"Error control unit or trottle valve"
Much more likely your throttles are bad IMO. That's what I would start with.
eml.....as already emailed (use a different bosch number and swap the eprom..... far cheaper).
BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
BMW 850 CSI november 1994 (EU spec)
Thanks for answering DR T. So the abs pump was the problem? Did you refurbished it or buyed a new one or did you repair it yourself?
Can you give me more info about this matter because I have now just the same problems with my E31. Thanks
Sicily, disregard my answer! Sorry, I did replace the abs pump previously but that was not related to this issue.
It wasn’t until I re-read this thread that I realized what the fix was to this particular problem.....a new EML.
See my post above. Diagnosed with laptop first and then a replacement EML unit fixed things completely.
Ok thanks for the info
Good evening everybody. So I changed the eml an dme's with a friend his E31 and the problem stays. His car is running well with my eml. We changed also the egs from his car into my car. Same problem and my egs is running well in his car. So I think those to control units are not the problem. Thottles have been refurbished 5000 km ago.
When the engine is cold the eml lamp stays out until the car is warm. There is enough power but when you do a sprint a release the gaspedal the eml lamp appears. Thas asc lamp is going on after a few 100 meters. When I do the blink asc test I get error 2. When I put out the module the error clears but when putting i back in it comes back. Can ik maybe be a lambda problem. Anyone any idees? Thanks
Unfortunately, IMO I think the best way to diagnose this is by running computer diagnostics (DIS/INPA) to locate the fault.
It seems to be a problem to find BMW dealers in my region in Belgium that have still a working DIS/INPA. For the 3rd time I put out and in the relais in the abs box and than the car rides without any problem for about 20 miles. After that the asc light goes on and also the eml is lightning up. If I don't put out and in the relais the error comes already after 1 mile. What is your opinion? Are the relais the problem? Any advice is welcome. Thanks
There is an error code that could help you. The code is initiated by pressing the ASC button when turning the iginition to "on", I'm no absolutly sure about the procedure. You can surely find information about this in the repair manuals or some one else might be more informed than I.
ABS/ASC blink codes from E32, probably same for E31
German version:
ABS/ASC-Blink-Code
- Bremspedal und Schalter "ASC" gleichzeitig drücken
- Zündung "an"
- Bremspedal und Schalter loslassen
- ASC-LEUCHTE fängt an zu blinken
BC = BlinkCode
BC 1 = kein Fehler
BC 2 = EMS Fehler
BC 3 = Motronic Fehler (DME/ EMU)
BC 4 = Drehzahlgeber Fehler hinten links
BC 5 = Drehzahlgeber Fehler hinten rechts
BC 6 = Drehzahlgeber Fehler vorne rechts
BC 7 = Drehzahlgeber Fehler vorne links
BC 8 = ABS-Magnetventil hinten links
BC 9 = ABS-Magnetventil hinten rechts
BC10 = ABS-Magnetventil vorne rechts
BC11 = ABS-Magnetventil vorne links
BC12 = ASR-Plungenventil Fehler hinten links
BC13 = ASR-Plungenventil Fehler hinten rechts
BC14 = Ventilrelais Fehler
BC15 = Rückförderpumpen Fehler
BC16 = Speicherladeventil Fehler
BC17 = Langzeitfehler Druchüberwachung
BC18 = Leckage Fehler (Wird auch angezeigt wenn Druckspeicher(Gaspatrone) im ASC+T Hydraulikblock schadhaft ist (zB. leer))
BC19 = Druck Fehler
BC20 = Getriebebeinflussung Leitungsfehler
BC21 = ABS/ASR-Regelgeräte Fehler
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein)
BC23 = Option pin Leitungs Fehler
Zu BC 22:
TD Signal Fehler
Regelgerät Kl. 55
Zündung aus
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen
Leitung vom ABS/ASR-Regelgerät Kl.55 zum Motronic- Steuerg. Kl.6 auf Unterbrechung/Plus-/und Masseschluß prüfen.
wenn i.O.
Fehlerspeicher Motronic auslesen
wenn i.O.
