Dynojet! Thanks
Here are a few pics. Got several graphs for later and a few vids
nice power for that turbo and boost level! I was going to predict you would be well over 400whp but didn't want to get you expectations up.
What turbo is this ? Sx256 ? Or something ?
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1989 535i - sold
1999 M3 Tiag/Dove - sold
^^^corrreccct
Vollosso has the nice dyno files maybe he would be kind enough to upload them when he has time
^^Yeah I agree. I made a boost leak tester but am waiting on a coupler.
When you say go over things, do you mean boost leak test? Or anything else?
Or the dyno sensor was off.
I've had it a few times where the dyno AFR and boost was not accurate to my logs or my gauges, which are very accurate. A little leak at the hose will show wrong readings. You very well could have been in the 16# range. That would seem more likely.
1996 332IS
Built 3.2
Dyno sensor was accurate
1989 535i - sold
Raji's pulls were done unloaded.
1989 535i - sold
Ah thats right, forgot about that. 0 load on my pulls.
1989 535i - sold
You can get an add on eddy current absorber to put extra load on the roller of a dynojet. I believe what they are saying is that the absorber was turned off so the load was only the drum inertia.
Nice numbers for sure! I knew you'd be over 400 by a good bit at 16lbs.
1995 M3...Screwed
Thanks!!! Should be easy 500 with a tune revision and better exhaust and same boost level.
1st dyno pull
https://www.youtube.com/watch?v=iNa9qHxX1Kk
And dyno pull #2 sorry for horribe vid :/
https://www.youtube.com/watch?v=sv3ihm_G8T8
dude cool ypur shit. I dont know why you go off like this its ridiculous.
Inertial dyno only applies to how it measures the power.
I dont know what were talking about anymore... But a dyno like this without the brake applied creates less load on the engine than a highway and if his car likes to change boost based on load i dont see what your going off about...
"Cant remove the mass of the mass of the drum"
lol what are you even getting at??????
1989 535i - sold
WTF are you talking about? Are you drunk? Maybe high?
If you don't know what I'm talking about here, you probably shouldn't be answering questions about the dyno... Just sayin'
