Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #4376
    Apr 2006
    Minnesota eh?
    86 325es
    60 psi base. Mine were the HP pumps that relieved at 120 or something. I flow tested them at 100 psi but don't remember the numbers. At 14.6 volts the pressure would drop like 5 or 10 psi with the injectors held open static for a short pulse. No pump I've ever tested flows what it should after going through lines and a filter and rail, ect... My VE drops off quickly above 7k so it was leanest at about 7000. I ran for a good while making drag pulls where the duty cycle was 100% for the majority of the pass lol. Finally put bigger pumps and 2200's in it. I'm also a 2.8L
    Test mode in megasquirt is the balls.
  2. #4377
    Jul 2004
    Austin, TX
    AA turbo 332i
    Idk man ‘yolo’ aside, I’m not here much but have been following your build for some time and perhaps it’s time to wait for the injectors and pump(s)
    The local 800hp+ cars will still be around in a couple months to beat on when the real cheese starts coming in and I want your motor to be too!!
    Personally my biggest fear is blowing something up while messing with a Mustang GT, 335i etc (my league lol) and then I’m just “that guy in that old broken car” on the side of the road.
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  3. #4378
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Okay guys issue here. Pulled my turbo today to replace the hardware and t4 gasket. A while back my scavenge pump failed and oil poured out of the center section. It got between the center section and the exhaust housing and cooked itself and essentially glued the center section to the turbine housing. I cannot separate the turbine housing.. any suggestions?
    Sent from my SM-G900V using Tapatalk
  4. #4379
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    A small chisel at the edge, where it meets...all the way around.
    A credit card ready.
  5. #4380
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    A lot of turbos seem to have the center section stuck to the turbine housing, even after a relatively short period of use.
  6. #4381
    milKt's Avatar
    Mine snugged up one time.
    Little wisdom and elbow grease cocked it loose.
    ANTI SEIZE
  7. #4382
    Feb 2012
    1995 BMW M3
    Finally got that stupid whore apart.
    Will anti seize prevent this from happening again? Not sure how anti seize will like the temps of that turbine housing, but I don't want to have to deal with this again
  8. #4383
    Jul 2005
    PEI, Canada
    2001 330i
    Perfect time to get a bigger turbo....
  9. #4384
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by PEI330Ci View Post
    I cannot fit a bigger turbo.
    I ground the shit out of the block AND the compressor cover and it BARELY fits. I can barely get a piece of printer paper folded in half to fit between the block and compressor cover. My only option, which I have and am considering, is to see if my cover can be milled out a bit and get the 69mm compressor wheel. Hell, maybe even a 70 or 71mm wheel. I don't know how much material can safely be removed from the 366 cover though..
  10. #4385
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by rajicase View Post
    I thought that the 366 shared the same cover casting as the 369? You'd just have to mirror your modifications on the new cover.....
    You'd definitely have an issue with an S400.....which would be the step above 69mm from Airworks.
    I'm not sure how Precision would match up size wise....
  11. #4386
    Feb 2012
    1995 BMW M3
    I'm sticking with Borg man. I'm sold. This s366sxe has changed my life lol. Its been an amazing turbo; cant beat it for $750 shipped brand new.
    If the 369 shares the same cover dimensions, I could use it and modify it. But I'm not really in a financial position to drop the money on another turbo yet.
  12. #4387
    Jul 2005
    PEI, Canada
    2001 330i
    For what it's worth, I'm kind of in the same boat.
    I would like to have access to more airflow than the GTX40 can deliver....and have looked at the GTX42...but don't know if it will fit....
  13. #4388
    Jul 2005
    PEI, Canada
    2001 330i
    I completely understand.
  14. #4389
    Apr 2006
    Minnesota eh?
    86 325es
    Precision 7675 is the ultimate in medium frame airflow
  15. #4390
    Jul 2005
    PEI, Canada
    2001 330i
    That's what Kenton is running and has recommended...
  16. #4391
    Huntsville, AL
    95 M3
    With the way the 66mm spools, I would look for a larger hot side turbine housing or some other means to increase exhaust flow. It would be interesting to get the exhaust back pressure on your set up to get a baseline. Maybe it isn't a problem, but if your at a 2:1 ratio, your killing HP.
    WOT
  17. #4392
    milKt's Avatar
    Permatex® Anti-Seize Lubricant - 80078
    [COLOR=#666666 !important]Category: Specialty Lubricants - Anti-Seize
    [/COLOR]
    A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing due to weathering or chemicals. Anti-Seize assures easier disassembly. Temperature range: -60°F to 1600°F (-51°C to 871°C).
  18. #4393
    Virginia
    97' m52 turbo
    Quote Originally Posted by milKt View Post
    [/COLOR]
    This makes very good lube for everything
  19. #4394
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by 328iFun View Post
    Everything....?
  20. #4395
    Boston, MA
    E36 M3 Turbo
    Absolutely everything gets lubed once that stupid cap is opened.. it gets everywhere
    edit: WOW 1600 degrees!!!
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  21. #4396
    milKt's Avatar
    Quote Originally Posted by SCapelo View Post
    *insert Randy from South Park "relaxing" in front of his computer*
  22. #4397
    Virginia
    97' m52 turbo
  23. #4398
    Feb 2012
    1995 BMW M3
    So since I had to take so much material off the cover it finally shit itself.
    Now I've called a local shop that builds custom borgs to see if they have a smaller cover they can mill out for my 66.
    If not, I'm going to need to look for another turbo. Any suggestions on a turbo that has a smaller compressor cover that will make at least 800whp? Does one exist?
  24. #4399
    DeWitt, Michigan
    '97 540i/6, '97 328i
  25. #4400
    Feb 2012
    1995 BMW M3
    Opened it up till I got to thick metal..brought to a machine shop since I can't tig. They said they can put a flat piece over it. Hope it doesn't fuck up flow too much...
Page 176 of 186 FirstFirst ... 76126151166167168169170171172173174175176177178179180181182183184185 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
