Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #4426
    Apr 2006
    Minnesota eh?
    86 325es
    Fans on an intercooler are very effective at getting the heat soak out at slow speeds. I'm going to be building a new intercooler for mine and thinking about selling my vibrant core and getting a Garrett. I've read really good things about them.
  2. #4427
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Selling? How much?
  3. #4428
    Feb 2012
    1995 BMW M3
    Also; to those running dual 450s, are you running both pumps full time or are you triggering the second pump off a hobbs switch?
    Two 450s full time seems like a retarded amount of fuel at idle and also probably heats up the fuel unnecessarily. However, I would much prefer to cut out any weak links or potential failure points, such as a hobbs switch... Thoughts?
  4. #4429
    Mar 2012
    Renton, Wa
    98 m3
    If its a split feed tank you have to run both
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #4430
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by vollosso View Post
    I'm gonna get a RR dual hanger in a few weeks when they get re-released.
  6. #4431
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by rajicase View Post
    Selling? How much?
    It is just a core, no end tanks
  7. #4432
    Vancouver, B.C., Canada
    '97 M3
    I run both 450s in parallel from each side continuously and monitor fuel temps on the OBC from an ethanol sensor.
    In addition to doing the fans on the intercooler I also sealed the intercooler to the rad which isolates the air from the intercooler and the from the kidney grill inlet. I did some testing to confirm that if the two aren’t sealed from each other the efficiency of the intercooler is crap. To test it I put plastic bags over the kidney grills and did highway WOT pulls and saw great improvements on the IATs. Water temp went up with the kidney blocked, that’s why I went with isolating the top and bottom inlets. If you don’t isolate the top and bottom inlets the kidney grill air goes down behind the intercooler and you don’t have a pressure differential across the intercooler which is required for any heat exchanger to work as it should.
  8. #4433
    Feb 2012
    1995 BMW M3
    Guess its about time for an update;
    So a lot has happened in the last 8 months. Crashed the M3, fixed it, got it back on the road, yada yada..
    Shortly after getting it back on the road I blew up my 3rd ZF 5 spd. Thought it was the bottom end so I pulled the motor like an idiot. While the engine was out I decided to replace the rod bearings for the hell of it. Upon first start I was getting a really bad bottom end knock. Sounded like rod knock. Super frustrated with the car so I said f**k it and gave up.
    Fast forward to a few days ago, I got the car towed to my new house and pulled the oil pan to investigate. Im 90% sure what happened was when I had the engine out I leaned on one of the tabs on the windage tray; was bent in and had damage from what looked like where a rod cap was smacking it. Pretty sure that was the source of my knock. So hopefully gonna get it back on the road real shortly here.
    Other news; bought a 2007 Kawasaki Zx6r and a house so got myself a nice little 2 car garage to work in and have been enjoying the bike and my 135 in the absence of my m3.
  9. #4434
    Feb 2012
    1995 BMW M3
    RACEKAR en route to my new house. Looks pitiful , I know. Flat tire up front. License plate crooked from a screw missing. Almost a years worth of dust. Almost done neglecting the poor thing.
    Below is also pictured the spot on the windage tray that I believe was the source of my knocking. Also a pic of my bike and the 135 on one of the best roads in Alabama!
    Sent from my SM-G930V using Tapatalk
  10. #4435
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It looks like the turbo E36M3 is no longer the most important thing in your life. I have had mine for 13-14 years and it has never been parked for a year. Broken many times. Shared my driving with 4 other cars. And been with my through 3 or 4 houses. But only one wife. I think you should give the E36M3 more attention.
  11. #4436
    Feb 2012
    1995 BMW M3
    I have definitely been slacking. Lost all motivation with the car for a while. But I got the itch back. Shes gonna be back out hurting feelings again shortly.
  12. #4437
    Apr 2006
    Minnesota eh?
    86 325es
    When working on the car becomes a chore sometimes you just have to put it away awhile
  13. #4438
    Mar 2013
    Upstate NY
    M3
    Keep in mind you also don't have to make 800-900 whp in a 3200lb car to have fun either lol. (Stop breaking shit and know your limits!!!)
  14. #4439
    NY
    skateboard
    Quote Originally Posted by Mklock View Post
    Yes a block designed for maybe 300 can only take so much abuse.
    ― George Orwell
  15. #4440
    '97 M3
    Quote Originally Posted by GG///M3 View Post
    I don’t think he cracked his block, just a couple mistakes so nothing to do with the strength of the engine.
  16. #4441
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    True. Engine hasnt given me issues since I built it. My dumbass messed that up. The transmission on the other hand has given me fits. On my 3rd 5 spd zf in a year. I'm getting like 2-3k miles out of a trans now.
  17. #4442
    Jul 2005
    PEI, Canada
    2001 330i
    Some food for thought:
    My local speed shop runs 2 drag cars. Both have engines making just over 1000 HP N/A. He runs the same model power glide transmission in both cars, which is rated for 3000 HP. He has to rebuild both transmissions after a season of racing, which in Canada is limited to about 8 to 10 track events.
    Having a transmission that is rated for X HP, doesn't mean it will last forever.
    At one point I had 4-ZF transmissions in my shop in anticipation of "breaking parts". I put serious $$$ in a clutch and shifter thinking that this was going to be the way to go. After less than 2000 miles of driving the car with that setup, I decided it wasn't for me. I knew torque wise I was on the edge of breaking 3rd gear, and I wasn't even fully turned up. Secondly, the transmission didn't shift as fast as my arm wanted to.
    If I was to do all this again, I would think 2 steps or "build revisions" down the road. While I knew that I wanted to make 450rwhp with the car in 2011 when I started, I should have been thinking about the 800hp, and 1000hp goals that would follow. That would have saved me years of headaches, and nearly $20k in transmission related expenditure.
  18. #4443
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Buy an SMG from an E46, they're super cheap and you can just add the shifter detents to it to make it a normal old 6 speed. It's a small amount of machine work to the bell housing to add grooves for the C clips but overall simple and seems to save a few hundred at least. But you also need the front half of the driveshaft, shifter linkage and carrier and the correct clutch disks.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  19. #4444
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    So was one of rods hitting the windage tray?
  20. #4445
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by IR M5 View Post
    I BELIEVE so. I have been unable to find anything else that would cause a bottom end knock. All the rod caps were on the correct rods, in the correct orientation and all were torqued to spec. All the bearings looked fine. All plastigauged in spec. I got everything back together and should be able to start it in the next couple days and ill know if its fixed or not.
    Quote Originally Posted by somebody5788 View Post
    I haven't decided what Im going to do for the trans. Maybe ill get a few thousand back come tax season and Ill just bite the bullet and do a conversion.
  21. #4446
    Mar 2012
    Renton, Wa
    98 m3
    If you’re going to do a trans swap put the final solution in there...
    1989 535i - sold
  22. #4447
    Feb 2012
    1995 BMW M3
    Welp. Engine still knocking as bad as ever. Dont know any more. But this is no longer fun, I do know that.
  23. #4448
    NY
    skateboard
    Sadnesses
    ― George Orwell
  24. #4449
    Mar 2013
    Upstate NY
    M3
  25. #4450
    Jul 2005
    California
    Bima
    does the knock go away when u press in the clutch alittle?
    just had to ask because mine did this and it turned out the tranny was blown instead.
Page 178 of 186 FirstFirst ... 78128153168169170171172173174175176177178179180181182183184185186 LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
