Why not just grind on the compressor cover? Just don't want to grind on a new part? The s300 covers are definitely huge but I didn't realize the s256 cover was so tiny! Looks like a gt30
Just don't want to grind a new part lol plus I don't know how thick the cover is and I'm not really confident that grinding it alone would get me the room need. The rib that it is hitting is like 1/4" and I think that that is about how much room I need.
And yes the 256 looks ridiculous next to the 366 lol.
Not even the skinnier part of the comp cover fits better?
This is how I had my hx40.
Yes it's stupid big lol!
I don't think I'll ever need to upgrade ffs.
I seriously burst out laughing when I saw the old vs new picture.
This happened tonight!
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Vollosso in case you are reading this, regarding my "clunking, " you were right. It wasn't the trans. Two of my flex disc bolts were super loose. Kinda scary. Must be my fault last time I had the trans out.... at least it's simple!
What the? Why is the comp cover on your S256 so small?
Here's mine.
1989 E30 - M50B28 Turbo - ZF 8 Speed
1989 535i - sold
1999 M3 Tiag/Dove - sold
The guibo (giubo) bolts/nuts are suppose to be a one time use only.
I've reused mine many times as well but they are a stretch bolt with crimp style lock nuts. I bought new ones for this time around.
Hey guys,
Who has replaced the heat shield crap in the trans tunnel with something other than OE?
Since my engine is still in I was thinking I could get a knife and cut the insulation at the firewall and then replace with something from there all the way down the trans tunnel. Any suggestions that will be A)durable , B) insulate cabin from heat /noise
I replaced mine with fatmat. It works okay. Some of it melted out..
1989 535i - sold
By the transmission.
1989 535i - sold
as a side note i loctight those guibo bolts every time now.
1989 535i - sold
Anyone else used something besides fat mat?
DEI fiberglass reflective heat tape or sheeting. Works great. Mine has been in place since 2010.