ABS/ASR-Regelgerät tauschen
Translation, hopefully correct:
- push brake pedal and ASC switch simultaneously
- Zündung "an" / ignition on
- Bremspedal und Schalter loslassen /release brake pedal + ASC switch
- ASC-LEUCHTE fängt an zu blinken/ASC light starts to blink
BC = BlinkCode
BC 1 = kein Fehler / no fault
BC 2 = EMS Fehler / EMS fault
BC 3 = Motronic Fehler (DME/ EMU)/ DME/EMU fault
BC 4 = Drehzahlgeber Fehler hinten links/fault speed indicator rear left
BC 5 = Drehzahlgeber Fehler hinten rechts/fault speed indicator rear right
BC 6 = Drehzahlgeber Fehler vorne rechts/fault speed sender front right
BC 7 = Drehzahlgeber Fehler vorne links/fault speed sender front left
BC 8 = ABS-Magnetventil hinten links/ABS solenoid valve rear left
BC 9 = ABS-Magnetventil hinten rechts/ABS solenoid valve rear right
BC10 = ABS-Magnetventil vorne rechts/ABS solenoid valve front right
BC11 = ABS-Magnetventil vorne links/ABS solenoid valve front left
BC12 = ASR-Plungenventil Fehler hinten links/fault ASR plunger valve rear left
BC13 = ASR-Plungenventil Fehler hinten rechts/fault ASR plunger valve rear right
BC14 = Ventilrelais Fehler/ fault valve relay
BC15 = Rückförderpumpen Fehler/ fault recycling pump
BC16 = Speicherladeventil Fehler/fault storage load valve
BC17 = Langzeitfehler Drucküberwachung/fault long time, pressure control
leakage fault (is also shown when pressure vessel (gas bomb) in ASC_T hydraulic block is damaged (for example empty))
BC19 = Druck Fehler/ fault pressure
BC20 = Getriebebeinflussung Leitungsfehler/fault wire transmission
BC21 = ABS/ASR-Regelgeräte Fehler/fault ABS/ASR control modules ffaulty
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein) TD-signal fault (should be the speed impulse)
BC23 = Option pin Leitungs Fehler/option pin line fault
Zu/to BC 22:
TD Signal Fehler/TD signal fault
Regelgerät Kl. 55/ control unit terminal 55
Zündung aus /ignition off
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen/disconnect from the ABS/ASR regulator unit and MOTRONIC module bank left the connectors
check the line from ABS/ASR regulating unit terminal 55 to MOTRONIC- control module terminal 6 for interruption/plus-/and ground connection
wenn in Ordnung / in case that is o.k.,....
Fehlerspeicher Motronic auslesen/read fault codes from DME
wenn in Ordnung/in case that is o.k.,....
ABS/ASR-Regelgerät tauschen/change ABS/ASR control unit
Thanks for your replys. I did that blink check. It is error nr 2 EMS/Fehler EMS Fault. What is the ems? Which module is that?
When you disconnect the ABS/ASC module the error goes away when you do the blink test but it comes always back.
EMS = electronic throttle = Elektronische Motor Steuerung (?)
somewhere here in the tester user manual it says" The EML/EMS selection is for vehicles with an electronic throttle. .." https://www.snapon.com/Files/Diagnos...AZ0025B42B.pdf
on a German forum I read that they cleaned the throttle valve and the fault disappeared.
Maybe you also test the gas pedal throttle potentiometer. http://www.bimmerboard.com/members/r...rottle-pot.jpg
http://www.bimmerboard.com/forums/posts/694988/
Thank you for the reaction Shogun
The throttles are refurbished by wokke 2 years ago and I also changed them with a good working E31. Problem stayed.
I will check for the throttle potentiometer but it is strange that the fault stay away when you put out and in the abs relais.
E32 Bentley Repair Manual shows the data for testing on page 130-45.
EML Pedal Position Sensor Test
pedal at idle position
manual transmission 0.34-0.43 VDC
automatic transmission 0.35-0.45 VDC
pedal at full throttle
manual transmission 3.1-3.3 VDC
automatic transmission 3.7-3.8 VDC
EML connector pedal position test pin
M70 DME 1.2 brown/violet pin 1
M70 DME 1.7 blue/brown pin 20
M30 DME 1.3 blue/brown pin 20
terminal numbers are molded in the EML connector face. These numbers are very small and may be difficult to read.
set a gap of 3mm / 0.118 in. between accelerator pedal bracket and the idle stop.
To check adjustment, peel back rubber boot from EML harness connector (round big plug left side engine bay close to the diagnosis port) and connect digital voltmeter between specified pin in connector and ground.
Hello
Problem is solved. It was a wrong contact in the cable behind the engine that was going from the asc module to the eml. I want to thank everybody for the input.
Hey! I experience what I think is the same problem as yours. I intermittenly get EML light an bank 1-6 shutdown. Often a recranks, key on off will fix it. This happens usually when warm after startup. Sometimes at coasting near idle. I also get the acs light on after a little while, but not always. I earlier got a constant no bank 1-6 start, that turned out to be a bad distributor. And also in that process I got a used eml module, since the car was still all weird. New rotors, 12 new spark plugs. New ignition wires both banks. Throttles cleaned and swapped. New coils. New fuel filters. Swapped dme connectors, swapped dme relays, swapped mafs, problem do not switch side. The car can sometimes perform good now, without eml light, so it is a lot better and the main issues are solved. But still got eml light now and then, espesially when warm. Have a diagnose pc, and when I get eml light it displays code 20 i belive it was, dk switch bank 1-6. Not much info on the web on fault codes from the eml unit. Since I also get asc light now, It could be the that something electrical between the modules is gone bad or halfway bad since its not constant. Any thoughts?
Im also going to do a propper resync of the throttels to rule that out, since batterys have been disconnected. They are new and fully charged btw. I always get eml light on and off after 2-3 seconds when the ignition is turned.
