Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 129
Thread: E21 Group 2 Build - Turbo S54, E46 running gear
  1. #101
    Nov 2015
    E21
    We had to modify the front coilovers to sit lower in position than a stock E46 to be at proper ride height and to keep the shock towers from sticking out above the hood. Worked out nicely I think...
  2. #102
    Nov 2015
    E21
    Details of the newly modified rear suspension arm (I think BMW calls it a Z link) that controls toe alignment.
  3. #103
    Nov 2015
    E21
    One last post for now....
    After many moons of wrangling and stressing... My Group 5 kit has finally been finished and will be shipped from Europe sometime next week!
  4. #104
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Nice on the toe link heim. Is that a 3/4 or 5/8? Much more freedom of movement on compression of the Z arm using a heim than aftermarket bushings for that. Just like the E36 Using the factory slotted toe carrier and aftermarket bushings or limiter spacers doesn't allow much change. The area is really mean to pivot and the heim is about as free as can get while being very direct.
    Do you have heim jointed sleeves for the rear camber adjuster? I can give some links if your looking to make your own.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    "If it flys, floats, or f*cks, rent it!"
  5. #105
    monterey, ca.
    e21, e30 m3. e46 330ci
    Quote Originally Posted by brettkcherry View Post
    I'd love to ride along with you for parts of your PNW tour if you didn't mind. Hit me up when you get closer to it and know what your route will be taking.
    hey bret, its 2 years to the date that you wrote the above and i thought that i should hit you up...... last march i bought that f800gs and moved to the san juan's.
    as for this tread, i really like the direction you've taken, well done.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
  6. #106
    Sep 2009
    Toronto, ON, Canada
    1980 BMW 320i
    The workmanship on this build is incredible. Please keep up the updates.
  7. #107
    Nov 2015
    E21
    Brought the E21 home recently (finally done with all the suspension/cage/chassis work). Here's the last glam shot on the lift... I so wish I had one at the home garage
    In the garage, sitting on all four tires for the first time in over a year:
    Plenty of room up front for intercooler, radiator, etc.
    As stated previously, I decided to go with the Group 5 flares but they haven't arrived yet. Since I still have the group 2 stuff (currently for sale!) I plugged it up there to see how much ground clearance I'm going to have up front... not much! Given that it's so low I'll be adding a cup car air lift system like this one: https://www.stanceparts.com/product/...it-front-rear/
    Trimmed the stock dash to fit around the cage. It's looking good, but will be much better with a nice Alcantara wrap finish.
  8. #108
    Nov 2015
    E21
    Second angle on the dash:
    Printed off a template for the AIM MXG display, looks like it will fit in nicely...
    Next steps are to locate pedal box, steering column and final seat positions. Then I can bend up and install the tubing for the transmission tunnel, then on to sheet metal!
  9. #109
    Nov 2015
    E21
    Quote Originally Posted by autox320 View Post
    Thanks for the reply. The threaded end of the heim is 3/4, the eyelet (or whatever it's called) side is 1/2 inch. I actually am looking to make my one upper and lower control arms for the rear. The stock E46 arms are non-adjustable so camber is fixed. Those links would be greatly appreciated, thank you!
    Quote Originally Posted by Tom D View Post
    The timing of your post was crazy! How are the motorcycle and the San Juans treating you? I wish we could ride together sometime but I sold my Ducati (to help pay for the E21 project) and my fiance subsequently sold her Triumph, so it pains me to say that I am bikeless at the moment.
    Thank you for the praise on the car :-)
    Quote Originally Posted by EauRouge2002 View Post
    Thank you, much appreciated! I'm doing my best to update when I get around to doing some work ;-)
  10. #110
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    I've had my suspicions from the build quality and speed that you have three hands, this is all the confirmation I need
    -John
  11. #111
    Aug 2001
    NC
    Sweet VW bus !
    I'll get back to you on the links and post here.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  12. #112
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    This thing just keeps getting cooler and cooler. Does the hood even clear the wheels?
  13. #113
    Nov 2015
    E21
    Quote Originally Posted by Somjuan View Post
    lol :-D
  14. #114
    Nov 2015
    E21
    Sweet VW bus !
    Thanks man. The bus has been a fun project as well. We bought it a few years ago and it was pretty ratty with, believe it or not, a V8 swap from a Lincoln. We ended up doing a full restoration and remodel of the interior plus a water-cooled 2.5 liter Subaru Legacy engine swap. She cruises so nicely now
  15. #115
    Nov 2015
    E21
    Quote Originally Posted by hotdish View Post
    Thanks man... it's sure been a fun experience. I've never done any kind of vehicle like this before. There's a lot to learn and a lot to potentially mess up along the way.
