1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
70* today. Rode the motorcycle to work
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
LOLOLOL too bad my POS isn't running.
Opelika eh, get to see what the good ol boys all about. Be warned, everybody you meet out there is related. Bobbys wife mary-ann is also his sister. And his cousin.
Their daughter has three eyes and fourteen fingers. And a toe on his forehead.
And if you see a group of middle aged pot belly hicks dancing around a fire wearing bed sheets, slowly back away, don't say a word, and leave.
this will be the third year in a row for this trip. i wouldn't say i have the area committed to memory, but i have the lay of the land down pretty well.
inbreeding is much more prolific in your part of the country than mine. so it's always interesting to observe when i travel.
we have those good ol' boys in white up here too. hell, Indy has a sordid past with the boys in white. whitestown and brownsburg are neighboring suburbs just outside Indy, and the mascots of the New Palestine MS & HS are the Dragons.
it was an interesting place to live, but i now have almost a full county between my house and Indy...and i'm glad for it.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Got my trans back in. More pretty powder coated stuff I'll never see
Experiment time. Got some cheap generic fuel injection hose from the auto parts store and submersed it in some e85. Let's see how it holds up..
So far 24hrs in and no signs of any breakdown.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Incorrect logic there. The outer covering of hose is a different rubber than the inner liner unless it is submersible as Butters has said. A failed fuel line can take out your engine or cause a fire, both of which can wreck your day. Just save up a few more penny's and buy the right stuff.
I understand this. I currently have a piece of cheap, generic fuel injection hose submersed in a Gatorade bottle filled with E85; both the inner and outter lining of the hose is being exposed to E85. I plan to leave it in there indefinitely, or until it degrades if it does. If it doesn't degrade being submersed, it wont degrade serving as an external fuel hose running outside the tank, that's what I was saying.
I did buy E85 rated hose for the front half of my fuel system, but not PTFE. Since I am leaving the rear lines by the tank stock, I am just replacing them with new rubber hose. I have no reason to believe there will be an issue. But if the piece of hose I submersed in E85 begins to degrade, I will just replace the rear hoses as well...
I just run all Gates brand hose in everything in my car. It's cheap and their fuel injection hose does specifically say E85 safe. Again I think all modern hoses are but hey if it specifically mentions it obviously your safer.
