1989 535i - sold
1999 M3 Tiag/Dove - sold
You could drill and tap the obd1 tube 1/2 way up, maybe 1/8- 1/4 NPT --> barb fitting. Then run a hose to your catch can.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Got more done on the underpanel /lip today.
What do you guys think?
It will be painted black, a rad baffle will be added, and maybe some bracing.
Also installed el cheapo slim 16" electric fan on the front of the radiator. I think I am going to wire it to the factory aux fan wiring.
Also painted intercooler brackets black.
Glad to hear you're enjoying that boost life! Need videos NOW!
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
Would something like this work as a safety measure in the event of an overboost? http://www.ebay.com/itm/New-Pressure...8AAOSwxCxT-~Uh
Thinking I could put that in the intake manifold. For $20 seems like cheap insurance, assuming it would work/prevent damage if.. say the wg line was damaged.
That won't flow enough air to be of any use.
Sent from my GTX3582R
Thats what I was concerned about.
I think ill get a cheapo 44mm wg and stick it on the cold side charge pipe and use it as a safety relief valve.
I have never used a safety valve. Your S256 flat out might do 500-550 rwhp. Not sure you could get in much trouble.
1989 535i - sold
Volosso is making 600+ ?
1996 332IS
Built 3.2
1989 535i - sold
1996 332IS
Built 3.2
1989 535i - sold
1996 332IS
Built 3.2
1989 535i - sold
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
I'm just running off wg. Tial 44mm.
If I were you I would make the wastegate line out of brake line. Can't come off, can't melt. If you want another line of over boost protection, get a normally closed adjustable pressure switch and wire it inline with the +12V supply to the injectors.
http://www.atpturbo.com/mm5/merchant...&Store_Code=tp
Don't put a wastegate on the charge pipe, they have no o rings in the valve seat so they are not air tight.
