Results 1 to 25 of 43
Thread: EML and ASC lights on? - solved
    Toronto, Canada
    BMW 850CSi
    During the past couple of days, while the car is warm and I'm coming to a slow coast eg. towards red light or in a parking lot, the car shuts dies OR the EML and ASC lights both come on and I loose most power. A subsequent restart may/may not resolve this...or it re-occurs during the next coast down. Heavier throttle and acceleration seem to help cure it for a period of time.
    Last night after a re-start, it started revving up and down between 1-2k rpm by itself repeatedly until I shut it down.
    What could it be? Dirty throttle bodies? Fuel pumps? Bad gas? Loose connection somewhere? DME's? Something else?
    Nov 2008
    Maryland
    not enough
    because of the varying symptoms...could it be your batteries dying? Or perhaps dying alternator (which would then cause low batt voltage) since higher revs seem to help?
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
    Toronto, Canada
    BMW 850CSi
    Then it wouldn't start after sitting overnight, no? Or have a weak turnover. But, she cranks like a banshee...
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by Dr. T View Post
    Snap, you're right. Unfortunately it looks like you may have to start the dreaded diagnostics process...unless you're able to plug it into some diag software? Have you noticed if it's only one bank that's shutting down?
    My other projects:
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Surging possibly a failed/failing Fuel Pressure Regulator - run car for a minute, shut down and then pull vacuum line from each FPR and examine for wetness caused by leaking/ruptured FPR diaphagm - if vac lines arent wet or fuel doesnt squirt out of FPR vacuum outlet, they are ok. Other cause of surging I have seen here is a bad MAF.
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Toronto, Canada
    BMW 850CSi
    Thanks Tom...will check the FPR's. They were changed along with both MAF's a couple years ago.
    Luis: No, the engine seems to run fine....slightly rougher, but not like when it's in LHM. Just, no power at all when the EML/ACS lights on.
    Aug 2003
    Woodinville, WA
    '87 L6, '97 840, '02 M5
    Charge the batteries overnight. Unlock the OBC and you can see real-time output from the Alternator. That will be the easiest way to eliminate charging system issues.
    1987 L6
    1997 840ci
    2000 740i Sport
    2000 M Roadster
    2001 M5
    2002 540i Sport
    2002 X5 4.6is
    2003 530i Sport
    2003 M3
    2003 Z3 3.0
    2005 X5 3.0 Sport
    Toronto, Canada
    BMW 850CSi
    Re-surfacing this thread to see if anybody has any new ideas....
    The same symptoms now occur immediately after starting the car....EML and ASC lights come on....and it either:
    1) Runs normal or with high idle or in Limp-Home mode or
    2) Begins to surge between 1250-1500rpm or even surged to redline at one point. NO throttle reponse at all (as if it's disconnected).
    I initially thought it was DK motors. Just installed new units from Wuffer with no change. The car is not driveable. Any ideas before I tow it to the dealer for diagnosis????
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Towing to dealer is a very bad idea.. you gonna have a bad time if you go that route.
    Do you have any sort of means of diagnostics to see the codes? I suspect EML computer could be involved.
    Aug 2003
    Woodinville, WA
    Had a similar problem on an e34 530i. I'm not at home but have a friend turn the car on and watch the DK motors. IIRC there is still a physical cable that controls the ASC flap. It's possible that cable is old/rusty/binding and when it opens the flap it gets stuck. I got a car free that the owner couldn't diagnose with this exact problem and it was a $30 cable. So check the ASC system first.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Quote Originally Posted by dragon850 View Post
    Agreed. INPA and an ADS cable would be a great place to start and easy to setup/operate. Sounds like a floating input somewhere (open sensor).
    Toronto, Canada
    BMW 850CSi
    EML and ASC lights on???
    Quote Originally Posted by BMSman View Post
    Towing to dealer bad? Lol, yeah bad for the wallet!!
    Been considering getting diagnostic setup for a while....but have not made the leap.
    Where do I begin? I do have an older laptop with win xp. Links to software/cable purchase???
