and they also needed service. If you have the grease you can repack these fairly easy also. Since I have the time and like to tinker I decided to buy new pulleys and then repack the old ones. If you do not know, a pulley that spins freely needs maintenance, either replacing or repacking. When you try to spin a new sealed pulley the resistance is the grease.
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
  4. #504
    Dec 2015
    Vermont
    Replaced all three under-body covers and a bunch of rusty or missing fasteners on my 2005 330xi--totaling $500+ (OUCH!), courtesy of ECS Tuning. The front one was cracked, and the others were crudded up pretty bad with rusted fasteners, and I just couldn't bring myself to install one new cover in combination with the old ones (yup, I'm anal like that). I do, however, plan on refurbishing them as it wouldn't surprise me if they come in handy at some point.
  5. #505
    Dec 2015
    Vermont
    Today, I received my 25% off Shark Injector from Turner Motorsports, and it installed without a problem. Oddly, I had ordered one from Bavarian Auto that failed to talk to my ECU. They gave up quick with an "Oh well..." but were kind enough to refund my money (more than I paid to Turner). I harbored hope it was a defective device or possibly the wrong one, which must've been the case, and was only waiting for them to go on sale (which they still are). I'm pretty damn happy about it--the car seems a little snappier, and I appreciate the new 7,000rpm redline.
  6. #506
    South Carolina
    Pulled the seats and detailed the interior. Then I washed the a engine bay. Next was an application of tire shine. Tomorrow should be perfect for claybar and a buff.
  7. #507
    Dec 2015
    Vermont
    Recharged my A/C... guess what: didn't work. : (
  8. #508
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Question to change, or not change, my steptronic automatic transmission fluid!..... BMW people generally say yes. No, it never trailered, didn't live in the Rockies, but junior did learn and drive on this car...his first car! 6 months later, car is on the market.....There is a BANG between shifts sometimes, and in the morning no drive for 5 seconds. I am told that there could be an issue with the C1-clutch, or a pressure-to-compensate defect.....anyone?
  9. #509
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Quote Originally Posted by Eaglesail View Post
    Change the fluid and filter, then get the EGS updated. If the bang is during the 1-2 shift, then chances are the 1-2 shift accumulator spring is broken.
    The no forward drive when cold is caused by a manufacturer defect in the C1 clutch tolerances. Upping the line pressure via fluid change and EGS update usually resolves this.
    Or continue to ignore maintenance and end up on the side of the road at the most inconvenient time. Your choice.
  10. #510
    Feb 2014
    Dutchess County NY
    05 325xi 5 speed
    Used a heatgun to turn the bumper trim to JET BLACK - yes it works
  11. #511
    Mar 2017
    After now 3 weeks driving this 3 with 116k...I've learned a bit more. Engine and transmission mounts (14 years old) ...Breaks-power steering- GM-BMW steptronic transmission..all need to be renewed with new filters and fluid changes. Until I see a spectrographic transmission oil analysis, I will not change the atf..if heavy metals..an abused transmission...I will plan on other means to address.
  12. #512
    Mar 2014
    Cincinnati, OH, USA
    2001 BMW 325i
    Nothing too exciting. Changed the oil and rotated the tires.
  13. #513
    Feb 2016
    Hickory/Charlotte
    things with wheels
    Removed my tint. Rear window was delaminated in the lower corners.
    Sent from my Nexus 6P using Tapatalk
    AW | NBL | Mtech-1 | H&R | 17x9 ET30 Arc 8
    ( ͡° ͜ʖ ͡°) by Brandon Smith, on Flickr
  14. #514
    Aug 2017
    Portland, OR
    2000 328i
    Rear tires last week. New turn signal stalk will arrive later this week. Just ordered a new rear window regulator and motor yesterday that I will hopefully have by the weekend so I can get it replaced. New front tires are another week out. Slowly but surely I'm getting things done.
  15. #515
    Dec 2015
    Fresno, CA, USA
    2005 BMW 330Ci Coupe
    Simple but needed to be done, I cleaned and re oiled my K&N Panel air filter.. lol.
    I'll definitely add to this post soon, doing a small cooling system overhaul including water pump, upper/lower hose, thermostat, and belts when I get my fan clutch tool from eBay .... btw anybody got one I can borrow or buy for <$10? (That's the eBay price lol) I'll pay for shipping to Fresno CA.
  16. #516
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Replaced the left rear wheel bearing. Not a fun job.
  17. #517
    Aug 2011
    aurora, co, usa
    94 325is vin# ef44406
    Quote Originally Posted by curry View Post
    Nope, not me... when my e46 needed one, I researched the job & said " screw it," and took it to a shop.
    The $$$ was worth it vs the headache & hassle.
  18. #518
    Dec 2015
    Fresno, CA, USA
    Quote Originally Posted by jwwetzel View Post
    What's the deal with that? Is it some horrible annoying work or what lol
  19. #519
    Sep 2008
    Sandy, Oregon
    How much did they charge you?
  20. #520
    Aug 2014
    Lawrence Kansas
    A rear wheel bearing is something I never want to do again.
  21. #521
    Sep 2008
    Sandy, Oregon
    I'm going to still do the right one, but that should be much easier as there is no exhaust system to drop. Maybe when I get back from vacation.
    Quote Originally Posted by dhurley34 View Post
  22. #522
    Aug 2014
    Lawrence Kansas
    I did the left rear as well and that exhaust really does complicate things.
  23. #523
    Aug 2011
    aurora, co, usa
    Quote Originally Posted by Leothelion092 View Post
    It's a press on bearing, you've got to press the old one off first. If you're a carport mechanic like me with basic tools, it's a bitch to do if you haven't done it before.
    I built front struts on my old e36 once... took me over a day doing it myself... yes, I'm not a mechanic, but I try.
    Now I'm more selective on what I try to do myself.
  24. #524
    Aug 2011
    aurora, co, usa
    I went to a long established shop with a good reputation... that's also a customer of mine. They charged me $365.00 including part(fag wheel bearing) labor & taxes.
    Also gave a vehicle check up & 2 year warranty on parts & labor. All in all, I think it was worth it.
  25. #525
    Dec 2015
    Vermont
    Started having increasing front vibration with increasing speed which turned out to be a sticking caliper. $267 for parts and labor... my only complaint is I now have a single gold-colored caliper.
  1. What did you do to your E46 today? (v.3)
    By WoLF in forum 1999 - 2006 (E46)
    Last Post: 09-17-2022, 04:01 PM
  2. What did you do to your e46 today?
    By gangly in forum 1999 - 2006 (E46)
    Last Post: 02-14-2012, 12:18 AM
  3. What did you do to your E36 today?
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 01-09-2008, 08:54 PM
  4. So what did you do to your e46 today?
    By Smilez in forum 1999 - 2006 (E46)
    Last Post: 08-22-2007, 11:58 AM
  5. what did you do to your M today?
    By mr rolleyes in forum 1992 - 1999 M3 (E36)
    Last Post: 10-05-2006, 11:01 AM
