Page 8 of 186 FirstFirst 1234567891011121314151617183358108 ... LastLast
Results 176 to 200 of 4646
Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #176
    Dec 2015
    Fairbanks Alaska
    looking for E36 328i
    Quote Originally Posted by vollosso View Post
    members that have done back to back testing with open manifolds divided housings only to have gains.......
    Edited for clarity.
    the larger divided housings will flow more obviously because of its size... But it will not spool well in an open manifold. At least not in that size. It won't be as bad on a 3.2L but it won't spool like a 35r I promise you that
    4 different turbo cars/1 BB chevy/1 all motor+nitrous...7 different turbos, 4 different intercoolers, 6 different EMS systems etc etc. Looking to play E36 on boost.
  2. #177
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Honestly im not worried about it.
    Ive spent hours upon hours reading on it. Seems to be a lot of contradicting information. I really am not worried about it not spooling up well on a 3.2L.
  3. #178
    Dec 2015
    Fairbanks Alaska
    Quote Originally Posted by rajicase View Post
    Ok up to you. if you decide you can't live with it, you do have other turbine housing options.
  4. #179
    Feb 2012
    1995 BMW M3
    Yeah I figured that.
    How much of a difference in spool do you think there would be with a different housing?
  5. #180
    Dec 2015
    Fairbanks Alaska
    Hard to say and what are we comparing to? Lots of factors here but It will not spool like a 35r.
  6. #181
    Mar 2012
    Renton, Wa
    98 m3
    So ridiculous. Just run the darn turbo.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  7. #182
    Feb 2012
    1995 BMW M3
    Not really sure just wondering what to expect?
  8. #183
    Feb 2012
    1995 BMW M3
    That's what's going to happen lol
  9. #184
    Dec 2015
    Fairbanks Alaska
    I agree. Run it. Let us know and If u are not happy with its performance you still have other options with that turbo. That simple
  10. #185
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    When looking at the compressor maps of a s256sx over laid a 35r's , yes, it looks like the s256 s much more comparable to it then a 30r.
    Got the standard 1.22ar exhaust housing.
    With that size compressor, why bother with such a big exhaust side? That housing would be better suited for a high revving Evo with a nice TS manifold that needs the exhaust flow for high boost at 9k+... The TS 1.00 would've been a better match for what you want, or getting a T4 > T3 adapter and running the 0.70 AR.
    As for the divided housing on an open manifold vs. a true TS mani, it still helps. XinlinesiX ran an open, top mount T4 OBX manifold on his 845whp e34 wagon, with a divided entry 6466 and his spool wasn't THAT much worse than my friend Ben's similar set-up, when he was around 600whp on 91 craptane, but Ben is running a Radowski TS manifold, with custom cams and pistons.
  11. #186
    Feb 2012
    1995 BMW M3
    So last night was first start. Started up and idled super smooth.. went painlessly. Hopefully that luck continues...
    After quite a few changes and more delays than expected I am nearing the end. I hope.
    Today I am going to put the cooling system and lights in and take it for a drive if I can get my boost gauge working.
  12. #187
    Mar 2012
    Renton, Wa
    98 m3
    So last night was first start. Started up and idled super smooth.. went painlessly. Hopefully that luck continues... After quite a few changes and more delays than expected I am nearing the end. I hope. Today I am going to put the cooling system and lights in and take it for a drive if I can get my boost gauge working.
    yaaayyyy
    1989 535i - sold
  13. #188
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Great news. I want to read about how the S256 with large turbine responds. Note that it will "wake up" with more boost if you are starting out with low boost.
  14. #189
    Mar 2012
    Renton, Wa
    98 m3
    yes, most turbos are very flat when at low low boost
    1989 535i - sold
  15. #190
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    sweet!
    how far are you from Opelika?
    i'll be there at the end of the month for the APR distributors' conference and would love a ride!
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  16. #191
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by doktor b View Post
    sweet! how far are you from Opelika? i'll be there at the end of the month for the APR distributors' conference and would love a ride!
    I think we should plan a meet with all the twinscrew cars and the turbo cars
    1989 535i - sold
  17. #192
    Feb 2012
    1995 BMW M3
    SOOOOOOOOOOO... today was the big day! Took her out for break in and some low boostin fun.
    Lemme start with HOLY SHIT....
    I took it out for break in and some low boost(5psi) pulls. Was incredible. However I must have a boost leak as A) I am only making 5 psi on a 7.5 psi spring set up and B) it is spooling much later than it should.
    All my charge piping is welded, couplers are all super tight, ICV hoses all solid. So my guess is the BOV. It is wide open at idle and it doesnt seem to close unless I stab the throttle to 3kish. I also wasnt making boost in 1st gear, granted I only got to 50% throttle in 1st. Got to a max of 75%ish throttle in 2nd, 3rd, and 4th.
    But if this is my biggest problem im happy. 5 psi compared to my tapped out NA set up was insane, and my NA set up was absolutely great. 5 psi and what must be a boost leak was MUCH faster than my NA set up and power came on much much earlier.
    So all in all a good day, went smoother than I expected.
    I have to give a huge thanks to Vollosso. Ive said it several times, I know.. But he has helped me SO much and to get here with relatively no issues has to be accredited in large portion to him.
    sweet!
    2 hours from Opelika. But I have no problem with making a drive to meet up with you.
    Absolutely man, I cant make an accurate assessment yet as I am def having a boost leak issue somewhere. But even so and at 5 psi... damn.
  18. #193
    Manchester, N.H.
    96 332IS 6466 turbo
    You haven't even lit the match that lights the fire yet.
    Turn the wick way up, maybe 4 times that 5psi. But at your pace, don't be foolish, you truly now have a weapon that can be pointing in your own mouth if your not careful. I suggest not going too heavy into throttle around corners just yet.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  19. #194
    Feb 2012
    1995 BMW M3
    Yeah, all I know at this stage is even with a boost leak, 5 psi is wayyyy better than my tapped out NA set up. I plan to run current boost(should be 7.5psi once leak is fixed) until engine and clutch break in is done.
    Ill go from there.
  20. #195
    NY/FL
    '08 G35S, '98 M3/4/5
    Ill go from there.
    If that's the case, I'm definitely excited to join you in the spinnywhoosh club!
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  21. #196
    Los Angeles, CA
    The reason why it is way better, is because you have so much more torque all the way to redline!
    Congrats on boosties!
  22. #197
    Feb 2012
    1995 BMW M3
    Thanks!
    Drove it about 50 miles yesterday, went really well.
    Two main issues; My valve cover is cracked so I am spewing quite a bit of oil. No more driving till I get another. Its my fault, I dropped it when installing and I thought it would be fine. Not the case.
    Other issue is my BOV. It was wide open at idle and I dont think closing very quickly either. Took it out and it had the weakest spring in it. So no wonder! Getting new spring and valve cover and hope to be back on the road within a week.
    Overall I am super happy if these are my biggest problems after my first FI build...
  23. #198
    Vancouver, B.C., Canada
    '97 M3
    What is the vacuum at idle? You may have a leak in the boost gauge line.
    Sent from my GTX3582R
  24. #199
    Feb 2012
    1995 BMW M3
    20ish. I have a digital boost gauge and the hose for it is like 2 inches right off manifold. Highly doubt it's leaking. But I will boost leak test before it gets back on the road.
    Out of curiosity, what are you getting at?
  25. #200
    South Carolina
    2004 330 vert 2004 X5
    Congrats. Your reaction was the same as mine. Welcome to the club. The only thing I regret is my stock 328 has only 500 miles on it since I went turbo. Poor car is feeling very neglected. I'm going to sell it.
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
