Thread: Rajicase's First Turbo Build, Ballin' On A (Nonexistent) Budget
  1. #4226
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Medical field is a smart career path these days -- easy to find work anywhere in the country, even in the world, and it pays decently enough to support a car hobby, unless maybe you have a family to support instead. Now you can buy a daily driver/tow vehicle and trailer for your drag car.
  2. #4227
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by dburt86 View Post
    Congrats on graduating. That’s some real shit
    Thanks man!
  3. #4228
    Nov 2013
    VA
    E36
    In all seriousness, MilkT had a huge role in this venting business here on BFC. Back in 2012 or 2010 he started up a good thread about this. It ultimately solved my issue with oil getting into the pipes. Obviously the practice has been around for some time. MikeR probably brought it to BFC attention. But, Craig started up a nice discussion about it.
    Sent from my E6782 using Tapatalk
    I started getting oil in the piping right around 11 psi but hasn't gotten worse at 18psi. Running t4 JB 6262 Precision. May need to try this vent line.
    OP,
    Congrats on graduating. To this day, one of my biggest accomplishments. The additional moneyz is very nice.
  4. #4229
    Feb 2012
    1995 BMW M3
    Thanks!
    Question;
    I'm gonna be getting a second fuel pump soon. Would it be stupid to put a bulkhead on the bottom of the drivers side of the gas tank to feed an inline pump?
  5. #4230
    Apr 2006
    Minnesota eh?
    86 325es
    Yes, yes it would. Not a safe plan. Congrats on graduating.
  6. #4231
    Feb 2012
    1995 BMW M3
    Dammnit.
    And thanks!
    Would putting a bulkhead in the top of the fuel pump hanger and just running a hose down to the baffle be a better way to supply an inline?
  7. #4232
    Mar 2012
    Renton, Wa
    98 m3
    I don't know a ton of supra guys bulkhead the bottom of the tank with success...
    I wouldnt discount it, i considered it.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  8. #4233
    Apr 2006
    Minnesota eh?
    86 325es
    Some people also do backflips on dirt bikes with no helmets. Remember the OP driving over a pipe on the interstate and ruining his exhaust? Now add a 1" hole in the bottom the gas tank to that.
  9. #4234
    Feb 2012
    1995 BMW M3
    Met with Zack today; we turned up the boost another 1 psi.
    Added a bit of fuel and timing and feels real good now.
    Gonna get on the dyno in the next week or so and see where she is at.
  10. #4235
    Mar 2012
    Renton, Wa
    98 m3
    You mean 1 click? Haha.
    1989 535i - sold
  11. #4236
    Boston, MA
    E36 M3 Turbo
    1 psi more.. doesn't give that kick that you really need lol
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  12. #4237
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by SCapelo View Post
    We cleaned up the fuel, added a bit of timing and upped the boost to the next click on his mbc.
    His boost isnt stable up top so we discussed a few things before pushing it anymore. He is still running the 85psi walbro which has to be relieving, that little intercooler, a tiny filter, and a 12 psi spring.
    Hopefully he knocks out these before the dyno
    1989 535i - sold
  13. #4238
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by vollosso View Post
    I really don't like how the AEM Truboost tapers off a couple PSI. How bad is the MBC? You'd notice a huge difference in spool up if you went to an electronic one. I saw full boost at least 300rpm sooner just from some tweaks on the settings but I miss how when I was on WG pressure it would be rock steady boost from the hit until redline
  14. #4239
    Mar 2012
    Renton, Wa
    98 m3
    If youre tapering try a stiffer wg spring or a different boost controller pressure pickup location.
    1989 535i - sold
  15. #4240
    Boston, MA
    E36 M3 Turbo
    You're right, anything less than 18psi is pretty much a toyota camry anyways
  16. #4241
    Manchester, N.H.
    96 332IS 6466 turbo
    What does +1 psi mean ? 14 to 15 ? Or 28 to 29 ?
    I would drop the coin on an Eboost2 or eboost street. Clamp that gate shut till you want it to open.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  17. #4242
    Mar 2012
    Renton, Wa
    98 m3
    Well raj's boost gauge is really twitchy i was seeing about 3-4 psi increase under peak boost. On the higher boost setting it was 24psi. I was watching afr/rpm more than boost though. Note that he was tapering down to 17psi..
    1989 535i - sold
  18. #4243
    Feb 2012
    1995 BMW M3
    Car feels a good bit faster.
    Seeing 24ish psi and it tapers off at redline.
    Id like an EBC but in my immediate future, a new IC needs to be purchased. Im still running a 3" $75 ebay IC. That has got to be costing me a decent bit of power.
  19. #4244
    Manchester, N.H.
    96 332IS 6466 turbo
    Huge difference. Get the treadstone tr1235.
    1996 332IS
    Built 3.2
  20. #4245
    Feb 2012
    1995 BMW M3
    I was thinking the 1045; I was thinking a thicker core would be more beneficial than then extra height. Whats your opinion?
  21. #4246
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by rajicase View Post
    I think the extra height is better because it exposes more surface area of the core material than a thicker core would. Probably leads to better cooling
  22. #4247
    NY/FL
    '08 G35S, '98 M3/4/5
    Updates:
    Cars been running good.
    Giving the sced and nitrous v8 losers the sauce.
    Graduated! XD
    Got a job in a cardiac icu so I'm stoked
    Gonna be making real money so I can have shiny car parts now instead of these hand me downs XD no more building a turbo M3 on a pizza delivery budget
    Gonna pick up all the hoes in my new lambo
    Lots of winning
    Hell yeah even Alabama says no to the ChoMo.
    Also , im gonna take up modeling. Look how sexy I am.
    Sent from my SM-G900V using Tapatalk
    I see nothing but win in these posts. Overwhelming amounts of win. Exactly why I return to view this forum, besides parts scavenging lol.
    Makes me wanna put my crapbox blue car together....someday lol.
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  23. #4248
    Mar 2012
    Renton, Wa
    98 m3
    Raj the closer to square You are the better flow you have but Youll need ducting to get the air through at some point.
    Id stab the 4.5" in there.
    1989 535i - sold
  24. #4249
    Feb 2012
    1995 BMW M3
    Would you go for the 1045 over the 1235?
  25. #4250
    Mar 2012
    Renton, Wa
    98 m3
    As big as you can fit. 1245
    1989 535i - sold
Page 170 of 186 FirstFirst ... 70120145160161162163164165166167168169170171172173174175176177178179180 ... LastLast
  1. My first turbo build....m52/t4spa/6262
    By bmw328m52 in forum Forced Induction
    Last Post: 07-30-2020, 11:42 AM
  2. First Turbo Build
    By Hitalick in forum Forced Induction
    Last Post: 09-24-2014, 12:30 PM
  3. first turbo build and need insight!!
    By mmm3power in forum Forced Induction
    Last Post: 06-30-2014, 08:06 PM
  4. first turbo build and need insight!!
    Last Post: 06-29-2014, 09:11 PM
  5. First turbo build help?
    By 318Isaac in forum Forced Induction
    Last Post: 11-26-2010, 05:08 PM