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    I will pm you later on the diagnostics
    Sent from my SM-G925T using Tapatalk
    Toronto, Canada
    BMW 850CSi
    Did you send that PM?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Sending now, sorry for the delay
    Toronto, Canada
    BMW 850CSi
    No problem..... Just thought I might have missed it
    Mar 2013
    netherlands
    850 CSI
    It runs: dme's ok
    No throttle response ..... EML or pedal. No stable revs....would start looking at EML.
    Did you look at the inline FUSE in the trunk..... if that one is "half" faulty you could get voltage drops (the computers do not like that).
    And diagnostics software (full laptop setup with dis, inpa, etc ....) is free......I build a full set for our club, you just need a dell 830 laptop and cable (lots of E31 owners already using it).
    BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
    BMW 850 CSI november 1994 (EU spec)
    Toronto, Canada
    BMW 850CSi
    Haven't checked the inline fuse yet. That's next...
    Where is the EML located? Is it next to the DME's? Guess I will need to get the software going and run diagnostics....
    Mar 2013
    netherlands
    850 CSI
    EML next to the DME's (the one at the back)
    Toronto
    330i ZHP, 850i, 92 318iC
    I will put out the offer that I have a diagnostic computer built by our old forum Moderator when he was doing such a thing. If you would like to use it, I am also located in Toronto. PM me
    Toronto, Canada
    BMW 850CSi
    Sounds great since that would get me up and running the quickest! Will pm...
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Did you do "Stomp Test", turn on ignition, when eml light goes off step on the gas pedal 5 times for right (1-6 cyl) or 6 times for left (7-12) side. Then count the blinks from the "Check Engine" light. It will give you a 4 digit code. There are tables available in the forum.
    Toronto, Canada
    BMW 850CSi
    Quote Originally Posted by peake View Post
    No, because the Check Engine light is not lit up. Only the EML and ASC (Traction Control) lights are on.
    Will the stomp test or Peake Tool work for these?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    NO ans NO, you need proper diagnostics. IMO, your throttles are bad, step 1. Step 2 your EML computer is bad.
    Toronto, Canada
    BMW 850CSi
    Ok, so I finally got a laptop running with INPA and DIS and come up with the following:
    INPA:
    1) EML: 2 errors: 1) Internal error control unit 2) unknown error location
    2) DME 1: Error 73 Speed signal
    DME 2: Error control unit or trottle valve
    DIS:
    1) DME (cyl 1-6): No errors
    DME (cyl 7-12): Error 73: Road-speed signal
    Explanation: Effect in the event of a fault:
    -with HG: bucking when driving at constant speeds close to idle speed (EML SG controls to idle speed)
    -loss of power (EML SG limits DK- potentiometer angle)
    -FGR has failed
    2) EML: Error 9: EML-system fault warning lamp (The EML SG has detected and set a fault in the EML warning lamp.
    Error 8: Internal control-unit fault (A system fault has been detected during the control-unit self-test)
    -The engine power output is reduced by limiting the opening speed and the DK angle
    -The EML warning lamp lights up
    Notes: If the EML SG detects a fault in the memory chips during operation, the fault "8 Internal control-unit fault" is stored
    Possible causes: - Power supply of the EML SG
    - Battery condition bad
    Test: -Clear fault memory
    -After taking the car for a test run, call up memory again
    -If the fault has been stored again, replace the EML SG
    So what do you guys think? EML unit itself is at fault and needs replacing? Anybody have a spare one?
  1. cel, eml, and asc lights are on (dme)
    By bingbonge39 in forum 1996 - 2003 (E39)
    Last Post: 04-20-2015, 10:15 PM
  2. EML and ASC/DSC light comes on - 2001 325i
    By frocco in forum 1999 - 2006 (E46)
    Last Post: 05-02-2008, 09:52 AM
  3. eml and asc light loss of power
    By timd003 in forum 1999 - 2006 (E46)
    Last Post: 03-23-2007, 09:46 PM
  4. ASC Light and performance issue solved !!!!
    By iToast in forum 2004-2010 (E60,E61)
    Last Post: 01-21-2007, 10:45 AM
  5. engine/eml/asc lights all on
    By soundcitation in forum 1999 - 2006 (E46)
    Last Post: 10-26-2006, 08:20 PM