    The answer to your question is: barely. This is one of the things that keeps me up at night. I have been waiting for months to receive the shipment of the new Group 5 kit so that I can measure and fit the correct wheel size. The goal is to have 18s on all 4 corners but I might have to change the size up front to fit under the fender. Alternatively, I might just have to modify the hood and fenders to be one single piece to make it all fit. The trouble is, even if I go with a smaller wheel, I'm having difficulty finding tires that are both wide enough and have a shorter overall height. It's a dilemma that currently only exists in my head... at least until the kit arrives and I can measure it all out for myself. *crosses fingers*
  16. #116
    Aug 2001
    NC
    rear camber arms could make a nicer set similar to these
    ECSTuning sells several types
    I hate aluminum bar stock for this application so would use steel / moly hands down. Especially with your power output i'd only use steel or moly.
    So I'd chose length you need and use these pre made swedged tubes from Speedway
    https://www.speedwaymotors.com/5-8-I...ku=91034558-15
    combine with favorite heim
    I like QA1's stuff; https://www.qa1.net/rod-ends-and-related/rod-ends
    I use the part numbers off QA1 and punch it into Speedway motors for better pricing and to combine items for less shipping.
    Since E46 at the HUB side you'll want to use all factory "bearing" replacements.
    Lemfoerder part number 33321140345 " Trailing Arm Mount Bushing; Rear Upper; Trailing Arm to Control Arm"
    These work at both HUB points where the spring perch connects to the hub and where the lower camber arm connects to the hub. Can verify but I'd check to see if also fits the DIFF side of the spring perch I'm not sure.
    I bought some here for our X3
    http://www.autohausaz.com/pn/33321140345
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  17. #117
    Houston, Tx
    '78 320i
    I really have nothing to say other than the things some of yall put together are things of beauty. Absolutely nuts.
  18. #118
    Jan 2015
    Australia
    Unknown
    Any updates on this? Super cool build.
    WTB:
    S50/S52 cams + trays
    Rallyroad 60mm gauge holder + 52mm gauge holder
  19. #119
    Dec 2016
    Boise idaho
    Too many
    Where did you source the group 5 body kit from?
  20. #120
    Apr 2015
    United States
    1974 estoril blue 2002
    Damn man, this build is legit. Keep it up!
    Sent from my SM-G960U using Tapatalk
  21. #121
    Feb 2019
    Yelm, WA
    1982 BMW E21 320i
    Hey Brett! Would be great to meet up to see what this looks like in person! I want my E21 to be tubed like that as well!
  22. #122
    Jan 2018
    Bayshore NY
    E30m3s54. E30 3.1turbo
    i love how this car went from 0-3000000000000 real quick sick job dude
    For e21 bracket kits email us
    john@silokin.com or check us out via
    facebook/Instagram : SILOKIN AUTOMOTIVE INC
  23. #123
    Apr 2008
    Wakefield, MA
    bmw e21 321
    Hey Brett,
    I am also building an E21 group 2 race car (much more tamed version with a stock motor) and was wondering if you could help me out with group 2 kit selection.
    I want to order it from the same french company as you did but I don’t know if I should go with 13 inch or 15 inch version?
    Do you know what the difference is? Is one wider than the other?
    I will be running 15x9 wheels (-20 offset).
    I called them yesterday but the guy who answered the phone did not speak english.
    Thank you very much for your help.
    Vladimir
  24. #124
    Nov 2015
    E21
    Hello all,
    It's been awhile since I've posted updates and am doing so now with a bit of a heavy heart. After many years of work, I am sadly having to let go of this project. Life circumstances have changed for me and finishing this car does not seem tenable anymore. I am posting to gauge any interest in the sale of this car.
    Here are the full details:
    E21 with full tube frame chassis
    S54 with turbo intake and exhaust manifolds (DOC Top mount & HPF black powercoated)
    E46 M3 front and rear suspension w/ custom Ohlins shocks
    E36 M3 5 speed (ZF)
    Full Group 5 Fiberglass widebody kit
    CAE Ultra Shifter - E46 M3
    2 Sparco EVO II seats
    If you are interested in knowing more details enough to acquire this project for yourself, please contact me at:
    brettkcherry8@gmail.com
    I have more photos, full invoices and knowledge about the final design intentions.
    https://drive.google.com/drive/folders/13oKmtxFoLCAN4MoIRdYGJ66VyVm6W9LP?usp=sharing
  25. #125
    Aug 2001
    NC
    Hello all,
    E36 M3 5 speed (ZF)
    I feel ya man, but sucks to see ya pass the torch on this machine. Be sure to post interest on R3V, NASA, TrackHQ, and of course Bimmerforums Track sections.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  1. E46 Drift Build turbo 5.3 lots of goodies
    By sidewaysfab in forum Drifting
    Last Post: 06-29-2017, 11:00 PM
  2. E36 Track Car Build Part II: Turbo S54 Swap
    By M3 Muscle in forum Track Car Builds
    Last Post: 03-10-2014, 01:06 PM
  3. Should I sell my E46 M3 to build Turbo E36
    By GuitarKid93 in forum 2001 - 2006 M3 (E46)
    Last Post: 10-31-2007, 11:10 PM
  4. Replies: 7
    Last Post: 03-14-2007, 09:46 PM
  5. Twin Turbo S54 E46 M3 by DA Motorsport
    By eurotekm3 in forum Forced Induction
    Last Post: 09-21-2006, 03:20 PM
