Quick question: What exhaust manifold gasket do you guys recommend? I've read to avoid using the ones that come with the manifold since they aren't that good. Should I just get an OE one? I wanted to avoid that because it has the heat shield built in and I thought that may cause issues
He man, I see you posting a lot of questions in other peoples threads non related to their builds. (also known as thread jacking)
Maybe start your own buildthread where you can post all of your questions of which I am sure people are happy to answer for you.
I say this in the nicest way possible, no harm done by you asking questions! maybe just ask them in your own thread!
as a response to your question, since most manifolds are the same for M54 and M52 engines, I think you could use the gaskets for the M52,
OEM number:11621744252
I too appreciate the ballseyness in the way you go at it, you get shit done.
I take a lot of info/motivation from this thread. gets me going!
I'm aware of threadjacking, just wanted to get these few questions asked in order to finish gathering up all my parts for my build. I didn't want to start a build thread until I have everything so I could post it all at once vs posting for a year with tiny updates
By the way thanks for the part number. I looked in realoem last night and only found a gasket that came in pieces of two versus what you posted which is exactly what I was looking for.
FWIW I have been running OEM exhaust manifold gaskets on my turbo build without issue. I have used both the OBD1 and OBD2 gaskets. Neither gave me an issue.
Where did you buy the rear panel from? I need one for my sedan. Thanks
Sent from my SAMSUNG-SM-G870A using Tapatalk
Thanks man, that's pretty cheap especially coming from the dealer.
Haha I know that's right. How long did it take to get it btw
Like 2 or 3 days.
No prob. I used a drill with an assortment if small drill bits for pilot holes and a spot weld cutter. Also used an angle grinder with a flap disc and wire wheel to remove seam sealer as well as a cutting wheel and grinding wheel to grind some of the welds along the corners of the tail panel. And a sawzall to cut into the corners of the tail panel to help me get better access to some of the brazed sections. Finally a dremel to cut away some of the brazed sections under the tail lights. And then a welder to spot weld the new panel in.
Me and my friend worked at it for about 6 hours to get the old panel out and new one in. I have yet to do any body work, filler, or paint. So I figure another 6 hours or so for that.
Sent from my SM-G930V using Tapatalk
Damn man now that's what I call determination ha. Looks like I have quite a job ahead of me. Do you have any disassembly pictures other then what you posted. My sedan isn't an m3 or anything but it has extreme sentimental value to me. I'm doing a full restore/boost modifications with some tasteful tid bits. All done the right way of corse. I'm sure a body shop could repair with enough money but I hate bondo. It's a good product don't get me wrong but only when used correctly.
So I drove my clap trap an hour away for a car meet and some races. Had a few decent cars to run;
Sorry for the crap videos but you get the idea...
I raced a handful of cars, best runs were with an 800whp hellcat and a 650-700whp Coyote. I don't know the full mod list on hellcat, but I know its pullied, tuned, injectors, exhaust, etc.
Coyote is a FBO running E85 and a 150 shot of nitrous on a tire. I had one passenger for all runs.
Me vs hellcat
https://www.youtube.com/watch?v=5M3FXyR4Lgc
Me vs FBO nitrous Coyote
https://www.youtube.com/watch?v=FBJp-I-rs5U
those are slocars
Sub’d
― George Orwell
I beat a Coyote with a 100 shot in mine at 14 psi on the HX35 and that was the day I killed the clutch (was slipping all day). He was a very unhappy person after that.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
What whp and etc do you think you are putting down? What boost? What turbo?
You may know better than me. I plan to dyno soon.
Currently though it is a 9.2:1 S52 with a Borg Warner S366sxe (66/74) running 21-23psi on E85.\
I always tell people I THINK I am around 650, but I don't really have a clue. The car works really well. Dead hooks from any roll. And is currently 29xx lbs.
I know you street racer types like HP and traction than anything else, but every 100lbs you take out of the car is =~25hp and will make your driveline that much more durable as it's under less strain to accelerate less mass.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
